    Extruder 0 has no filament sensor
    Filament Monitor
    1.5k
    • Dave Parryundefined
      Dave Parry @Dave Parry
      @dave-parry Do I need to define the end stop with M574?
      I have used the following:-
      M574 U2 S1 P"e0stop"
      • alankilianundefined
        alankilian @Dave Parry
        @dave-parry
        It looks like your wiring is fine (except for the colors man 😆 ) so that's not it.
        I do not have an M574 for the extruder stop, so that's probably the problem since it's defining a switch as the endstop type for pin e0_stop.
        Also, make sure you have e0_stop in your M591.
        Dave Parryundefined 1 Reply Last reply Reply Quote 0
          Dave Parry @alankilian
          @alankilian No I only just tried the 574 command, as I thought that might be the problem;
          I'm using
          M591 P3 C"e0_stop" S1
          I have noticed that the led flashes Red-Green when no filament in and irregular green when printing. I assume thats correct.
          alankilianundefined 2 Replies Last reply Reply Quote 0
            @dave-parry
            The only thing I can think of is to use an Ohm meter to check your black wire is complete.
            Do you happen to have an oscilloscope or a USB analog capture device so you can look at the signal coming out of the sensor?
            You could also use an LED and a resistor. (I'll have to think about how to do that a bit.)
            Maybe someone else sees something I'm missing.
              @dave-parry said in Extruder 0 has no filament sensor:
              I'm using
              You've got a D0 in there right?
              Dave Parryundefined alankilianundefined 2 Replies Last reply Reply Quote 0
                @alankilian Have checked all the wires with a meter, from the back of the duet through to the pins on the connector. I also checked through to the pogo pins for the gnd and 3.3 v but the data doesnt go to them so cant check futher than the connector.
                  @alankilian Where does that go?
                    alankilian @alankilian
                    Just for fun, I disconnected my sensor and did a power-on and I get:
                    m591 d0
                    Duet3D rotating magnet filament monitor v1 on pin e0stop, enabled, sensitivity 28.80mm/rev, allow 60% to 160%, check every 3.0mm, no data received
                    So...... We can forget about wiring.
                    Something else is wrong.
                    Can you type this in the GCODE console and report back the results:
                    • m591 D0 P1 C"e0_stop" S1
                    • m591 D0
                    • m591 D0 P3 C"e0_stop" S1
                    • m591 D0
                    Here's what I get:
                    m591 D0
                    Simple filament sensor on pin e0stop, enabled, output low when no filament, filament present: yes
                    m591 D0
                      @dave-parry Ah yes I have
                      M591 D0 ; display filament sensor parameters for extruder drive 0
                      after the M591 command.
                        @dave-parry
                        Try the test commands I posted above you.
                          @alankilian MiniKossel
                          Status
                          Idle
                          Mode: FFF
                          Tool Position
                          X
                          0.0
                          Y
                          0.0
                          Z
                          250.00
                          Extruder Drives
                          Drive 0
                          0.0
                          Speeds
                          Requested Speed
                          0 mm/s
                          Top Speed
                          0 mm/s
                          Sensors
                          Vin
                          24.1 V
                          MCU Temperature
                          43.9 °C
                          Z-Probe
                          0
                          Tools
                          Extra
                          Control Heaters
                          Tool Heater Current Active Standby Hot End
                          T0 - Load Filament Heater 1
                          active 27.3 °C
                          Bed Heater 0
                          off 29.4 °C
                          Temperature Chart
                          30/12/2021, 17:48:31 m591 D0
                          Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 28.80mm/rev, allow 60% to 160%, check printing moves every 3.0mm, version 3, mag 133 agc 61, no calibration data
                          30/12/2021, 17:48:19 m591 D0 P3 C"e0_stop" S1
                          30/12/2021, 17:48:05 m591 D0
                          30/12/2021, 17:47:51 m591 D0 P1 C"e0_stop" S1
                          30/12/2021, 17:47:26 m591 D0 P1 C"e0_stop" S1 m591 D0 m591 D0 P3 C"e0_stop" S1 m591 D0
                          Simple filament sensor on pin e0stop, enabled, output low when no filament, filament present: no
                          Duet3D rotating magnet filament monitor v1 on pin e0stop, enabled, sensitivity 28.80mm/rev, allow 60% to 160%, check printing moves every 3.0mm, no data received
                            OK!!! You've got it configured now.
                            If you wait a minute or so, do you get a report with mag and agc:
                            • Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 28.80mm/rev, allow 60% to 160%, check every 3.0mm, version 3, mag 129 agc 118, no calibration data
                              filament monitor v1
                              We may need some extra help from @dc42 to see if there's something different with the v1 filament monitor vs. my v3.
                              Dave Parryundefined 2 Replies Last reply Reply Quote 0
                                @alankilian Not got that message yet and it wont home now. I get Error G28
                                failed to enable end stops.
                                  @alankilian I only just got this about a month before christmas, so dont understand the V1
                                    @dave-parry Restarted it and it's now homing
                                      @dave-parry Have rechecked the commands and I now get this
                                      m591 D0
                                      Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 28.80mm/rev, allow 60% to 160%, check printing moves every 3.0mm, version 3, mag 133 agc 60, no calibration data
                                      So it is V3
                                        @dave-parry
                                        OK!!!
                                        You're all set.
                                        You'll get calibration data after you start a print.
                                        What do you think the problem was?
                                        • "C3" vs. "e0_stop"
                                          @alankilian No sorry Alan, I meant I put the Gcode commands in manually and it reports V3. If I power on/off it goes back to no sensor. It does however display extruder drive 0 data in the status window. If I feed some filament it increments the correct amount.
                                          alankilianundefined Dave Parryundefined 2 Replies Last reply Reply Quote 0
                                            @dave-parry
                                            Post your config.g
                                            You've just got something missing or something extra in there.
                                            You're REALLY close.
