    CONSTANT AJAX disconnect errors
    307
    54.6k
    • snomonundefined
      snomon
      Hi guys, I'm having the same problem..Im trying to tell it to print something but it keeps giving me AJAX errors..ctrl+r a few times, i get in at some point. The print then keeps messing up and having me to reset it, not sure why
      2:55:56 AMM122
      Used output buffers: 3 of 32 (15 max)
      RepRapFirmware for Duet WiFi version 1.19.2 running on Duet WiFi 1.0
      Board ID: 08DDM-9FAM2-LW4SD-6J9F6-3S46N-12X7W
      Static ram used: 21176
      Dynamic ram used: 96104
      Recycled dynamic ram: 1504
      Stack ram used: 1304 current, 5920 maximum
      Never used ram: 6368
      Last reset 00:12:18 ago, cause: power up
      Last software reset reason: User, spinning module GCodes, available RAM 3136 bytes (slot 4)
      Software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
      Error status: 0
      Free file entries: 10
      SD card longest block write time: 9.7ms
      MCU temperature: min 51.1, current 53.7, max 55.9
      Supply voltage: min 23.4, current 24.1, max 24.6, under voltage events: 0, over voltage events: 0
      Driver 0: stalled standstill
      Driver 1: stalled standstill
      Driver 2: stalled standstill
      Driver 3: standstill
      Driver 4: standstill
      Date/time: 2017-09-21 02:55:52
      Slowest main loop (seconds): 0.167053; fastest: 0.000034
      MaxReps: 6, StepErrors: 0, FreeDm: 240, MinFreeDm 234, MaxWait: 10780ms, Underruns: 0, 0
      Scheduled moves: 5, completed moves: 5
      Bed compensation in use: none
      Bed heater = 0, chamber heater = -1
      Heater 0 is on, I-accum = 0.0
      Heater 1 is on, I-accum = 0.3
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      Network state is running
      WiFi firmware version 1.19.2
      WiFi MAC address 60:01:94:34:40:06
      WiFi Vcc 3.14, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 36896
      WiFi IP address 192.168.20.81
      WiFi signal strength -57dBm
      Reconnections 0
      HTTP sessions: 1 of 8
      Socket states: 2 0 0 0 0 0 0 0
      Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      2:55:49 AMConnection established!
      2:55:24 AMDisconnected.
      2:55:16 AMConnection established!
      2:55:11 AMDisconnected.
      2:55:03 AMConnection established!
      2:55:01 AMDisconnected.
      2:54:53 AMConnection established!
      2:54:15 AMDisconnected.
      2:52:10 AMConnection established!
      2:46:32 AMDisconnected.
      2:43:49 AMConnection established!
      2:41:46 AMDisconnected.
      2:39:46 AMConnection established!
      2:38:11 AMDisconnected.
      2:33:01 AMConnection established!
      2:32:52 AMDisconnected.
      2:32:40 AMCalibrated 6 factors using 13 points, deviation before 0.028 after 0.014
      2:31:48 AMM32 Enclosure bracket v10(1).gcode
      File Enclosure bracket v10(1).gcode selected for printing
      2:30:54 AMM0 H1
      File Enclosure bracket v10(0).gcode print time was 0h 9m
      2:30:07 AMM25
      Printing paused
      2:25:29 AMConnection established!
      2:24:55 AMDisconnected.
      2:21:20 AMCalibrated 6 factors using 13 points, deviation before 0.091 after 0.024
      2:20:42 AMM32 Enclosure bracket v10(0).gcode
      File Enclosure bracket v10(0).gcode selected for printing
      2:20:14 AMM0 H1
      2:19:53 AMM25
      Printing paused
      2:11:17 AMCalibrated 6 factors using 13 points, deviation before 0.071 after 0.014
      2:10:35 AMM32 Enclosure bracket v10(0).gcode
      2:10:08 AMM122
      Used output buffers: 1 of 32 (14 max)
      Dynamic ram used: 96200
      Recycled dynamic ram: 1408
      Stack ram used: 4048 current, 9104 maximum
      Never used ram: 3184
      Last reset 00:31:37 ago, cause: power up
      Error status: 0
      SD card longest block write time: 0.0ms
      MCU temperature: min 54.7, current 55.3, max 55.6
      Supply voltage: min 23.4, current 24.0, max 24.4, under voltage events: 0, over voltage events: 0
      Driver 0: standstill
      Date/time: 2017-09-21 02:10:06
      Slowest main loop (seconds): 0.176147; fastest: 0.000000
      MaxReps: 0, StepErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
      Bed probe heights: 0.245 0.225 0.020 -0.266 -0.374
      Heater 1 is on, I-accum = 0.5
      Segments left: 0
      http is ready with "M122" in state(s) 0
      WiFi flash size 4194304, free heap 32424
      Reconnections 0
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      2:10:00 AMM0 H1
      File Enclosure bracket v10.gcode print time was 0h 14m
      • mhackneyundefined
        mhackney
        My update…
        I installed a wifi extender on my network to get a better signal to my Duet WiFi. I'm in the range of about -45dBm now, much better than the -79 I had before.
