    Extruder 0 has no filament sensor
    Filament Monitor
    1.5k
    • Dave Parryundefined
      Dave Parry @alankilian
      Its on the row next to the X end stop which I hope is E0 end stop. It is on my wiring connection drawing anyway. It is the wiring with the yellow heat shrink on.
      Apologies for crappy photo, but I have to take the heated bed off to get to the board, and then recalibrate.
      • alankilianundefined
        alankilian @Dave Parry
        @dave-parry
        It looks like you've got the E0_STOP and GND wires reversed according to THIS PAGE.
        Dave Parryundefined 2 Replies Last reply Reply Quote 0
          @alankilian Dont they reverse at the Sensor end, which would mean it doesnt matter? or have I misunderstood the instructions. If it is wrong its easy to change at the sensor end,
          Dave Parryundefined 1 Reply Last reply Reply Quote 0
            Dave Parry @Dave Parry
            Just rechecked and on the sensor I have white wire(GnD) is going to the top connection (Gnd). Red to centre and Black Wire to Data.
            This seems to me to be ok. Should I reverse the data and gnd to see if that cures it?
            Agree would be better if I had Gnd as black, I Just connected the wrong end to the board.sensor end 2.jpg
              @alankilian Have just double checked the wiring by testing from the underside of the Duet board to the sensor, and they check out ok.
              Is there only one line of code in the config.sys.
              ie - M591 D0 P3 C"e0_stop" S1
              or have I missed a command out.
                @dave-parry Do I need to define the end stop with M574?
                I have used the following:-
                M574 U2 S1 P"e0stop"
                  @dave-parry
                  It looks like your wiring is fine (except for the colors man 😆 ) so that's not it.
                  I do not have an M574 for the extruder stop, so that's probably the problem since it's defining a switch as the endstop type for pin e0_stop.
                  Also, make sure you have e0_stop in your M591.
                    @alankilian No I only just tried the 574 command, as I thought that might be the problem;
                    I'm using
                    M591 P3 C"e0_stop" S1
                    I have noticed that the led flashes Red-Green when no filament in and irregular green when printing. I assume thats correct.
                    alankilianundefined 2 Replies Last reply Reply Quote 0
                      @dave-parry
                      The only thing I can think of is to use an Ohm meter to check your black wire is complete.
                      Do you happen to have an oscilloscope or a USB analog capture device so you can look at the signal coming out of the sensor?
                      You could also use an LED and a resistor. (I'll have to think about how to do that a bit.)
                      Maybe someone else sees something I'm missing.
                        @dave-parry said in Extruder 0 has no filament sensor:
                        I'm using
                        You've got a D0 in there right?
                        Dave Parryundefined alankilianundefined 2 Replies Last reply Reply Quote 0
                          @alankilian Have checked all the wires with a meter, from the back of the duet through to the pins on the connector. I also checked through to the pogo pins for the gnd and 3.3 v but the data doesnt go to them so cant check futher than the connector.
                            @alankilian Where does that go?
                              alankilian @alankilian
                              Just for fun, I disconnected my sensor and did a power-on and I get:
                              m591 d0
                              Duet3D rotating magnet filament monitor v1 on pin e0stop, enabled, sensitivity 28.80mm/rev, allow 60% to 160%, check every 3.0mm, no data received
                              So...... We can forget about wiring.
                              Something else is wrong.
                              Can you type this in the GCODE console and report back the results:
                              • m591 D0 P1 C"e0_stop" S1
                              • m591 D0
                              • m591 D0 P3 C"e0_stop" S1
                              • m591 D0
                              Here's what I get:
                              m591 D0
                              Simple filament sensor on pin e0stop, enabled, output low when no filament, filament present: yes
                              m591 D0
                                @dave-parry Ah yes I have
                                M591 D0 ; display filament sensor parameters for extruder drive 0
                                after the M591 command.
                                  @dave-parry
                                  Try the test commands I posted above you.
                                    @alankilian MiniKossel
                                    Status
                                    Idle
                                    Mode: FFF
                                    Tool Position
                                    X
                                    0.0
                                    Y
                                    0.0
                                    Z
                                    250.00
                                    Extruder Drives
                                    Drive 0
                                    0.0
                                    Speeds
                                    Requested Speed
                                    0 mm/s
                                    Top Speed
                                    0 mm/s
                                    Sensors
                                    Vin
                                    24.1 V
                                    MCU Temperature
                                    43.9 °C
                                    Z-Probe
                                    0
                                    Tools
                                    Extra
                                    Control Heaters
                                    Tool Heater Current Active Standby Hot End
                                    T0 - Load Filament Heater 1
                                    active 27.3 °C
                                    Bed Heater 0
                                    off 29.4 °C
                                    Temperature Chart
                                    30/12/2021, 17:48:31 m591 D0
                                    Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 28.80mm/rev, allow 60% to 160%, check printing moves every 3.0mm, version 3, mag 133 agc 61, no calibration data
                                    30/12/2021, 17:48:19 m591 D0 P3 C"e0_stop" S1
                                    30/12/2021, 17:48:05 m591 D0
                                    30/12/2021, 17:47:51 m591 D0 P1 C"e0_stop" S1
                                    30/12/2021, 17:47:26 m591 D0 P1 C"e0_stop" S1 m591 D0 m591 D0 P3 C"e0_stop" S1 m591 D0
                                    Simple filament sensor on pin e0stop, enabled, output low when no filament, filament present: no
                                    Duet3D rotating magnet filament monitor v1 on pin e0stop, enabled, sensitivity 28.80mm/rev, allow 60% to 160%, check printing moves every 3.0mm, no data received
                                      OK!!! You've got it configured now.
                                      If you wait a minute or so, do you get a report with mag and agc:
                                      • Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 28.80mm/rev, allow 60% to 160%, check every 3.0mm, version 3, mag 129 agc 118, no calibration data
                                        filament monitor v1
                                        We may need some extra help from @dc42 to see if there's something different with the v1 filament monitor vs. my v3.
                                          @alankilian Not got that message yet and it wont home now. I get Error G28
                                          failed to enable end stops.
                                            @alankilian I only just got this about a month before christmas, so dont understand the V1
