    Heaters will not turn on
    Using Duet Controllers
    1.4k
    • kvi94undefined
      kvi94 @kvi94
      I tried my part cooling fan on out4, out5 and out6, it does not work.
      Is there a way to perform a built-in self test?
      Thank you.
      kvi94undefined 1 Reply Last reply Reply Quote 0
      • kvi94undefined
        kvi94 @kvi94
        @T3P3Tony @dc42 please help me! Is there anything I can do to test whether the mosfet driver is causing this issue?
        I have powered this board 4-5 months back, before that it sat in the antistatic bag and box while I was assembling my printer. I was at the calibration stage of my build, so I have not even got the chance to use the board properly to print something.
        Thank you.
          dc42 administrators @kvi94
          @kvi94 how did you have the buck converter connected? Th 18.8V minimum supply voltage is suspicious.
          Your M307 parameters in config.g are different for heaters 0 and 1, yet the expected rate of temperature rise reported in the error messages are the same. That doesn't look right, so I think something is going wrong with the configuration. Here are two things you can do to check:
          1. Send the following commands and check that the values reported are the same as you set in config.g:
          M950 H0
          M307 H0
          M950 H1
          M307 H1
          1. Send this command:
          M98 P"config.g"
          and see if any error messages result.
          The chips that drives the heater 0 and heater 1 mosfet are the 74HCT365 or 74HCT367 chips labelled U8 and U9. I advise against trying to measure voltages on those chips, because if you short pins together then you are likely to feed 5V into the microcontroller. You can measure the gate drive voltage to the mosfets on resistors R115 (for OUT0) and R40 (for OUT1). These resistors are close to the respective mosfets. You can measure the input voltages to the buffer ICs on R53 (for OUT0) and R57 (for OUT1).
          • kvi94undefined
            kvi94 @dc42
            @dc42 the buck converter was connected on the same line that feeds the duet board. Since I removed it, I now get 23.8V minimum. I will wire it on spare port of my PSU.
            @dc42 said in Heaters will not turn on:
            M950 H0
            M307 H0
            M950 H1
            M307 H1
            Send this command:
            M98 P"config.g"
            Can I do this while the board is powered via USB? I disconnected the board to inspect for any physical damage, but i see none.
            Yes, I went through the schematics and located the 2 74HCT365 drivers on the board. Can I measured the required pins while powered via USB? or should it be powered by 24V?
            And regarding the expected temperature rise, it is not constant every time I tried. At times it is 1.7deg, 1.3deg or 0.3deg.
            Additionally, I want to confirm when does the LED next to out0-out3 turns on? Because whenever I set the heater active with a temperature the LED are off.
            Thank you.
              @kvi94 as I said before, do not try to measure the voltages on the pins of those chips. Measure them on the resistors instead. You can use USB power, but expect the 5V rail voltage to be a little low, perhaps 4.5V.
              kvi94undefined 2 Replies Last reply Reply Quote 0
              • kvi94undefined
                kvi94 @dc42
                @dc42 sure, I will locate the resistors and confirm with you in a while.
                Thank you.
                • kvi94undefined
                  kvi94 @dc42
                  @dc42 please find below the output for M950 and M307 commands
                  M950 H0
                  Heater 0 pin out0 frequency 250Hz, sensor 0
                  M307 H0
                  Heater 0 model: heating rate 0.593, cooling time constant 389.7, dead time 3.93, max PWM 1.00, calibration voltage 0.0, mode PID
                  Computed PID parameters: setpoint change: P76.6, I1.957, D210.7, load change: P76.6, I5.418, D210.7
                  M950 H1
                  Heater 1 pin out1 frequency 250Hz, sensor 1
                  M307 H1
                  Heater 1 model: heating rate 1.680, cooling time constant 233.0/193.0, dead time 6.75, max PWM 1.00, calibration voltage 23.7, mode PID
                  Computed PID parameters: setpoint change: P15.7, I0.397, D74.4, load change: P15.7, I0.865, D74.4
                  The PID parameters are the same as in my config.g for H0 and H1.
                  Below is output for M98
                  M98 P"config.g"
                  HTTP is enabled on port 80
                  FTP is disabled
                  TELNET is disabled
                  • kvi94undefined
                    kvi94 @kvi94
                    @dc42 please find below pictures for R115, R40 and R57. Is R53 located next to temp3 pin by chance?
                    I have put 3 coloured dots on the mosfet pins for R115 and R40, if you do not mind could you please tell me explicitly where to measure the required voltage. It is my first time doing this at this scale, I really do not want to mess up things since this situation is already stressing me out.
                    Regarding R57, should I measure across the 2 terminals of the resistor itself?
                    Thank you.
                    R115
                    R40
                    R57
                      Does that chip next to R57 have a pock mark on it or is that just an artifact of the camera?
                      • kvi94undefined
                        kvi94 @Phaedrux
                        @phaedrux Thanks for pointing this out, I guess it comes with experience. I just had a look at it, there is something but I cannot say if it is a pock mark or a bulged. I will take a look at it tomorrow under daylight and post pictures.
                        Thank you.
                        • kvi94undefined
                          kvi94 @kvi94
                          @dc42 please take a look at the close up pictures of the 74HCT365 chip. Can this be the cause for the fault?
                          Could you please guide me where to place the test leads to measure voltage for R115, R40, R53 and R57. I posted location pictures for the components in my previous post.
                          Thank you.
                          20220111_160429.jpg 20220111_160335.jpg 20220111_160323.jpg 20220111_160317.jpg 20220111_160245.jpg 20220111_160232.jpg 20220111_160220.jpg 20220111_155816.jpg
                            @kvi94 those pock marks look suspicious to me. I've Just examined three MB6HC boards, and on those boards I can read the figure 3 clearly at that location on the chip.
                            To measure the voltage that the driver is feeding to the mosfet, measure between one end of the mosfet gate resistor (e.g. R115) and ground.
                            • kvi94undefined
                              kvi94 @dc42
                              @dc42 As I will be doing this while it is powered via USB, using the input GND terminal is fine? Additionally, should I set the port active with a temperature and measure or measure at idle?
                                @kvi94 yes you can use the VIN ground terminal, or the middle pin of any of the IO connectors.
                                • kvi94undefined
                                  kvi94 @dc42
                                  @dc42 Please find below the voltage of the resistors when both output are off.
                                  R40 = 0.001V
                                  R115 = 0.025V
                                  R53 = 0.032V
                                  R57 = 0.001V
                                  • kvi94undefined
                                    kvi94 @kvi94
                                    @dc42 I managed to measure the voltage when the heaters are in active state by the firmware, the reading are as follows:
                                    R40 = 0.001V
                                    R115 = 0.025V
                                    R53 = 0.585V
                                    R57 = 0.004V
                                    • kvi94undefined
                                      kvi94 @kvi94
                                      @dc42 did you manage to take a look at the values? What does it suggest?
                                      Thank you.
                                        @kvi94 if you are sure that the heaters were on when you took the measurements and had not yet faulted, then it looks like those drivers have failed. Please email warranty@duet3d.com with a link to this thread.
                                        • kvi94undefined
                                          kvi94 @dc42
                                          @dc42 I had someone to keep an eye on DWC for any fault while I took the measurements, so I am pretty confident they had not faulted.
                                          Alright, I will get this done.
                                          Thank you.
