    Baby stepping steps back.
    594
    • jens55undefined
      jens55
      @johnmaundrell, just a quick thought on this - what is your minimum Z limit? Are you trying to go below that limit? This is what I have in my config.g (note the Z -0.5 part)
      M208 X8 Y5 Z-0.5 S1
      johnmaundrellundefined 2 Replies Last reply Reply Quote 1
      • gnydickundefined
        gnydick @johnmaundrell
        @johnmaundrell I reported this year's ago and even provided a video. Deny deny deny...
        1 Reply Last reply Reply Quote -2
        • fcwiltundefined
          fcwilt @johnmaundrell
          @johnmaundrell
          Are you trying to step past the Z min setting?
          • johnmaundrellundefined
            johnmaundrell @jens55
            @jens55 I dont really understand how the minimum Z value is noted in the code or the relationship between trigger height and minimum Z height. If you could explain this it would help many thanks.
              @jens55 My M208 X0 Y0 Z0 S1
                jay_s_uk @johnmaundrell
                @johnmaundrell RRF doesn't let you go outside the machine limits. So when you babystep lower than Z0, because your lower Z limit is 0, it won't go any further. Setting it to Z-1 allows you to go below 0
                johnmaundrellundefined 1 Reply Last reply Reply Quote 0
                  johnmaundrell @jay_s_uk
                  @jay_s_uk Ok thanks understand that. Can you tell me which command sets the actual trigger height please.
                    @johnmaundrell G31 in your config.
                    There is a process for calibrating the trigger height
                    https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
                      @jay_s_uk I have tried this set up but it appears that after I set it all up it fails to save the data and then reverts back to the original setting. I can also only set it up in the homed position not in the centre of the bed.
                      johnmaundrellundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                        johnmaundrell @johnmaundrell
                        @johnmaundrell M564 S0 dosent disable the axis position
                          @johnmaundrell you need to save the probe offset yourself. config.g is never changed unless you're the one doing the change.
                            @johnmaundrell I have to go out now but I will try again this evening thanks everyone so far for your help. I will gradually get a better understanding with your help. G31 is a good start.
                              @johnmaundrell Ahh I was thinking probe offset was only XY not Z as well!!!