        I've been on a business trip for 3 days but have some additional observations.
        I've done 10ish prints before the trip and a few yesterday and did not have any disconnects during the print. The disconnects while idle still occur but they are farther between. The reason is
        "An AJAX error has been reported, so the current session has been terminated. Please check if your printer is still on and try to connect again."
        M122 shows:
        MaxReps: 117, StepErrors: 0, FreeDm: 240, MinFreeDm 120, MaxWait: 3180388ms, Underruns: 0, 1
        Scheduled moves: 1, completed moves: 1
        The good news is, when this happens, I am able to Connect without restarting the Duet. I did read the new wiki on disconnects and found my AJAX retries was set to 1 so I've changed that to 3 and I'll keep watching.
        My 3D Printing blog: http://www.sublimelayers.com
        Coming this summer: "3D Printing Strategies - the art of perfecting your designs and prints"
        • botundefined
          bot
          Just a note, to anyone who is questioning whether their signal strength is sufficient, here is a great article I found:
          https://support.metageek.com/hc/en-us/articles/201955754-Understanding-WiFi-Signal-Strength
          Notice the chart at the end that gives general guidelines for required signal strength.
          *not actually a robot
          • Jareryundefined
            Jarery
            Currently I cannot connect at all anymore via web. Ive tried clearing cache, safari and chrome, rebooted the printer 3 times, cycled the wifi on/off.
            Consol says it connects to my network and lists assigned ip, but unable to connect.
            Edit : connected after about 20min of throwing things at it
            Via USB my M122 network is :
            WiFi MAC address 5c:cf:7f:a4:a1:64
            WiFi Vcc 3.13, reset reason Turned on by main processor
            WiFi flash size 4194304, free heap 39944
            WiFi IP address 192.168.2.54
            WiFi signal strength -33dBm
            Reconnections 0
            HTTP sessions: 0 of 8
            • KeeganBundefined
              KeeganB
              Ok, after a few more nights of testing, I can confidently say the following:
              1. It will stay connected forever at idle.
              2. It seems to stay connected forever running G32 commands, and other manual control commands
              3. Within minutes of starting a new print, it disconnects. EVERY SINGLE TIME. The same AJAX error every time.
              4. After approximately 30-60 mins, it can be reconnected fine and will stay connected forever or until I start a new print.
              I am still on 1.19.2, but may downgrade as this is really annoying.
              Artemis
              Rostock Max v2
              Orion
                Is the "Error reason:" given in the Ajax disconnect message Timeout, or something else?
                • KeeganBundefined
                  KeeganB
                  @dc42:
                  Sorry, I should have included that. Yes, I believe that is the error message. It’s the same message every time.
                  Artemis
                  Rostock Max v2
                  Orion
                  • Jareryundefined
                    Jarery
                    my Ajax error is the same, doesn't say what the cause is whether timeout or other.
                    Just states "an AJAX error has been reported, so the current session has been terminated. Please check if your printer is still on and try to connect again "
                    I also disconnect every print but mine do not reconnect.
                    Edit:
                    I'm just commissioning a second DuetWifi delta, it has :
                    Firmware Version: 1.18.1 (2017-04-09)
                    WiFi Server Version: 1.03 (ch fork)
                    Web Interface Version: 1.15a
                    And if I force a disconnect, the warning message has at the bottom "Reason: Timeout". This bottom line is not present at all in the 19.2 firmware disconnects issue. Cannot print yet so unable to tell if the issue is board related or wifi network.
