    Weird Laser Mode
    Laser Cutters
    3.2k
    • g0rgundefined
      g0rg @pauledd
      @pauledd You got it ! Same idiot issue. I put the board on the right pins and it works now.
      Sometimes more than 2 eyes and a good reactive forum helps.
      Thank you very much guys !
      Duet 2 wifi , Ooznest Worbee CNC 1510 , Neje Laser 20w. Ruida 100w Co2 Laser 6090. Some homemade laser cnc grbl 1515.
      • FelixHundefined
        FelixH
        So @pauledd how do you focus your laser now?
        I need to do some engravings today and I haven‘t used the laser since I updated the RRF to 3.3, so I fear I will have some troubles there.
        I understand the safety issue behind, but I used to use the laser at 1% power to align it with my work and also focus. I don‘t understand how I am supposed to do it now if the laser can only be ON while moving…
          Phaedrux Moderator @FelixH
          @felixh said in Weird Laser Mode:
          I'm not sure either, but maybe a work around could be to start a move with the laser on with a very very slow feed rate so that it barely actually moves?
          FelixHundefined 1 Reply Last reply Reply Quote 0
          • FelixHundefined
            FelixH @Phaedrux
            @phaedrux following the original poster's suggestion, I prepared two macros for that:
            FOCUS LASER ON
            M106 P2 S255  ; turn on laser's 12v PSU
            M451   ; disable Laser Mode
            M950 F3 C"nil"
            M950 F3 C"!exp.heater3" Q1000   ; assign laser pin to a free fan Numbe
            M106 P3 S0.001 ; enable laser with 1% power
            ; do the focusing stuff
            FOCUS LASER OFF
            M106 P3 S0 ; disable laser
            M950 F3 C"nil" ; free heater3 again for use in laser mode
            M106 P2 S0  ; turn on laser's 12v PSU
            it works ok. My problem is now that I have to do the focusing BEFORE switching to Laser mode with:
            M452 C"!exp.heater3" S1 F200
            If I have done something in laser mode and I have to refocus or pinpoint another work origin, even if I switch to CNC mode it throws an error telling me that the pin "exp.heather3" is occupied (or assigned, I don't remember). So, how do "unassign" the pin when I switch from Laser mode to CNC mode?
            Sincerely I can understand the safety concerns behind not being able to use M3 while not moving, but at the end of the day, if I have a laser I have to be able to set it onto the correct origin and also focus it. Even I am not able to do that with a M3 command, I have been able to do find a workaround.
            I think this is an issue it should be addressed. It makes working with a laser cumbersome and overly complicated if you are not use to tinker with the RRF3 environment. Maybe a solution would be limit the power output of the M3 command to 1% when stationary? Just an idea...
            • FelixHundefined
              FelixH
              well, just as usual after I posted something I myself come up with an improvement...
              I changed the macros as follows:
              Laser focus ON
              M453   ; Enable CNC Mode
              M950 P0 C"!exp.heater3" Q1000   ; assign laser pin to a pin number
              M42 P0 S0.01  ; set 1% PWM on GPIO port 0
              Laser Focus OFF
              M42 P0 S0 ; disable laser
              M950 P0 C"nil" ; free heater3 again for use in laser mode
              And I changed my "switch to CNC macro to:
              M5
              M106 P2 S0  ; turn off 12v PSU
              M452 C"nil" ; free "exp.heater3" pin
              M453 ; Put the machine into CNC Mode
              M550 P"WorkBee CNC Machine" ; Set machine name
              in which I added the M452 C"nil" line.
              This seems to work, although when I go back to CNC mode the console throws a red warning:
              Error: DueX fan or GPIO pins may not be used to control lasers
              but well, it looks like I will have to live with it. On a positive side, I think that the M42 command lets me control the power of the laser somehow better. Yesterday I used it "the old way" with a Fan port and even a M106 P3 S0.001 would start burning the plywood after a couple of seconds.
              o_lampeundefined 1 Reply Last reply Reply Quote 1
                M452 C"nil" should free the pin.
                Which I see you found already.
                I'm not sure on that either. @dc42 could say more?
                • FelixHundefined FelixH referenced this topic
                • o_lampeundefined
                  o_lampe @FelixH
                  @felixh
                  I guess you get this error message, because RRF doesn't register the C"nil" part.
                  It just recognizes you are using M452 in CNC mode... @dc42 I guess, this could be sorted out?
                  Felix, would it be possible to go through a real tool change? Then you could free the laser pin in tfree.g* while you are still in laser mode.
                  • FelixHundefined
                    FelixH @o_lampe
                    @o_lampe
                    I will try it when I get back home, yeah. Thanks!
                    • o_lampeundefined
                      o_lampe @FelixH
                      @felixh
                      I figured out a simpler method to fire the laser without moving.
                      No need for CNC mode switches and re-assigning pins:
                      G1 E10 F60 Snnn   ; requires a virtual extruder in config and M302 P1 to allow cold extrusion
                      With this simple line your laser will fire up for 10sec. Tested with RRF3.3
                      • o_lampeundefined o_lampe referenced this topic
                      • FelixHundefined
                        FelixH @o_lampe
                        @o_lampe sounds great and simple, but am I right to think you are working with a 3D printer setup?
                        • o_lampeundefined
                          o_lampe @FelixH
                          @felixh
                          The controller was in 'Laser mode' when I tested it, but there was also an extruder tool config. It's not necessary to have a stepper or thermistor connected, just a virtual config.
                          • Otsoundefined Otso referenced this topic
