    How can I start a part program again after it is finished
    CNC
    360
    • martin7404undefined
      martin7404
      So I built a custom machine for automated drilling of ALU profile
      with 2 AXIS , Z, and X.
      On my CNC mills and lathe machines, I can put M99 at the end of a file and it will run it again and again until some condition or with M00 and switch on the controls keyboard.
      Generally, I want to loop the part program (job) endless
      Dduet wifi , RPF2 with duet brackout board and external drivers
      How to do this with DUET
      Muldex IDEX Duet2+Duex5
      Custom CoreXY 600x400 Hemera , Duet3+Toolboard+1HCL closed loop
      Sapphire Pro with Duet2, with closed-loop motors
      custom high temp E3D tool changer with Duet2+Duex
      • oliofundefined
        oliof @martin7404
        @martin7404 you can do this with metacommands
        I would write a helper macro, "Loop.g" that looks roughly like this:
        while globals.Loop
          M98 P{params.X}
        A Macro "EnableLoop"
        if exists(global.Loop)
          set global.Loop = true
        else
          global Loop = true
        And a Macro "StopLoop"
        if exists(globals.Loop)
          set globals.Loop = false
        else
          global Loop = false
        Then you can set up your system to Loop by running EnableLoop
        and call your looping gcode running M98 P"Loop" X"FileToLoop"
        Note this is untested and probably misses some nuance. You will need to make sure that in case of error globals.Loop is unset for example
        martin7404undefined 1 Reply Last reply Reply Quote 2
          martin7404 @oliof
          @oliof thank you
          So I should move to RPF 3 then with this project
          oliofundefined baird1faundefined 2 Replies Last reply Reply Quote 0
          • oliofundefined
            oliof @martin7404
            @martin7404 I would recommend that
            • baird1faundefined
              baird1fa @martin7404
              @martin7404 I'm running a duet 2 wifi with external drivers and using RRF3.4 the only issue I've seen is that when in CNC mode I have no DRO of any kind. They are supposedly fixing that when 3.4 becomes RC1 (not sure what that means)
              • oliofundefined
                oliof @baird1fa
                @baird1fa excuse my ignorance, but what does DRO mean in this context and what is it used for?
                martin7404undefined 1 Reply Last reply Reply Quote 0
                  martin7404 @oliof
                  @oliof Digital Read Out.
                  i.e. No position tracking on panel DUE only in DWC
                  • oliofundefined
                    oliof @martin7404
                    @martin7404 PanelDue (and 12864 if configured to do so) do show current position (within limits), but I guess you are looking for either a real time display or position reporting from encoders etc.?
