    Does anyone here work on Superslicer?
    87
    8.6k
    • arhiundefined
      arhi @hestiahuang
      @hestiahuang said in Does anyone here work on Superslicer?:
      @dc42 said in Does anyone here work on Superslicer?:
      able us to display thumbnail images on Panel
      Sounds great! Only SS and PS? How about S3D and IdeaMaker?
      Both s3d and IdeaMaker are closed source so none of us can add anything to them. When at least one other slicer support this and the paneldue is parsing this we can request on the s3d and ideamaker forums for them to support this feature too.
      Now, s3d is dead so nothing will happen there for sure, IdeaMaker is awesome (my slicer of choice) but they are pretty slow to implement features that are totally unusable for their own printers. They only recently added octoprint integration (they had network upload and network printing with their own custom printers for years) .. but since they already embed some image in gcode if I remember correctly for their own printers this might go faster than octoprint integration 🙂
      • oliofundefined
        oliof
        @dc42 @resam Ultimaker Cura dev has answered on my feature request, I will copy that here:
        I think PNGDec is a much more friendly option for PanelDue. It requires even less memory and the PNG format actually has more than a month of battle-testing behind it. There's a decent chance that this image format gets forgotten as "that nice one from December 2021" like most new image formats. But of course, it's not up to us to decide for them. We just need to try to integrate with all of these printers and their formats where feasible.
        Since this is only going to be relevant to support certain printers (if those printers start needing it) and we can't test with those printers, we're not likely going to be implementing this at Ultimaker. What's more, Ultimaker itself will not allow us time to implement this since they don't benefit from it either. So we'll have to defer this. It's not going to get any priority, though it would be nice to have (as long as it doesn't increase complexity of code maintenance too much).
        So maybe consider pngdec and the png format?
          dc42 administrators @oliof
          @oliof my developers tell me that unfortunately .PNG format needs a 32K RAM buffer to decode it, because it uses LZW compression. That's why we can't use it for this purpose.
          For example, the documentation of PNGDec for Arduino says it only works on processors with at least 49kb of RAM. Also, the PNGDec Arduino library is several thousand lines of C++, compared to 300 claimed for a QOI decoder.
          resamundefined 1 Reply Last reply Reply Quote 1
          • resamundefined
            resam @dc42
            @dc42 Here is a QOI and a PNG of the same Cura scene (=sliced model) rendered in 320x320 pixels generated by my Cura-DuetRRFPlugin:
            snapshot.qoi.txt (just renamed to .txt for uploading here)
            And here my changes to make it happen on the next branch: https://github.com/Kriechi/Cura-DuetRRFPlugin/tree/next
            It is not embedding anything yet into the gcode file (@dc42 did you settle on a file spec for that yet?), so instead it just creates a few files in your ~/Downloads/ folder.
            The plugin also logs extensively to the usual cura log file - in case you get an error, please attach it.
            dc42undefined 1 Reply Last reply Reply Quote 2
              dc42 administrators @resam
              @resam thanks for that! What I would like is for the QOI thumbnail image to be base64-encoded and added to the GCode file as a specially formatted comment - just like PrusaSlicer/SuperSlicer do except that they start from PNG format. Both PNG and QOI have (different) magic bytes at the start of the file, so we can use them to check whether the format is QOI.
              The SuperSlicer code that does the base64 encoding and writing to file is at line 921 of https://github.com/supermerill/SuperSlicer/blob/master/src/libslic3r/GCode.cpp.
              PS - here is an example of thumbnail comment blocks generated by SuperSlicer (these are still encoded in PNG format). SuperSlicer puts it close to the start of the file, after the "generated by" comment.
