Solved Temperature setting gone.
Hello everyone,
the display of the temperature setting disappeared from the display panel on my computer.
do you have an idea.
Thank you. -
Can you show a photo of what you mean?
Have you recently changed anything? Firmware update? Does your DWC version match your firmware version?
@phaedrux Here is a picture. Yes I made an update recently.
no one can help me. I just made an update, before it worked very well. I attach my config file.
; Configuration file for Duet WiFi (firmware version 1.21) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2 on Sun Mar 17 2019 11:25:52 GMT+0100 (heure normale d’Europe centrale) ; ---------------------------------------------------------------------------------------------------------------------------------------------- ; General preferences ; ---------------------------------------------------------------------------------------------------------------------------------------------- G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves M665 R160.00 L400.00 H520.00 B140.00 ;M665 R160 L400 B150 H520; Set delta radius, diagonal rod length, printable radius and homed height H500 M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them ; ----------------------------------------------------------------------------------------------------------------------------------------------- ; ----------------------------------------------------------------------------------------------------------------------------------------------- ; Network ; ----------------------------------------------------------------------------------------------------------------------------------------------- M550 P"LittleMonsterWifi" ; Set machine name M552 S1 ; Enable network ;M587 S"Livebox-2AF2" P"........................." ; Configure access point. You can delete this line once connected M586 P0 S1 ; Enable HTTP M586 P1 S0 ; Disable FTP M586 P2 S0 ; Disable Telnet ; ----------------------------------------------------------------------------------------------------------------------------------------------- ; ----------------------------------------------------------------------------------------------------------------------------------------------- ; Drives ; ----------------------------------------------------------------------------------------------------------------------------------------------- M569 P0 S1 ; Drive 0 goes forwards M569 P1 S1 ; Drive 1 goes forwards M569 P2 S1 ; Drive 2 goes forwards M569 P3 S1 ; Drive 3 goes forwards M350 X16 Y16 Z16 E16 I1 ; Configure microstepping with interpolation M92 X80.00 Y80.00 Z80.00 E427.190 ; Set steps per mm M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; Set maximum instantaneous speed changes (mm/min) M203 X19980.00 Y19980.00 Z19980.00 E3600.00 ; Set maximum speeds (mm/min) M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; Set accelerations (mm/s^2) M906 X1000.00 Y1000.00 Z1000.00 E800.00 I60 ; Set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; ----------------------------------------------------------------------------------------------------------------------------------------------- ; Axis Limits ; ----------------------------------------------------------------------------------------------------------------------------------------------- M208 Z0 S1 ; Set minimum Z ; ----------------------------------------------------------------------------------------------------------------------------------------------- ; ----------------------------------------------------------------------------------------------------------------------------------------------- ; Endstops ; ----------------------------------------------------------------------------------------------------------------------------------------------- M574 X2 S1 P"xstop" ; ok Set active high endstops M574 Y2 S1 P"ystop" ; ok Set active high endstopS M574 Z2 S1 P"zstop" ; ok Set active high endstops ; ----------------------------------------------------------------------------------------------------------------------------------------------- ; ----------------------------------------------------------------------------------------------------------------------------------------------- ; Z-Probe ; ----------------------------------------------------------------------------------------------------------------------------------------------- M558 P9 C"^zprobe.in+zprobe.mod" H5 F300 T3000 ; Set Z probe type to bltouch and the dive height + speeds H10 M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch G31 P500 X0 Y25 Z0.00 ; Set Z probe trigger value, offset and trigger height 2.45; 2.658 M557 R140 S25 ; Define mesh grid ; ----------------------------------------------------------------------------------------------------------------------------------------------- ; ----------------------------------------------------------------------------------------------------------------------------------------------- ; Heaters ; ----------------------------------------------------------------------------------------------------------------------------------------------- M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 R4700 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M140 H0 P0 ; resets the temperature limit for the heater to the default for bed heaters M143 H0 S120 ; set temperature limit for heater 0 to 120C M307 H0 B0 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.060000e-8 R4700 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M143 H1 S280 ; set temperature limit for heater 1 to 280C ;M307 H1 A437.1 C302.4 D0.6 S1.00 V24.3 B0 ; PID tuning ed3 v6 buse 0,4 ; ----------------------------------------------------------------------------------------------------------------------------------------------- ; ----------------------------------------------------------------------------------------------------------------------------------------------- ; Fans ; ----------------------------------------------------------------------------------------------------------------------------------------------- M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency FAN IMPRESSION M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency FAN BUSE M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency FAN BOITIER MCU ;M106 P2 S0 H-1 ; set fan 2 value. Thermostatic control is turned off M106 P2 F100 L0.4 B0.5 T33:40 H100:101:102 ; Set fan 2 Duet case fan. Turns on when the MCU temperature (virtual heater 100) ; ----------------------------------------------------------------------------------------------------------------------------------------------- ; ----------------------------------------------------------------------------------------------------------------------------------------------- ; Tools ; ----------------------------------------------------------------------------------------------------------------------------------------------- M563 P0 D0 H1 ; Define tool 0 G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures ;*** If you have a single-nozzle build, comment the next 2 lines M563 P1 D1 H2 ; Define tool 1 G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures M579 X0.996 Y0.993 Z1.00 ; scaling factor for Cartesian cords x1.01266 Y1.00908 X0.99453 ; ------------------------------------------------------------------------------------------------------------------------------------------------ ; ------------------------------------------------------------------------------------------------------------------------------------------------ ; Automatic saving after power loss is not enabled ; ------------------------------------------------------------------------------------------------------------------------------------------------ ; ------------------------------------------------------------------------------------------------------------------------------------------------ ; Custom settings are not configured M575 P1 B57600 S1; panel due ; ------------------------------------------------------------------------------------------------------------------------------------------------ ; ------------------------------------------------------------------------------------------------------------------------------------------------ ; Miscellaneous ; ------------------------------------------------------------------------------------------------------------------------------------------------ G29 S1 M501 ; Load saved parameters from non-volatile memory ; ------------------------------------------------------------------------------------------------------------------------------------------------
How many tools do you actually have?
