    No tools are showing in DWC - noob
    Duet Web Control
    1.5k
      M563 P0 S"extruder 0 (model)" D0 H0 F-1 ; define tool 0
      M563 P1 S"extruder 1 (support)" D1 H1 F-1 ; define tool 1
      Can you try mofifying your tool definition to look like
      M563 P0 S"extruder0" D0 H0 ; define tool 0
      M563 P1 S"extruder1" D1 H1 ; define tool 1
      Can you also check the settings tab in DWC and verify the version matches 3.3
      Nvigr8undefined 3 Replies Last reply Reply Quote 0
      • Nvigr8undefined
        Nvigr8 @Phaedrux
        @phaedrux I didn't see a settings tab but these are from elsewhere in DWC:
        Modified Multoo MT1.5, Modified Creality CR6SE, Modified Monoprice Mini Delta, Modified Wanhao Di3, Phrozen Shuffle
        • Nvigr8undefined
          Nvigr8 @Phaedrux
          @phaedrux Ok made the changes to the tool section and now they are showing up in DWC and on the PanelDue. Thank you very much!
          However when I touch the heater 1 icon I get : Error Temperature reading fault on heater 1: sensor open circuit
          I double checked the wiring and the thermistors are connected to E0 temp and E1 temp.
          One thing to note and I'm not certain this is an issue, I have a breakout board on the extruder body for all the wiring so that I can just plug one 25pin plug into it to swap out extruders. I've double checked the wiring to make sure everything is going where it should.
          Thanks again for your help on this!
          • Nvigr8undefined
            Nvigr8 @Phaedrux
            @phaedrux Odd, its now showing two extruders in tool 1 with two heaters and a third heater in tool 2.
              Phaedrux Moderator @Nvigr8
              @nvigr8 said in No tools are showing in DWC - noob:
              Do you have a wiring diagram for this board?
              I would suggest testing the wiring direct to remove the breakout board from the equation. It may be sharing a negative ground connection that the duet uses to switch the heater.
              Nvigr8undefined 2 Replies Last reply Reply Quote 0
              • Nvigr8undefined
                Nvigr8 @Phaedrux
                @phaedrux To what do I set the active and standby temps? Would you please explain them?
                I wired in an extra thermistor directly to the board and did not get the error this time. It reads a normal temp on DWC but on the PanelDue it still reads a crazy number. Also even though I don't have a heated bed in the configuration, it shows one on the Panel Due.
                I'll have to draw a diagram for you tonight or tomorrow. I would really like to be able to use this breakout board setup. I have three different extruder assemblies that I will be switching between and it will make the switch so much easier.
                Thanks for your help.
                  You probably need to update your paneldue firmware
                  https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update
                  Normally they would be set by your slicer.
                  Nvigr8undefined 1 Reply Last reply Reply Quote 0
                  • Nvigr8undefined
                    Nvigr8 @Phaedrux
                    @phaedrux This is the breakout board that I'm using:
                    link text
                    Here is a diagram:
                    Note: This assembly does not thave E1 and accessories. Connections are there for another two extruder assembly.
                    Here is the corresponding plug pins:
                    Pic of the whole assembly:
                    One thing that just occured to me, does soldering thermistor wires cause problems?
                    • Nvigr8undefined
                      Nvigr8 @Phaedrux
                      @phaedrux Do you know what the SH terminal on that breakout board is for?
                      Also, after doing some reading, it looks like I should have checked the resistance on the wires I used to connect the thermistors... Maybe that is part of the issue. Tonight I'll replace those cables with thermistor cables and crimp them onto the plug pin instead of soldering.
                      • Stephen6309undefined
                        Stephen6309 @Nvigr8
                        @nvigr8 Change the S1 to S0 in your M574.
                        • Nvigr8undefined
                          Nvigr8 @Stephen6309
                          @stephen6309 Thank you for the input. Last night I finally got the X and Y endstops and movement working properly.
                          However, now the Z endstop shows as being on even though the BLtouch has not been triggered. Not sure what I changed to make this happen.
                          Stephen6309undefined 1 Reply Last reply Reply Quote 0
                            Stephen6309 @Nvigr8
                            @nvigr8 Add a ! to the pin that should fix it. For example: M558 P9 C"!^zprobe.in" H5 F120 T6000
                            • Nvigr8undefined
                              Nvigr8 @Stephen6309
                              @stephen6309 Which .g file would that be in? Thanks.
                              • Nvigr8undefined
                                Nvigr8 @Stephen6309
                                @stephen6309 NM, I found it. Thanks! I'll try it out at lunch.
                                  Stephen6309 @Nvigr8
                                  @nvigr8 config.g You just need to edit the one in there already.
                                  • Nvigr8undefined
                                    Nvigr8 @Stephen6309
                                    @stephen6309 What does that ! do there to make it work?
                                      Stephen6309 @Nvigr8
                                      @nvigr8 The ! inverts the signal from the pin.
                                      • Nvigr8undefined
                                        Nvigr8 @Stephen6309
                                        @stephen6309 Ah, good to know. Thank you.
                                        • Nvigr8undefined
                                          Nvigr8 @Stephen6309
                                          @stephen6309 Thanks again for the help. However, when I first made this post and put in the config.g it WAS working. It was the ONLY axis working at the time. In trying to fix other problems - tools, thermistors, etc. I must have changed something to make it not work. That line you referenced earlier apparently didn't change though.
                                          I just wanted to give a little more context. I will still try your suggestion when I go home for lunch.