              ; thumbnail begin 16x16 844
              ; iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAACPklEQVR4AYVT32vTUBTOP6KFqaC+C2
              ; Pbi/+CvyZ7moiPysA9CGotdqtx7di6pjRNm9r0l41Lmy5p2rWElrYECgGh4lOf8uZr/oNrvsCROSY+
              ; XM65957zne/e8x2u3++rs9lMMQyjJcuyPRqNalf5w+Hwa7vd1uv1es+yrG+TyaSCXM627QYuVFU1YR
              ; H8Lx/JpmlqBA4QDodwHMf5Ah+VkHSVDwswxBIoR7RAFUCwT3ne+yTLjqZpnXK5POArldBH9fF4XEUM
              ; gLEPAXAAEBzuqOqPDUnyI/v77Fk6vUzk8856NutXLMvEmxFP1WFDAFwQvU1R9FayWbaWyfg7krRAla
              ; iuz9dOTnwUooVisCEAaBIy/EgiwW4KAlvP5fyHkuTdi8X8t8fH84/5/DyjqvZfANul0hKUN/b2/OeF
              ; whLJm7Wat3V66t3K5diDTMZrdDrmowBoNZXy76TT7LGm/XqlKD9fx+MLLmiu8eboyH2vKO4TQfBeiu
              ; JC63ZbW4WCd79a9VcODthqMul/7nan9V6vE+ohuE/p+tQ6P1c5QRCm+AOIA3a32fx+LRplt4Mn3Dg8
              ; ZHdLJXY9HmfNszOduoRY/FnYRnwSDtEe+C+CJ6EDjVbLeJdKubvF4iLC8+yDKLpIGAwGTQBR6zlUxQ
              ; G1BhS3k8kl+byiOACE8i5LOdQBpAwkCAVgJF+agVix6PKiOCUpk2bAGLl/pEy0/jdM2GP4iA1H1InW
              ; RV1cHiaSOyWH00hVKREBtCfB0Mhf/CdYrN/5dKVwK+5qBwAAAABJRU5ErkJggg==
              ; thumbnail end
              ; thumbnail begin 220x124 12368
              ; iVBORw0KGgoAAAANSUhEUgAAANwAAAB8CAYAAAACRt5vAAAkAUlEQVR4Ae2dSZdcxZXH32cAGzcaql
              ; RVGhASGGNxjt3GbYNtZhvMoEIWAolJQqiQSmgGyoAEEqZAwggQNni2z/HGvWs2vfI5XvVKW69q3av8
              ...(lots more lines here) ...
              ; +5EYPU6Oqjuf08VWO1wzxcz7fJ63JSyppUeuqIGoq3czTCxqlRCxfeaPB5rkmpx1CCqabG2POYJRpD
              ; faHKYR6xbJDv87EbDDVoqkapM1bmlaQRQN345JMdGRLSHGxS6rHWsklNjSnZ8xoam9iFsS/Ldc98hP
              ; Gtj6SGJKEKSamsK00jPJcvJPyyHvVlhRxGTkjr0qEGjiqOyE31aj6TYUdOg/o08v+XlPmlxsnXiJ9L
              ; NPrWimseOIKy/g8uwR/l/+4AzAAAAABJRU5ErkJggg==
              ; thumbnail end
              resamundefined 1 Reply Last reply Reply Quote 0
              • resamundefined
                resam @dc42
                @dc42 Here the file beginning with a 320x320 QOI (about 37kB, so only the first few lines):
                ;FLAVOR:RepRap
                ;TIME:4199
                ;Filament used: 3.57983m
                ;Layer height: 0.15
                ;MINX:69.693
                ;MINY:92.957
                ;MINZ:0.2
                ;MAXX:174.818
                ;MAXY:152.057
                ;MAXZ:7.55
                ;POSTPROCESSED
                ;Generated with Cura_SteamEngine 4.12.1
                ;Exported with Cura-DuetRRF by Thomas Kriechbaumer 1.2.5
                ; thumbnail begin 320x320 37140
                ; cW9pZgAAAUAAAAFABAAA/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f
                ; 39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39
                ; /f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f
                ; /f39/f39/f39/f39/f39/f396P8aFQYa/4BnHYIA/f39/f3F/xoVBRr/06sw1/+DaiCnAP39/f39xP
                ; 8aFQYb/9auMNr/+so5//9xXBp7AP39/f39wz//06sw2P/6yzn/wP9hTxduAP39/f39wgoWKcH/OzAR
                ; bgD9/f39/cEK/9SsMNgpwv83LxdVAP39/f39wP85Lg06FinCnnn/EA4GNQD9/f39/f86Lw07/+y/Nf
                ; Apw//3yDj+/wQEBCkA/f39/fz/OzANPP/uwTbzKcT/5rs2+wD9/f39/P86Lw08AinF/8WhMfsA/f39
                ; /fsQ/+/BNvMpxv+7mCzQAP39/f36EP/tvzXx//vLOf/H/450JMMA7/9CNQ9D/yoiCSv/AAAAAP39/f
                ; 3G/zwwDT09LMj/jHIisADs/wcFAQf/RTgPRv/AnCvE//nKOP7/IhwKRwD9/f39xf9HORBI/+3ANfEs
