    Duet 3 Mini 5+ Short to Ground Error
    546
      Phaedrux Moderator @3DMakerKid
      @3dmakerkid said in Duet 3 Mini 5+ Short to Ground Error:
      I have heard that there was an issue with a revision of the board awhile back with this issue, so I'm not sure if maybe my board was a part of that batch?
      I think you may be referring to the Duet3 6HC which had a batch of bad diodes, but I don't think that affected the mini.
      Are you using stealthchop?
      Can you send M122 and share the result?
      Often accompanied by this error is the X or Y axis refusing to move and making an intermittent ticking sound (X is plugged into driver 0 and Y to drive 1).
      I assume you've checked out all the wiring?
      3DMakerKidundefined 1 Reply Last reply Reply Quote 0
      • 3DMakerKidundefined
        3DMakerKid @Phaedrux
        @phaedrux I am using stealthchop, M122 result:
        RepRapFirmware for Duet 3 Mini 5+ version 3.3 (2021-06-15 21:46:11) running on Duet 3 Mini5plus WiFi (standalone mode)
        Board ID: WB4NT-F096U-D65J0-40KM2-0Q03Z-ZJYMR
        Used output buffers: 3 of 40 (36 max)
        Static ram: 102724
        Dynamic ram: 106092 of which 12 recycled
        Never used RAM 34876, free system stack 204 words
        Tasks: NETWORK(ready,15.0%,264) HEAT(delaying,0.0%,366) Move(notifyWait,0.1%,362) CanReceiv(notifyWait,0.0%,941) CanSender(notifyWait,0.0%,371) CanClock(delaying,0.0%,340) TMC(notifyWait,0.6%,115) MAIN(running,82.7%,426) IDLE(ready,0.7%,29) AIN(delaying,0.8%,274), total 100.0%
        Owned mutexes: WiFi(NETWORK)
        Last reset 00:00:37 ago, cause: power up
        Last software reset at 2022-01-06 21:02, reason: User, GCodes spinning, available RAM 31628, slot 0
        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
        Error status: 0x00
        MCU revision 3, ADC conversions started 37895, completed 37895, timed out 0, errs 0
        Step timer max interval 1480
        MCU temperature: min 15.6, current 20.2, max 20.4
        Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
        Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 10, reads 1959, writes 10, timeouts 0, DMA errors 0
        Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 1959, writes 9, timeouts 0, DMA errors 0
        Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 1959, writes 9, timeouts 0, DMA errors 0
        Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 1959, writes 9, timeouts 0, DMA errors 0
        Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 10, reads 1958, writes 10, timeouts 0, DMA errors 0
        Driver 5: position 0, assumed not present
        Driver 6: position 0, assumed not present
        Date/time: 2022-01-07 17:26:56
        Cache data hit count 72624651
        Slowest loop: 6.64ms; fastest: 0.12ms
        === Storage ===
        Free file entries: 10
        SD card longest read time 3.8ms, write time 0.0ms, max retries 0
        === MainDDARing ===
        === AuxDDARing ===
        Bed heaters = 0 -1, chamberHeaters = -1 -1
        Segments left: 0
        Movement lock held by null
        HTTP is idle in state(s) 0
        Telnet is idle in state(s) 0
        File is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Trigger is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        SBC is idle in state(s) 0
        Daemon is idle in state(s) 0
        Aux2 is idle in state(s) 0
        Code queue is empty.
        === CAN ===
        Messages queued 338, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17), ts 189/0/0
        Tx timeouts 0,0,188,0,0,148 last cancelled message type 4514 dest 127
        === Network ===
        Slowest loop: 27.87ms; fastest: 0.00ms
        HTTP sessions: 1 of 8
        - WiFi -
        Network state is active
        WiFi firmware version 1.26
        WiFi MAC address f0:08:d1:02:e6:60
        WiFi Vcc 3.40, reset reason Power up
        WiFi flash size 2097152, free heap 24672
        WiFi IP address 192.168.86.30
        WiFi signal strength -47dBm, mode 802.11n, reconnections 0, sleep mode modem
        Clock register 00002002
        Socket states: 0 2 0 0 0 0 0 0```
        I have checked over wiring and even replaced motors several times.
          Post config?
            @phaedrux Apologies
            ; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed Jun 30 2021 18:28:51 GMT-0400 (Eastern Daylight Time)
            G90                                          ; send absolute coordinates...
