    where should i plug my bed heater into.
    • Dima.undefined
      Dima.
      I think I read somewhere that you should plug your bed heater into the Vout on the duet board. Is this true? My bed has not been heating up fast enaugh on the 'Out' ports on the board
      jumpedwithbothfeetundefined 1 Reply Last reply Reply Quote 0
      • jumpedwithbothfeetundefined
        jumpedwithbothfeet @Dima.
        @dima the time it takes to heat up depends on the size of your bed and heater etc have you carried out a PID on your bed?
        https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Wiring_Diagram
        6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
        Dima.undefined 1 Reply Last reply Reply Quote 0
        • Dima.undefined
          Dima. @jumpedwithbothfeet
          @jumpedwithbothfeet I don't remember carrying out a PID tune.
          In this case, what would the purpose of Vout be?
            @dima, OUT 0 power in is the power supplied to your board to power the bed heater and OUT 0 is the supply to your actual heater this allows you to power the bed with a different PSU than you use to power the main board.
            I don't know what heater your using, but if you haven`t PID tuned the bed already and you haven't had any other issues but heating time, I would do this next.
            • mrehorstdmdundefined
              mrehorstdmd
              This calculator will give you a good idea of the heat up time based on starting temperature, target temperature and bed construction.