                ; yf9nVBqKAOr/AwIAA/9hThZj/9WtMNkpwP7bsjT/CAgFLgD9/f39xP9pVRdq//rKOP7/+8s5/8r/Vk
                ; cYigDo/xANAxD/c10adf/asDHeKcL+pYct/wICAQ4A/f39/cP/aFQXav/4yTj8LMv/RjkRWADm/w8M
                ; Aw//emMbfP/pvDXtLMT/b10k9v8BAQELAP39/f3C/2lVF2sS//vLOf/M/x4aC1EA5P8iHAcj/5Z5Ip
                ; n/6r017izFnXr/Ny8YwgD9/f3L/xcTBRj/Ix0IJADxEzEszf8cFwg5AOL/HxkHH/+ZfCKc//LEN/Ys
                ; ... snip
                ; thumbnail end
                T0
                M190 S60
                M104 S215
                M109 S215
                Latest changes pushed to https://github.com/Kriechi/Cura-DuetRRFPlugin/tree/next
                1 Reply Last reply Reply Quote 4
                • botundefined
                  bot
                  I'm working on getting this up and running in PrusaSlicer. It's not going smoothly so far but that is my fault. I'll keep trying and let you know if I give up.
                  *not actually a robot
                  • botundefined
                    bot
                    Ok so I have what appears to be a working first version.
                    But, I have not figured out a way to verify that the encoded base64 is indeed the QOI image...
                    ; generated by PrusaSlicer 2.4.0+n8 on 2022-01-02 at 07:14:16 UTC
                    ; thumbnail begin 32x32 1332
                    ; cW9pZgAAACAAAAAgBAD+WVlZrIj+kJCQsYj+eHh4hYidiMB/wSiuiKeIIP53YFOb1QrBO8CliKSIKD
                    ; ssVcOsiLiImohAs4iSiIeICsGjiBHAQP6UZ07+xmw5/qdcMP6BW0UKwCgzwJqIO8Aswwr+fn5+iogZ
                    ; CiAXp4gNGRUgFf5qXlj+q2hCMsAGwP6dXDX+aF9ZERUZCjvBLMA7pIijiBU7wArAFQG1iDkNN/6RZE
                    ; sywgbB/p9dN/6DXUcZCsI7wBmliBU7KDvACsEkAR7+iH13/q1qQzLDBsP+lFw7/mVcVv5bW1vBGaOI
                    ; AjcswLeIMwrAGTMgFf58Zlkyxf6nXDDE/p5cNf6BXEYZKDMCGTvALCAFmYgVETM3/pFkSjLGBsYAER
                    ; UKwDvBCiSxiD2OiDH+uWo9MscGx/6eXDb+ZVtWCsA7wRkzIDr+nG9VMskGyA7+gVtFCsA7GQKciBn+
                    ; q2hBMsr+p1wwyHrADhmjiAIZOwodMsr+p1wwyAnAFRECGTvBHTLKBscJwf6hXzn+bm5uNzvC/rhqPT
                    ; LKBscJwf6gXjgkwDcsChkaMsmhmJkbBsUJwhUKKKOILAqoiP66bD8yyKKXo5fAGwbECcFr/p5cNgo7
                    ; GTumiKKI/rlqPjLGfqOoNcKdaf6wYTMGwnrBEP6eXDY7wKaIf0A7GjLFDDXFnWkb/qdcMMB6wRDA/p
                    ; 5cNhmriDkKLMAaMsM6o5c1yJ1p/qxfMZ16wRDAFf5zc3OsiC+SiMH+uGk9/sZsOcIMNcudaRuWDMAQ
                    ; wP6lYj3+lJSUESxAwB0VMsA6IzXOmCsQwf6lYz3+fX19p4iDiA7BFTIENdGdapYMmCz+nlw2KLOItY
                    ; j+VlZWCsAaDDXUGxUdLCCQiCwC/qZsTDXW/qFoRh3ALMA3nYj+Z1tU/pNlSjXOZsT+lGZMDsA7pogo
                    ; DkDB/mVZU/6/bkA1wWbN/r5tP/6Bal3+bW1tkogZJAqZiMJ/wP5nXFX+mGlP/s1wPM7+oWdGDiwvr4
                    ; iXiDs/nYjCIX8sp4j+e2NW/r9uQP7NcDzK/r5tP/50XVA/wCwVEaiIQDuZiFXAEqKIChk/MP5lWVL+
                    ; kWNJ/s1wO8j+r2pCP8AOCjcdMCwRCQMOP8AZHRLAIcH+k2RKKcb+kWJIPxnAfxk/MCHAMDeTiCE3FT
                    ; ADwBLBIaeI/n9zbP7Ec0Qpwv6+bD7+cltOITAKAjcwIcISIRIsHT8wA8ISKLmIAf5pXVb+kmRJKcD+
                    ; kGFHIcA/ChkwwSESwSEOo4ghnIjAf8ADNDCxiLSILxIDwP5iV1D+c1tOEsAOGR0SwiE/EjAdLAAAAA
                    ; AAAAAB
                    ; thumbnail end
                    https://github.com/n8bot/PrusaSlicer/commit/e087f3bf78d6822d36900bcd53b0a0df6d00b24d
                    0 n8bot committed to n8bot/PrusaSlicer
