Using a 12 volt fan on 6HC board with vin 24 volts
I have a 12-volt fan I want to use on Out 7. The 6HC board has 24 volts for Vin. Could I just connect one lead of the fan to the dedicated 12V pin and connect the other lead to ground on V_OUTC2 on Out 7? Wouldn't that make it controllable?
@gixxerfast Yes, there is another fan. I suppose I could move one of the fans to Out 4.
@weevil You could of course keep V- (fan gnd wire) connected to out7 pin and steal the V+ (12V) from any other free 12V pin. It's just a tiny bit more messy
@gixxerfast I just looked at the wiring diagram. It has this warning:
"Note: These outputs are protected by a flyback diode connected to V_OUT_LC_2. Do not mix loads connected to V_OUT_LC_2 with the jumper set to 12V and loads connected to V_FUSED on the same bank." -
@weevil How many fans do you currently have in total, and where ae they connected?
@deckingman I have 2 fans, one for the hotend and one for part cooling. I have decided to just stick with my 24v fans, much simpler.
@weevil said in Using a 12 volt fan on 6HC board with vin 24 volts:
That's the obvious solution, then you can set one of the two banks of outputs to 12V and the other one to VIN.
@dc42 Thanks!
@deckingman Thanks
