    Please help me tune my custom printer
    3.9k
      deckingman
      @raykholo:
      Ian I have a 300x300mm machine with Volcano 0.8mm on it and stopped using this one because I cannot sustain the filament requirements 🙂
      So you wouldn't like my 350 x 375 x 750 with 5 colour Diamond that takes 5 reels at a time 🙂 I also have a 0.9mm diameter Diamond but that's only 3 colour. I bought it for printing T Glass but having re-mortgaged the house to buy 3 reels of T glass, I'm saving it for something really special 🙂
      • raykholoundefined
        raykholo
        Oh, I read your other comment about this. This was in response to that.
        I would love it, but I'd have to make a version with a 0.2mm nozzle for myself so that I could use 5 filament color scraps instead of 5 reels.
        If we count all my half-built/ torn apart frames, I now have 20 printers.
        Deltaprintr Delta Go
        Vslot Mini Kossel
        P3steel (makerfront i3, heavily modified)
        2 x Wanhao Duplicator i3 - heavily upgraded. First one just became my best printing machine, second one is getting a diy 4x y splitter like prusa multimaterial.
        Duplicator i3 Plus. On the list for modifications.
        3 custom designed sheet metal based on CNC machanics - this is the 300mm^3 frame.
        Also have 1 where this was a box frame from 20x40 extrusion instead of a folded sheet metal frame.
        Yellowjacket (small 200x200 of the same frame type)
        Still have the 80/20 Frame from the gmax I tried to build as my first printer.
        600x600mm frame from 20x40 vlsot
        5 frankenbot. Our clone of the old laser cut wood Printrbot Plus, BOM around $125.
        DICE.
        I spend over $250 buying 18kg of PLA at a time from Microcenter.
        • ThatBigPrintundefined
          ThatBigPrint
          right guys part cooling fan and abs seams to fail regardless of what I'm trying ? maybe its to powerful… ? print bite temperature settings ? bed 115deg and hot end 220deg ? what do you guys think to retraction settings ?
            ThatBigPrint
            how is best for me to upload the simplify 3d ff file ?
              ThatBigPrint
              now things have gotten harder i tried updating the firmware with he web interface and it restarted as i had expected but can't connect to it both online and through usb ?
                What firmware versions were you upgrading from and to? Did you read the upgrade notes first?
                  ThatBigPrint
                  original wifi firmware to the most recent 1.19.2 followed this https://duet3d.com/wiki/Updating_WiFi_firmware_or_DuetWebControl_files
                    Did you read the upgrade notes?
                      ThatBigPrint
                      No just looked at instructions i was in a rush to get updated because of the heated bed issue. Is it fixable ?
                        Yes, but now you will need to install the new DuetWiFiServer.bin by copying it to /sys on the SD card in a PC. The upgrade notes link to https://duet3d.com/wiki/Upgrading_to_DuetWiFiFirmware_1.19.
                          ThatBigPrint
                          looking at this only one issue i can't connect to the printer through usb (i will get another usb cable to double check) even after the erase and reset having spoken to Roland this afternoon
                            See https://duet3d.com/wiki/What_to_do_if_your_Duet_or_Duet_WiFi_won%27t_respond.
                              ThatBigPrint
                              just not working for me but i am coming up to the nec tomorrow may be better in person if i bring the board up ?
                                ThatBigPrint
                                Right chaps board is back from repair thanks to me not reading the instructions 😕
                                while it was away i have done loads of hardware mods main one is cutting the top off with my cmc mill and wedding a new one on (first one was in stainless and it warped) everything is working fine aside from the bed temperature input showing 2000 Deg c my config file has not changed checked the resistance of the sensor 100 ohm ish at room temperature not sure whats gone on there can anyone help out ?
                                  ThatBigPrint
                                  just to isolate board issue i changed it out for my brand new duet wifi at the same problem is it because of the new firmware change ? i have a p100 temp sensor for the hot end and I'm using the on board thermistor connection next to the heated bed power out ?
                                    There was a firmware change in 1.19 that requires an M305 command in config.g for each thermistor channel you use. So if you don't have a M305 P0 command in config.g, you need to add one. For example:
                                    M305 P0 T100000 B3950
                                    Replace the B parameter by the B value of your bed thermistor, if you know it.
                                      ThatBigPrint
                                      Those settings worked a treat 🙂 thanks
                                      few more things both printers both running the duetwifi seem to time out on the network intermittently need to power cycle to get them back on ?
                                      also an existing issue with print surface print bite is proving a nightmare right now resorted to playing to the one printer more tuned and to stick ! cleaned and wet paper towelled the bed to no avail needed printbite because the one printer is my production one and i wanted to just pull the parts off they need to be abs for the oil rigs only managed to send out 10 ! any other surfaces that are reliable tried buildtak but its to adhesive sometimes
                                        If Printbite behaves like PEI, then putting the bed + print in the freezer may help to release it.
                                        My favourite print surfaces are plain (uncoated) glass and PEI, however I only print PLA and occasionally PETG, and I haven't tried printing on PrintBite.
                                        Regarding lost network connections, see https://duet3d.com/wiki/WiFi_disconnections_and_AJAX_timeout_errors.
                                          ThatBigPrint
                                          Thank you for advice with the PIE i have ordered some for the time being printbite is behaving somewhat (still lifting a tad on pictures 60deg bed)
                                          in other updates the printer is tramed and level ! this took ages with dial test indicator but way worth it ! also started from scratch with the config file and the simplify settings and finally getting somewhere ? network issues are still going on for both machines added a fan on the board for the bigger one the signal is a tad low and the delta is right next to the router 20 dbm…
                                          still have imperfections but retractions seem almost there and bridging is perfect ? and not sure how to cure the divots ? they are where the end of a layer is maybe wipe less ?
                                          • Dougal1957undefined
                                            Dougal1957
                                            try upping your bed temp a bit try 70 for PLA and 115 for ABS Printbite needs a bit higher temps than other surfaces
                                            Doug