                    First try QOI
                    • botundefined
                      bot
                      Well, I was able to confirm that I can generate and output a QOI image to a file from prusaslicer. and I can confirm that when that file is converted to base64 encoding, the outputted string to gcode is identical. So, indirectly I confirm that the implementation works.
                      However, there still might be issues. It's a start.
                      Now, I have to integrated it only when RRF is selected.
                      • botundefined
                        bot @bot
                        The test image file seems to be upside down when I view it in this viewer I got from some random GH repo. I have done nothing that seems like it would influence the upside-downness of the image, so I think that might just be a problem with the image viewer. In any case, it would be easy to flip the image if needed.
                        • resamundefined
                          resam @bot
                          @bot I think my first try also had it flipped in Y. The PNG encoder used in PrusaSlicer has a flip parameter that was active, so I'm pretty sure that QOI just expects its pixel data the other way around.
                          From your base64 sample posted above, unfortunately I have to report that the qoiconv tool just produces visual gibberish when converting to PNG.
                          • botundefined
                            bot @resam
                            @resam did you decode it from base64 first?
                            • resamundefined
                              resam @bot
                              @bot of course! It seems to be valid QOI with 32x32 pixels, just that the color data doesn't resemble a meaning 3D model... unless that is intended for your test?
                              • botundefined
                                bot @resam
                                @resam Hmmm no that is not intended at all. But actually that output was from an older test. Can you try this?
                                ; generated by PrusaSlicer 2.4.0+n8 on 2022-01-02 at 08:52:13 UTC
                                ; QOI thumbnail begin 64x64 1496
                                ; cW9pZgAAAEAAAABABAAAwv9QUFB//6Ghof//jY2N3yUA7v88PDxg/6Ghof8Y/ygoKEAAx/8UFBQg/3
                                ; l5eb8kJQDT/xkNByD/lFErv/+SUCrf/xULBiD/AAAAANL/FBQUIP95eXm/JAz/FBQUIADJDCUk/42N
                                ; jd//KCgoQADQ/2M2HH//xmw5/8D+p1wwAf9TLhh/ANAYJMAlAM0M/42Njd/AJQDNHTMywQbBAf8VCw
                                ; Yg/wAAAADNJSQY/ygoKEAAzwwlJP+NjY3fDADK/zEbDkAywwbCAf9TLhh/AMoM/3l5eb8k/2VlZZ//
                                ; AAAAANP/KCgoQP+NjY3fwCUAyDAyxAbEPADIJSQY/ygoKEAA1f8UFBQgJST/eXl5v/8UFBQgAMQd/6
                                ; 1eMt8yxQbFAf8qFwxAAMQM/3l5eb8kDADZJST/jY2N3yUAwjAyxwbGATwAwv8oKChAJMAlANv/FBQU
                                ; IP+NjY3fJCUAHTMyyAbIAf8VCwYg/wAAAAAlJBj/KCgoQADdDCUk/5t5Zt8yygbJAf6QalQkJQDgHT
                                ; MyywbL/3xOMr8A4P8xGw5AMs0GzAH/PyISYADdMDLOBs7/Uy4YfwDaHTMyzwbPAf8VCwYg/wAAAADX
                                ; MDLRBtABPADUHTMy0gbS/31FJL//FQsGIP8AAAAA0f8xGw5AMtQG0/+SUCrf/1MuGH8AzzAy1QbVPA