            M83                                          ; ...but relative extruder moves
            M550 P"Hermione"                   ; set printer name
            M552 S1                                      ; enable network
            M586 P0 S1                                   ; enable HTTP
            M586 P1 S0                                   ; disable FTP
            M586 P2 S0                                   ; disable Telnet
            M587 I192.168.86.24
            M569 P0.0 S1 D3 V0                                 ; physical drive 0.0 goes forwards
            M569 P0.1 S0 D3 V0                                ; physical drive 0.1 goes forwards
            M569 P0.2 S0 D3 V0                                ; physical drive 0.2 goes forwards
            M569 P0.3 S0                                 ; physical drive 0.3 goes forwards
            M569 P0.4 S0 D3 V0
            M584 X0 Y1 Z2:4 E3                           ; two Z motors connected to driver outputs Z and E1
            M350 X16 Y16 Z16 E16 I1                      ; configure microstepping with interpolation
            M92 X100.00 Y100.00 Z400.00 E409.00         ; set steps per mm
            M566 X900.00 Y900.00 Z60.00 E120.00          ; set maximum instantaneous speed changes (mm/min)
            M203 X15000.00 Y15000.00 Z300.00 E1200.00      ; set maximum speeds (mm/min)
            M201 X4000.00 Y4000.00 Z120.00 E250.00          ; set accelerations (mm/s^2)
            M906 X800 Y800 Z400 E600 I30                 ; set motor currents (mA) and motor idle factor in per cent
            M84 X Y E0 S30                                      ; Set idle timeout
            M671 X-10:240 Y0:0 S3 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
            M208 X0 Y0 Z0 S1                             ; set axis minima
            M208 X240 Y205 Z210 S0                       ; set axis maxima
            M574 X1 S3                                   ; configure sensorless endstop for low end on X
            M574 Y1 S3                                   ; configure sensorless endstop for low end on Y
            M558 P5 C"^io2.out" H2 F600 T6000 A3             				; Prusa PindaV2 Endstop
            M308 S2 P"temp2" A"Pinda V2" Y"thermistor" T100000 B3950      		; Prusa PindaV2 Thermistor
            G31 P1000 X-35.75 Y-18.7 Z.68                                  				; Nozzle offset
            M574 Z1 S2                                                 			; Set Z axis endstop, controlled by probe
            M557 X0:180 Y0:180 P3                                    			; Define mesh grid for probing
            M376 H2																; Fade height 5mm
            M564 S0 ;
            M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
            M950 H0 C"out0" T0                           ; create bed heater output on out0 and map it to sensor 0
            M307 H0 B0 S1.00                             ; enable bang-bang mode for the bed heater and set PWM limit
            M140 H0                                      ; map heated bed to heater 0
            M143 H0 S120								 ; set temperature limit for heater 0 to 120C
             M307 H0 B0 R0.274 C426.1 D11.33 S1.00 V24.0   ; control parameters for H0
            M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
            M950 H1 C"out1" T1                           ; create nozzle heater output on out1 and map it to sensor 1
            M307 H1 B0 R2.203 C200.0:140.4 D5.77 S1.00 V24.1                             ; disable bang-bang mode for heater  and set PWM limit
            M143 H1 S280                                 ; set temperature limit for heater 1 to 280C
            M950 F0 C"out5" Q500 ;
            M106 P0 C"Part Cooling" S0 H-1 ;
            M950 F1 C"out6" Q500 ;
            M106 P1 C"Hotend" S1 H1 T45 ;
            M563 P0 D0 H1 F0                           ; define tool 0
            G10 P0 X0 Y0 Z0                              ; set tool 0 axis offsets
            G10 P0 R0 S0                                 ; set initial tool 0 active and standby temperatures to 0C
            ; Custom settings are not defined```
              I think it may be related to stealthchop. Can you test with spreadcycle for a while?
                @phaedrux Yes, I can.
                  3DMakerKid @3DMakerKid
                  @3dmakerkid actually, Does sensorless homing require stealthchop to be on? I can't seem to recall
                    I think stallguard works with stealthchop, but I don't think you need stallguard configured to use stealthchop.
                    Additionally, the TMC2209 stepper driver used in Duet 3 Mini 5+ (and Duet 3 Tool board TOOL1LC once stallGuard is implemented in firmware), features stallGuard 4. This is optimised for operation with stealthChop, while its predecessor stallGuard 2 (TMC5160 and TMC2260) works with spreadCycle. You will need to adjust the speed at which stealthChop changes over to spreadCycle. This is set by M569 V parameter. The default is 2000.
                    https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing
                      @phaedrux Ok, I'm using sensorless homing on this printer and it looks like it can't be used with spreadcycle, as I found out here https://teamgloomy.github.io/sensorless.html .
                        Well you'd switch between as needed I guess.
                        Stealthchop isn't really recommended for printing unless you're limiting your speed and acceleration due to the loss of torque in exchange for absolute quiet.
                          @phaedrux It's now doing the same thing as before except just when the machine is powered on instead of after a print, and I changed nothing. So I'm not sure how much switching stealthchop off is going to help in this case.
                            As we can't rule out whether there is an error with the stepper or not, we will replace the board under warranty.
                            Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
                              3DMakerKid
                              @phaedrux You guys are awesome, I'll get that done as soon as I can!