Your config shows two tools being defined, but there is no heater or extruder defined for the second tool.
I think those lines should be commented out.
G29 S1
G29 S1 should not be used in config.g. Load the heightmap in your slicer start gcode after homing the z axis.
Can you please send M122 and M98 P"config.g" and post the results?
I have an extruder and heater EV6
here is the M122
08/02/2022, 19:08:54 M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later Board ID: 08DDM-9FAM2-LW4SD-6J9FL-3SJ6J-KJZ7Y Used output buffers: 3 of 24 (12 max) === RTOS === Static ram: 23876 Dynamic ram: 74368 of which 68 recycled Never used RAM 16104, free system stack 134 words Tasks: NETWORK(ready,13.0%,237) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,305) MAIN(running,86.2%,503) IDLE(ready,0.7%,29), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:02:18 ago, cause: power up Last software reset at 2022-02-06 20:59, reason: User, GCodes spinning, available RAM 16104, slot 2 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Step timer max interval 0 MCU temperature: min 14.1, current 22.3, max 22.6 Supply voltage: min 24.2, current 24.4, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Driver 0: position 70738, standstill, SG min/max 0/118 Driver 1: position 70738, standstill, SG min/max 0/130 Driver 2: position 70738, standstill, SG min/max 0/143 Driver 3: position 0, standstill, SG min/max not available Driver 4: position 0, standstill, SG min/max not available Driver 5: position 0 Driver 6: position 0 Driver 7: position 0 Driver 8: position 0 Driver 9: position 0 Driver 10: position 0 Driver 11: position 0 Date/time: 2022-02-08 19:08:53 Cache data hit count 4294967295 Slowest loop: 11.14ms; fastest: 0.16ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 3.3ms, write time 0.0ms, max retries 0 === Move === DMs created 83, maxWait 106475ms, bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves 5, completed moves 5, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 15.66ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 - WiFi - Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.26 WiFi MAC address 5c:cf:7f:ee:6a:e7 WiFi Vcc 3.40, reset reason Turned on by main processor WiFi flash size 4194304, free heap 25512 WiFi IP address 192.168.1.18 WiFi signal strength -66dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0
M98 P"config.g"
08/02/2022, 19:10:10 M98 P"config.g" HTTP is enabled on port 80 FTP is disabled TELNET is disabled Error: in file macro line 34 column 19: M350: array too long, max length = 0 Error: in file macro line 35 column 27: M92: array too long, max length = 0 Error: in file macro line 36 column 34: M566: array too long, max length = 0 Error: in file macro line 37 column 37: M203: array too long, max length = 0 Error: in file macro line 38 column 34: M201: array too long, max length = 0 Error: in file macro line 39 column 34: M906: array too long, max length = 0 Error: Sensor number out of range Error: bad drive number Error: Tool 0 not found Error: bad drive number Error: Tool 1 not found Warning: the height map was loaded when the current Z=0 datum was not determined probing. This may result in a height offset. Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 277C
thank you for your help
Hello, no one can help me
@synergy41 it looks like you haven't assigned any driver to the extruder. If your extruder is connected to the E0 motor output, add this before line 34:
M584 X0 Y1 Z2 E3
Thank you, that was right.
It's passing something weird then during the update to 3.3 -
I think the problem was that your old config didn't have an M584 command and there were defaults in older firmware. There a no longer defaults and the M584 command must be present.
undefined dc42 marked this topic as a question
undefined dc42 has marked this topic as solved