                                ; DMHRAy1gbWAf8VCwYg/wAAAADKEDLXBtcBAMoQMtcG1wEAyhAy1wbXAQDKEDLXBtcBAMoQMtcG1wEA
                                ; yhAy1wbXAQDKEDLXBtcBAMoQMtZ+/qxfMQbWAQDKEDLVoZiklp1pmCwG1QEAyhAy1KKXNcIbBtQBAM
                                ; oQMtI6o6g1xAkrBtIBAMoQMtEMNccJGwbRAQDKEDLPOqOXNcoJKwbPAQDKEDLOBDXNCRsGzgEAyhAy
                                ; zDqimDXQlQ0GzQEAyhAyywQtNdIJ/rBhMwbLAQDKEDLKDDXVCRsGygEAyRj/wXNG/zLIOiM12AkrBs
                                ; gBJQDHJSQhMscMNdsJGwbH/qZlPiQlAMT/FBQUIP+NjY3fJCUQMsU6IzXemzorBsUSJSQYDADBJSQY
                                ; /ygoKEAAEDLEBDXhCRsGxAEADP+NjY3fwCUA/3l5eb8kDADBEDLDopc15BsGwwEAwP8UFBQgJSQYJP
                                ; 88PDxgAMIQMsE6IzXmCSsGwQEAwiX/oaGh/wwAwxAywKKXNekJGwbAAQDD/xQUFCAAxBA6IzXsCSsB
                                ; AMr/r2Az3zXvCf+lWzDfAMr/Gg4HIP+zYzTfNe4J/zMcD0AAyyX/ZjgefzXs/4BHJZ8Azw4JNegJDg
                                ; DRJRE15v+aVS2/ANURNeQRANclCTXgCQ4A2SURNd4RAN0lCTXaCQ4A3yURNdgnAOMRNdYRAOUlJzXS
                                ; CSUA5yURNdARAOslCTXMCQ4A7SURNco7APH/TSoWYDXHCQ4A8yU7NcQnAPcRNcIRAPklCcAOAPslAN
                                ; 4AAAAAAAAAAQ==
                                ; thumbnail end
                                • resamundefined
                                  resam @bot
                                  @bot that one is producing a completely empty 32x32 PNG...
                                  I have to mention though: I don't fully trust the QOI toolchain either 😏
                                  But the converter tool is from the "official" specification repo, so 🤷
                                  • botundefined
                                    bot @resam
                                    @resam I tend to believe what you are verifying. I've not been able to decode the base64 into what is a viewable QOI image... however, the file writing to qoi format works.
                                    Hmmm.. Thank you for the help. I have no idea what to try now lol.
                                    • resamundefined
                                      resam @bot
                                      @bot does PrusaSlicer give you RGBA data with 4 channels? or just 3?
                                      you seem to have it hardcoded to 4, but I don't see where you take this assumption from.
                                      • botundefined
                                        bot @resam
                                        @resam The image data is 4 channel, yes. The PNG contains full transparency in part of it.
                                        When I write a test QOI image from a thumbnail, the image is perfectly vieable in https://github.com/Tom94/tev
                                        So, the problem doesn't seem to be the pixels. It seems to be the base64 encoding?
                                        But also the last test might have been ruined by me trying to generate QOI only if RRF is selected.
                                        test111.txt rename to .qoi
                                        • botundefined
                                          bot
                                          I have verified that everything works as intended, albeit the thumbnail is upside down! lol. Not sure why that is.