                    • Jareryundefined
                      Jarery
                      Comissioned my 2nd duet wifi printer.
                      Board came with 1.18.1 firmware. No disconnects when printing. Although only did few prints, 10 min long or so.
                      Upgraded to 1.19.2, disconnected a coulee min into my first print. Ajax error message again has no line on the bottom stating reason.
                      So i have 2 new Duet wifi's, both disconnect from my Asus RT-AC3100 wifi network on every print.
                      The chances its a "bad board" or slim as it happens on both boards.
                      The chances its my network settings are low as Ive set everything to set channel, etc, and it works on 1.18 without disconnects.
                      There is something in 1.19 that just makes it appear to timeout
                      • KeeganBundefined
                        KeeganB
                        I've never downgraded a Duet. Is it the same process as the update from 1.18 to 1.19.2 was, but in reverse?
                        Artemis
                        Rostock Max v2
                        Orion
                          I really wish there was some way I could reproduce the problem you are experiencing. AFAIK you are the only user who finds 1.19.2 less reliable than 1.18.
                          Downgrading to 1.18 you will need to do a simultaneous install of both DuetWiFiFirmware and DuetWiFiServer. If the board was shipped with 1.19 firmware originally then you will also need to install DuetWiFiFirmware.bin on the WiFi module.
                          Then you will need to follow the connection instructions for 1.18 and earlier.
                          • lolorcundefined
                            lolorc
                            i also find 1.19.2 less reliable than 1.8 with regard to the wireless/ajax issue. (sorry I'm not really helping with the debugging at the moment, house for sell, can't use my printer as often as I wish)
                            • KeeganBundefined
                              KeeganB
                              Thanks David.
                              My board was shipped with 1.18.
                              I understand that network issues are near impossible to replicate. I wish there was more detailed log info or something I could get to you. I am able to force a reconnect via USB with M552 S-1/S1
                              The real frustration comes when doing calibration prints and etc. It disconnects so quickly I can't make any adjustments easily; baby stepping, extrusion, temp etc to do on-the-fly adjustments. That, and every time I want to start a new test print I have to go through the reconnect process every time.
                              I feel pretty confident my network is not the issue, but I have been toying with the idea of upgrading my router and other network equipment, so maybe I will do that now just in case. I've also considered taking on my my extra routers and setting up a clean dummy network to test.
                              David, is there any possible advantage in doing a "clean" install of 1.19.2. Meaning, could/should I format the SD card and do a completely clean install of everything, and then just paste in my config values as needed?
                              Artemis
                              Rostock Max v2
                              Orion
                              • Jareryundefined
                                Jarery
                                @KeeganB:
                                Thanks David.
                                My thoughts also.
                                I'm also not happy with 1.19 in regards to 1.18.
                                All the additions are awesome, and I always use volumetric extrusion and other features not in 1.18. But if i have no method of connecting to the system the features it has are a moot point.
                                • Dougal1957undefined
                                  Dougal1957
                                  I Did have an issue to start with which was almost instant disconnects I fitted an AP Extender and got round it but then when I moved the printer back to it rightful location the issue re-appeared turns out my WiFi AP Credentials for the original AP was corrupt deleting them and re-applying fixed the problem not saying it will fix you issues but may be worth a try?
                                  FWIW I am using a netgear WiFi router (D6400)
                                  • KeeganBundefined
                                    KeeganB
                                    Sorry Dougal,
                                    I am not following what you are suggesting? Are you saying the credentials saved to the DUET for connecting to your AP were bad?
                                    Artemis
                                    Rostock Max v2
                                    Orion
                                      Dougal1957
                                      yes indeed
                                      • KeeganBundefined
                                        KeeganB
                                        Thanks, I will certainly try that. It won't hurt anything and if it resolves this issue, Ill be ecstatic!
                                        Artemis
                                        Rostock Max v2
                                        Orion
                                          Dougal1957
                                          Use the M588 to remove it from the list first before trying to re-instate it
                                          • KeeganBundefined
                                            KeeganB
                                            I didn't have much time last night, but I tested your idea Dougal. Nope 😞
                                            Artemis
                                            Rostock Max v2
                                            Orion