                                          ; Configuration file for Duet WiFi (firmware version 3.3)
                                          ; generated by RepRapFirmware Configuration Tool v3.3.10 on Wed Jan 05 2022 21:06:25 GMT-0600 (Central Standard Time)
                                          M575 P1 S1 B57600                                      ; enable support for PanelDue
                                          G90                                                    ; send absolute coordinates...
                                          M83                                                    ; ...but relative extruder moves
                                          M550 P"Multoo"                                         ; set printer name
                                          M552 S1                                                ; enable network
                                          M586 P0 S1                                             ; enable HTTP
                                          M586 P1 S0                                             ; disable FTP
                                          M586 P2 S0                                             ; disable Telnet
                                          M569 P0 S0                                             ; physical drive 0 goes backwards
                                          M569 P1 S0                                             ; physical drive 1 goes backwards
                                          M569 P2 S1                                             ; physical drive 2 goes forwards
                                          M569 P3 S1                                             ; physical drive 3 goes forwards
                                          M569 P4 S1                                             ; physical drive 4 goes forwards
                                          M584 X0 Y1 Z2 E3:4                                     ; set drive mapping
                                          M350 X16 Y16 Z16 E16:16 I1                             ; configure microstepping with interpolation
                                          M92 X80.00 Y80.00 Z400.00 E400.00:400.00               ; set steps per mm
                                          M566 X900.00 Y900.00 Z60.00 E120.00:120.00             ; set maximum instantaneous speed changes (mm/min)
                                          M203 X6000.00 Y6000.00 Z180.00 E2100.00:2100.00        ; set maximum speeds (mm/min)
                                          M201 X500.00 Y500.00 Z20.00 E250.00:250.00             ; set accelerations (mm/s^2)
                                          M906 X1300 Y1300 Z1300 E450:450 I30                    ; set motor currents (mA) and motor idle factor in per cent
                                          M84 S30                                                ; Set idle timeout
                                          M208 X0 Y0 Z0 S1                                       ; set axis minima
                                          M208 X420 Y410 Z470 S0                                 ; set axis maxima
                                          M574 X1 S1 P"!xstop"                                   ; configure switch-type (e.g. microswitch) endstop for low end on X via pin !xstop
                                          M574 Y1 S1 P"!ystop"                                   ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin !ystop
                                          M574 Z2 S2                                             ; configure Z-probe endstop for high end on Z
                                          M950 S0 C"exp.heater3"                                 ; create servo pin 0 for BLTouch
                                          M558 P9 C"^zprobe.in" H5 F120 T6000                    ; set Z probe type to bltouch and the dive height + speeds
                                          M558 H30                                               ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
                                          G31 P500 X-32.69 Y-31.88 Z2.5                          ; set Z probe trigger value, offset and trigger height
                                          M557 X15:215 Y15:195 S20                               ; define mesh grid
                                          M308 S0 P"bedtemp" Y"thermistor" T100000 B3950         ; configure sensor 0 as thermistor on pin bedtemp
                                          M950 H0 C"bedheat" T0                                  ; create bed heater output on bedheat and map it to sensor 0
                                          M307 H0 B1 S1.00                                       ; enable bang-bang mode for the bed heater and set PWM limit
                                          M140 H0                                                ; map heated bed to heater 0
                                          M143 H0 S120                                           ; set temperature limit for heater 0 to 120C
                                          M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
                                          M950 H1 C"e0heat" T1                                   ; create nozzle heater output on e0heat and map it to sensor 1
                                          M307 H1 B0 S1.00                                       ; disable bang-bang mode for heater  and set PWM limit
                                          M143 H1 S295                                           ; set temperature limit for heater 1 to 295C
                                          M308 S2 P"e1temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 2 as thermistor on pin e1temp
                                          M950 H2 C"e1heat" T2                                   ; create nozzle heater output on e1heat and map it to sensor 2
                                          M307 H2 B0 S1.00                                       ; disable bang-bang mode for heater  and set PWM limit
                                          M143 H2 S295                                           ; set temperature limit for heater 2 to 295C
                                          M950 F0 C"fan0" Q500                                   ; create fan 0 on pin fan0 and set its frequency
                                          M106 P0 S0 H-1                                         ; set fan 0 value. Thermostatic control is turned off
                                          M950 F1 C"fan1" Q500                                   ; create fan 1 on pin fan1 and set its frequency
                                          M106 P1 S1 H1:2 T45                                    ; set fan 1 value. Thermostatic control is turned on
                                          M563 P0 D0 H1 F0                                       ; define tool 0
                                          G10 P0 X0 Y0 Z0                                        ; set tool 0 axis offsets
                                          G10 P0 R0 S0                                           ; set initial tool 0 active and standby temperatures to 0C
                                          M563 P1 D1 H2 F0                                       ; define tool 1
                                          ; Custom settings
                                          ; add for filament sensors
                                          M591 P1 C"e0stop" S1 D0                                ;filament monitor connected to E0 endstop
                                          M591 P1 C"e1stop" S1 D1                                ;filament monitor connected to E1 endstop
                                          M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"     ; set voltage thresholds and actions to run on power loss
                                          T0                                                     ; select first tool
                                          • Nvigr8undefined
                                            Nvigr8 @Stephen6309
                                            @stephen6309 Ok, I'm at home and I added that !. Now M119 shows the Z is not stopped.
                                            Next problem is that when I home the Z axis, the probe deploys but when pushed in, it does not register as a stop. Ideas?