                                          The branch has been updated to trigger QOI format only if RRF is selected as gcode flavor. Also, the thumbnail comment will indicate if it is QOI (but will remain unchanged if outputting PNG)
                                          https://github.com/n8bot/PrusaSlicer/tree/n8-240-qoitest
                                          ; generated by PrusaSlicer 2.4.0+n8 on 2022-01-02 at 09:00:33 UTC
                                          ; QOI thumbnail begin 128x128 3024
                                          ; cW9pZgAAAIAAAACABAAAx/8UFBQg/42Njd//oaGh//9QUFB/AP3mJSQY/ygoKEAA0QwlJP+NjY3fDA
                                          ; Du/xkNByCeaf8AAAAA7gz/eXl5vyQlANX/FBQUIBjAJQDs/0ooFWD/xmw5//+SUCrf/1MuGH8A7CUk
                                          ; GP8oKChAANcMJST/jY2N3wwA6B3/lFErvzLA/qdcMMD/aDkenwDpDP95eXm/JAwA2yUkGCUA5v8xGw
                                          ; 5AMsIGwQH/PyISYADm/ygoKEAkwCUA3f8UFBQg/3l5eb8kJQDk/2M2HH8ywwbD/1MuGH8A5CUk/42N
                                          ; jd//FBQUIADfDCUkGP8oKChAAOAdMzLEBsQB/xULBiD/AAAAAOAM/42Njd8kJQDjDBjAJQDeMDLGBs
                                          ; UBPADeJSQY/ygoKEAA5QwlJP+NjY3fDADaHTMyxwbH/31FJL//FQsGIP8AAAAA2gz/eXl5vyT/ZWVl
                                          ; n/8AAAAA6f88PDxg/6Ghof8YJQDY/zEbDkAyyQbI/5JQKt//Uy4YfwDY/zw8PGD/oaGh/xj/KCgoQA
                                          ; Dr/xQUFCD/eXl5vyT/ZWVln/8AAAAA1jAyygbKPADV/xQUFCD/eXl5vyQMAO7/FBQUICUk/42Njd//
                                          ; PDw8YADSHf+tXjLfMssGywH/FQsGIP8AAAAA0v8oKChA/6Ghof/AJQDxDP+NjY3fJCUA0DAyzQbMAT
                                          ; wA0CUkGP8oKChAAPMMJST/jY2N3wwAzB0zMs4GzgH/FQsGIP8AAAAAzAz/eXl5vyQlAPf/KCgoQP+N
                                          ; jY3fwCUAyhky0AbPATwAyiUkGP8oKChAAPn/FBQUICUk/3l5eb//FBQUIADGHTMy0QbRPADHDP95eX
                                          ; m/JAwA/SUk/42Njd8lAMT/MRsOQBAy0gbSAf8qFwxAAMT/KCgoQCTAJQD9wf8UFBQg/42Njd8kJQDC
                                          ; MDLUBtMB/1MuGH8AwiUkGAwA/cMMJSQYDB0zMtUG1QH/FQsGIAwYJCX/AAAAAP3HDBj+m3lmMtcG1g
                                          ; H/pH5o/xj/KCgoQAD9yB0zMtgG2P99RSS//xULBiD/AAAAAP3H/zEbDkAy2gbZ/5JQKt//Uy4YfwD9
                                          ; xTAy2wbbPAD9wh0QMtwG3AH/FQsGIP8AAAAA/TAy3gbdATwA+h0zMt8G3wH/FQsGIP8AAAAA9/8xGw
                                          ; 5AMuEG4AH/Uy4YfwD1/3xDJJ8y4gbiPADyHRAy4wbjAQUA7zAy5QbkATwA7B0zMuYG5gH/FQsGIP8A
                                          ; AAAA6Rky6AbnATwA5h0zMukG6f99RSS//xULBiD/AAAAAOP/MRsOQDLrBur/klAq3/8/IhJgAOEwMu
                                          ; wG7P9TLhh/AN4dMzLtBu0B/xULBiD/AAAAANswMu8G7gE8ANgdMzLwBvD/fUUkv/8VCwYg/wAAAADW
                                          ; MzLxBvEBANYzMvEG8QEA1jMy8QbxAQDWMzLxBvEBANYzMvEG8QEA1jMy8QbxAQDWMzLxBvEBANYzMv
                                          ; EG8QEA1jMy8QbxAQDWMzLxBvEBANYzMvEG8QEA1jMy8QbxAQDWMzLxBvEBANYzMvEG8QEA1jMy8Qbx
                                          ; AQDWMzLwopeYHAbwAQDWMzLufqOXoZjAGwbvAQDWMzLtoZijlzXCnWn+sGEzBu0BANYzMuwMNcUJGw
                                          ; bsAQDWMzLqOiM1yAn+rF8xBuoBANYzMukMNcsJGwbpAQDWMzLnOiM1zps6KwbnAQDWMzLmBDXRCRsG
