    RRF Update to 3.3 just killed my FW
    2.1k
    • Andy Cohenundefined
      Andy Cohen @Phaedrux
      @phaedrux Heck... at this point I'm not sure of anything!
      I also suspect the wifiserver FW needs to be updated as well as the ManelDue.
      ; Configuration file for Duet WiFi (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Jan 31 2022 16:37:49 GMT-0800 (PST)
      M550 P"My Printer" ; set printer name
      M550 P"CloneDuet" ; Set machine name
      M552 S1 ; Enable network
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M92 X88.57 Y88.57 Z400.00 E125.459271 ; set steps per mm
      M201 X1000.00 Y1000.00 Z20.00 E250.00 ; set accelerations (mm/s^2)
      M906 X800 Y800 Z400 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X300 Y195 Z210 S0 ; set axis maxima
      M574 X2 S1 P"!xstop" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin xstop
      M574 Y2 S1 P"!ystop" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
      M574 Z1 S1 P"!zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop
      M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
      M557 X10:300 Y-16.0:195 S20 ; define mesh grid
      M563 P1 ; Define tool 1
      G10 P1 X35 Y0 Z0 ; Set tool 1 axis offsets
      G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
        Andy Cohen
        Yeah... you were correct.
        There's no
        "M669 K1 ; switch to CoreXY mode"
        I added it and now it seems to work.
          Can you send m122 and share the results?
          Andy Cohenundefined 1 Reply Last reply Reply Quote 0
            @phaedrux Attached.
            In the meantime the PanelDue is a 5.0i but it does not seem to want to update via the Duet. It's 3 years old. Think I'll need to remove it from it's containment and hit a resent button?
            M122
            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
            Board ID: 08DGM-917DA-G4MS8-6JKD0-3S06N-K9TVB
            Used output buffers: 3 of 24 (12 max)
            Static ram: 23876
            Dynamic ram: 75052 of which 0 recycled
            Never used RAM 15488, free system stack 184 words
            Tasks: NETWORK(ready,14.4%,244) HEAT(delaying,0.0%,326) Move(notifyWait,0.1%,364) MAIN(running,85.2%,417) IDLE(ready,0.4%,29), total 100.0%
            Owned mutexes: WiFi(NETWORK)
            Last reset 00:04:26 ago, cause: power up
            Last software reset at 2022-01-31 19:16, reason: StuckInSpinLoop, GCodes spinning, available RAM 12280, slot 0
            Software reset code 0x4083 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x2000254c Task MAIN Freestk 900 ok
            Stack: 004534c9 00455180 810f0000 00000000 3f000000 369dc3a0 3edbc06f 3331bb4c 40000000 b5ddd98d 388ab355 bb360b61 3e2aaaab 3f800000 00000000 00000000 4354c416 00000000 00000000 60000010 004534c1 200080c8 00408da7 00000000 200182c8 20004c8c 0041872b
            Error status: 0x00
            Step timer max interval 0
            MCU temperature: min 37.4, current 39.2, max 39.6
            Supply voltage: min 23.9, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
            Driver 0: position 0, standstill, SG min/max not available
            Driver 1: position 0, standstill, SG min/max not available
            Driver 2: position 0, standstill, SG min/max not available
            Driver 3: position 0, standstill, SG min/max not available
            Driver 4: position 0, standstill, SG min/max not available
            Driver 5: position 0
            Driver 6: position 0
            Driver 7: position 0
            Driver 8: position 0
            Driver 9: position 0
            Driver 10: position 0
            Driver 11: position 0
            Date/time: 2022-01-31 19:26:17
            Slowest loop: 7.69ms; fastest: 0.17ms
            === Storage ===
            Free file entries: 10
            SD card longest read time 1.1ms, write time 0.0ms, max retries 0
            === MainDDARing ===
            === AuxDDARing ===
            Segments left: 0
            Movement lock held by null
            HTTP is idle in state(s) 0
            Telnet is idle in state(s) 0
            File is idle in state(s) 0
            USB is idle in state(s) 0
            Aux is idle in state(s) 0
            Trigger is idle in state(s) 0
            Queue is idle in state(s) 0
            LCD is idle in state(s) 0
            Daemon is idle in state(s) 0
            Code queue is empty.
