    Using a 12 volt fan on 6HC board with vin 24 volts
    570
    • Gixxerfastundefined
      Gixxerfast
      Do you have other 24V units already connected to out8 and out9 so you don't want to jumper the voltage to 12V?
      Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
      Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
      Ender 3 Pro with BTT SKR-2 + RRF
      Weevilundefined 1 Reply Last reply Reply Quote 0
      • Weevilundefined
        Weevil @Gixxerfast
        @gixxerfast Yes, there is another fan. I suppose I could move one of the fans to Out 4.
        Gixxerfastundefined dc42undefined 2 Replies Last reply Reply Quote 0
          Gixxerfast @Weevil
          @weevil You could of course keep V- (fan gnd wire) connected to out7 pin and steal the V+ (12V) from any other free 12V pin. It's just a tiny bit more messy 🙂
          • Weevilundefined
            Weevil @Gixxerfast
            @gixxerfast I just looked at the wiring diagram. It has this warning:
            "Note: These outputs are protected by a flyback diode connected to V_OUT_LC_2. Do not mix loads connected to V_OUT_LC_2 with the jumper set to 12V and loads connected to V_FUSED on the same bank."
            deckingmanundefined 1 Reply Last reply Reply Quote 2
              deckingman @Weevil
              @weevil How many fans do you currently have in total, and where ae they connected?
              • Weevilundefined
                Weevil @deckingman
                @deckingman I have 2 fans, one for the hotend and one for part cooling. I have decided to just stick with my 24v fans, much simpler.
                  dc42 administrators @Weevil
                  @weevil said in Using a 12 volt fan on 6HC board with vin 24 volts:
                  That's the obvious solution, then you can set one of the two banks of outputs to 12V and the other one to VIN.
                    deckingman @Weevil
                    @weevil To expand on what @DC42 has said, set jumper on out 4-6 to fit between 12V and V_outC1, set jumper on out 7-9 to fit between V_fused and V_OutC2, connect the 12V fan to any of out 4 to 6, connect the 24V fan to any of out 7 to 9.
                    • Weevilundefined
                      Weevil @dc42
                      @dc42 Thanks!
                      • Weevilundefined
                        Weevil @deckingman
                        @deckingman Thanks
