12864 command M701 S"nnn"
463
    demonlibra
    Good day.
    Is it possible to add command M701 S"ABS" to menu.
    Tryed to write command:
    button R20 C2 T"LOAD ABS" A"M701 S#0" L"ABS"
    but nothing happened.
      Perhaps it doesn't like the S#0?
        demonlibra
        The command must be
        M701 S"ABS"
        but in configuration menu file I cannot write like this
        button R20 C2 T"LOAD ABS" A"M701 S"ABS""
        Doudble double quote will not working correctly.
        How to write this command correctly?
        undefined 1 Reply Last reply 7 Jan 2022, 19:57 Reply Quote 0
          dc42 administrators @demonlibra
          @demonlibra try this:
          button R20 C2 T"LOAD ABS" A"M701 S""ABS"""
            demonlibra
            The line can be selected, but no characters are displayed.
            The filament load command does not start.
            undefined 1 Reply Last reply 9 Jan 2022, 22:21 Reply Quote 0
              Phaedrux Moderator @demonlibra
              @demonlibra said in 12864 command M701 S"nnn":
              A"M701
              Is this missing a " ?
              undefined 1 Reply Last reply 10 Jan 2022, 18:32 Reply Quote 0
                demonlibra @Phaedrux
                @Phaedrux
                Sorry, I dont understand
                undefined 1 Reply Last reply 10 Jan 2022, 18:50 Reply Quote 0
                  @demonlibra Nevermind, I misstook the command.
                  I'm not sure what the problem would be.
                  undefined 1 Reply Last reply 11 Jan 2022, 13:27 Reply Quote 0
                    @phaedrux To use command M701 we must put in double quote name of the filament.
                    But to write line in menu we must put in double quote whole command.
                    Double double quote did not working.
                    Sorry for my english.
                      rjenkinsgb
                      How about making a macro file containing the command, then just call the macro with the button line?
                      Robert J.
                      Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
                      undefined 1 Reply Last reply 11 Jan 2022, 14:55 Reply Quote 1
                        demonlibra @rjenkinsgb
                        @rjenkinsgb I am already thinking about it.
                        I will use this option if I don’t find another solution.
                          demonlibra
                          created folder "/menu/filaments"
                          created files pla, abs, petg with content
                          M701 S"PLA"
                          M701 S"ABS"
                          Working fine.