            === Network ===
            Slowest loop: 182.04ms; fastest: 0.00ms
            HTTP sessions: 1 of 8
            • WiFi -
              Network state is active
              WiFi firmware version 1.26
              WiFi MAC address bc:dd:c2:89:a2:9b
              WiFi Vcc 3.38, reset reason Turned on by main processor
              WiFi flash size 4194304, free heap 24160
              WiFi IP address 192.168.1.92
              WiFi signal strength -37dBm, mode 802.11n, reconnections 0, sleep mode modem
              Clock register 00002002
              Phaedrux Moderator @Andy Cohen
              @andy-cohen said in RRF Update to 3.3 just killed my FW:
              I think you'll need to update it's firmware via usb as well so that it can communicate with RRF3 as well. I think the latest firmware is 3.4 for the paneldue. I think once you have it up to date with the firmware you'll actually be able to update it via DWC in the future.
              https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update#Section_Firmware_update_via_USB
              It looks like your main firmware and wifi firmware are up to date now. Can you confirm that DWC is also at 3.3?
                @phaedrux Right. I'm already there.
                Bossa does not work in the latest MacOS.
                I'm forced to find a ... PC.
                BTW where do I find the DWC version?
                  droftarts administrators @Andy Cohen
                  @andy-cohen to get Bossa working on macOS, see this thread: https://forum.duet3d.com/topic/11445/
                  Find DWC version in DWC on system page, general tab https://duet3d.dozuki.com/Wiki/Duet_Web_Control_v2_and_v3_(DWC)_Manual#Section_General_tab
                    Andy Cohen @droftarts
                    @droftarts said in RRF Update to 3.3 just killed my FW:
                    DWC is at 3.3.
                    Found a PC and updated the PanelDue. The update worked but it does not see the tools nor does it operate anything. My bet is I have to add a line in the config... right?
                      Andy Cohen @Andy Cohen
                      @andy-cohen Yup!
                      All seems to be working fine for now.
                      I'm really not looking forward to updating my Toolchanger!
                      Andy Cohenundefined 2 Replies Last reply Reply Quote 0
                        This post is deleted!
                          @andy-cohen This update FUBARED my machine. WHY was SO much changed?
                          Now I cannot control the tool from the PanelDue. I get constant messages about commands that no longer work WTF!
                          The tool definition makes no sense at all to me!
                          I cannot see how the Extruder is associated with the tool AT ALL!!!
                            This tool has no extruder or heater assigned to it. Perhaps that's your issue? You didn't mention which tool you're trying to control.
                            Can you share a recent config.g?
                            PanelDue is up to date now? DWC is at 3.3 as well?
                              @phaedrux When I try to retract at the hotend from the panel it does nothing. Then the panel becomes unresponsive. I cannot believe how frustrating this is! Why so many changes?
                              M551 P"adc238" ; Set password
                              ;M587 S"ATT642_EXT" P"4269605351" ; Configure access point. You can delete this line once connected
                              M587 S"ATT642" P"4269605351" ; Configure access point. You can delete this line once connected
                              M575 P1 B57600 S1 ;Paneldue
                              ;M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit
                              M307 H0 B0 R0.219 C409.3 D5.09 S1.00 V23.7 ;From auto tune
                              ;M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
                              M307 H1 B0 R2.422 C201.2 D10.87 S1.00 V24.0 ;From Auto tune
                                How many tools do you have? one or two?
                                Can you share your config from RRF2?
                                I understand you're frustrated, but it's really not as devastating and you're making it out to be. Answer my questions and we'll get you back up and running.
                                The upgrade isn't forced and you can go back if you wish.
                                  @phaedrux I have one. The code there is taken from the old config. When I put in what came out of the web app it does not work at all.
                                  This is what was generated by the web app:
                                    If you only have a single tool remove this section for tool1 then.
                                    Does the extruder move when at temp?
                                    Can you be more specific? What do the messages actually say? What commands?
                                    Can you confirm that the PanelDue is up to date now by checking it's version on the setup page?
                                      @phaedrux OK... I will rem those lines out.
                                      The messages were as follows:
                                      "Error Tool 0 not found"
                                      "Error: Attempting to Extrude with no tool selected"
                                      There were more but I lost them.
                                        @phaedrux I remmed out the lines and rebooted.
                                        The PanelDue shows the extruder icon with a Zero next to it(it used to show a "1").
                                        I set the temp and heat it up. I select the Icon button so it's highlighted and I then go to the button to extrude some filament and hit extrude and nothing happens
                                          Can you add T0 to the end of your config.g so that the first tool is selected at startup?
                                            Can you send M98 P"config.g" and post the results?