                                          ; 5gEA1jMy5Qw11BsG5QEA1jMy4zotNdYJKwbjAQDWMzLiDDXZCRsG4gEA1jMy4DojNdwJKwbgAQDWMz
                                          ; LfBDXfCRsG3wEA1jMy3qOXNeKVDQbeAQDWMzLcOi015AkPBtwBANYzMtsMNecJGwbbAQDWMzLZOiM1
                                          ; 6gkrBtkBANYzMtgMNe0JGwbYAQDWMzLWOiM18CkrBtYBANYzMtUENfMJ/rVkNAbVAQDV/xQUFCD/qW
                                          ; U/3zLUopc19hsG1P+RWTjf/xQUFCAA0xgk/r15UzLSOiM1+AkrBtL+pW1M/42Njd8lANElJBgzMtGi
                                          ; lzX7CRsG0Q0YJCUAzv8UFBQgGCQlADMyzzojNf3AKSsGzwEMJSQY/ygoKEAAyyUk/42Njd//KCgoQA
                                          ; DAMzLOBDX9wwkbBs4BAMAM/42Njd/AJQDIDP95eXm/JP9lZWWf/wAAAADCMzLNopc1/cYbBs0BAMH/
                                          ; FBQUICUkGAwAxf88PDxg/6Ghof8Y/ygoKEAAwzMyyzotNf3ICQ8GywEAwyUk/42Njd8lAMIM/3l5eb
                                          ; 8kDADFMzLKopc1/csJGwbKAQDE/xQUFCD/eXl5vyT/ZWVln/8AAAAAwP8oKChAJMAlAMYzMsg6IzX9
                                          ; zgkrBsgBAMX/FBQUICUk/42Njd//KCgoQCT/jY2N3/8oKChAAMczMseilzX90QkbBscBAMf/FBQUIP
                                          ; +NjY3fJCUAyTMyxTojNf3UmCsGxgH/AAAAAMgMJQDKMzLEBDX91wkPBsQBANYzMsOilzX92QkbBsMB
                                          ; ANYzMsE6IzX93AkrBsEBANYzMsAMNf3fCRsGwAEA1jM6IzX94ikrAQDW/5ZSK781/eUJ/3dBIp8A1v
                                          ; 8aDgcg/2Y4Hn81/eT/mlUtvwDZETX94hEA2yX/s2M03zX93gn/MxwPQADdJRE1/dwRAOElCTX92AkO
                                          ; AOMlETX91icA5xE1/dQRAOklJzX90AklAOslETX9zhEA7yUJNf3KCQ4A8SURNf3I/4BHJZ8A9f9NKh
                                          ; ZgNf3FCQ4A9yUnNf3CJwD7ETX9wBEA/SUJNfoJDgD9wSURNfgRAP3FDgk19AkOAP3HJRE18icA/csR
                                          ; NfARAP3NJQk17AklAP3PJRE16hEA/dMlCTXmCQ4A/dUlETXkJwD92RE14QkzAP3bJSc13iclAP3dJR
                                          ; E13BEA/eElCTXYCQ4A/eMlETXWOwD95w4JNdIJDgD96SURNdAnAP3tETXOEQD97yUJNcoJDgD98SUR
                                          ; NcgRAP31JQk1xAkOAP33JRE1wicA/fsRNcARAP39JcAA/f39wwAAAAAAAAAB
                                          ; thumbnail end
                                          results in
                                          • botundefined
                                            bot @bot
                                            as @resam pointed out to me, PrusaSlicer itself has to flip its pixels while encoding to PNG. I tried reversing the vector of pixels using std::reverse but that is not working.
                                            So... for now the thumbnails are upside down! Lol. Sorry dc42.
                                            @dc42 Here is a build of PrusaSlicer-n8 2.4.0 with the QOI image format enabled for RRF firmware, and upside-down thumbnail generation.
                                            I've created an issue with QOI GH repo to ask/mention the idea of a flip image function on encode, so we can easily get our thumbnails the right way around!
                                            Link to Win64 binary release: https://github.com/n8bot/PrusaSlicer/releases/download/version_2.4.0-release1-n8/PrusaSlicer-n8-2.4.0-QOIforRRFtest1-Win64.zip
