    Duex PWN pins gives 2.5 V and not 5 V
    696
    • hsverreundefined
      hsverre @dc42
      It is in the correct position between 5V INT and 5V AUX and it gives 2.5 V. When I reomve the jumper it gives 0 V. I guess there has to be a hardware fault somewhere.
      droftartsundefined 2 Replies Last reply Reply Quote 0
      • hsverreundefined
        hsverre @dc42
        I guess there is a stepdownconverter somewhere. Might be a idea to measure it.
          droftarts administrators @hsverre
          @hsverre the PWM pins are Pulse Width Modulation pins, ie they pulse 5V at whatever interval you set. The voltage can be difficult to measure with a voltmeter at anything less 100% duty cycle, which needs to be set. So how have you set it up? Are you just plugging something in, expecting 5V? Please post your config.g and firmware version.
          hsverreundefined 1 Reply Last reply Reply Quote 0
            @hsverre also note you can’t use the same heater and PWM pin on the DueX; heater E2 is shared PWM1, heater E3 is shared with PWM2, etc.
            • hsverreundefined
              hsverre @droftarts
              @droftarts said in Duex PWN pins gives 2.5 V and not 5 V:
              @hsverre Please post your config.g and firmware version.
              Here it is:
              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later + DueX5
              ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Jul 30 2021 22:46:27 GMT+0200 (sentraleuropeisk sommertid)
              M550 P"Voron24" ; set printer name
              M669 K1 ; select CoreXY mode
              M552 S1 ; enable network
              M586 P0 S1 ; enable HTTP
              M586 P1 S0 ; disable FTP
              M586 P2 S0 ; disable Telnet
              M569 P1 S0 ; z drive 1
              M569 P2 S1 ; z drive 2
              M569 P3 S0 ; z drive 3
              M569 P4 S1 ; z drive 4
              M569 P5 S1 ; a drive 5
              M569 P6 S1 ; b drive 6
              M569 P7 S0 ; ex drive 7
              M572 P7 S0.19
              M584 X5 Y6 Z1:2:3:4 E7
              M671 X815:815:-125:-125 Y500:-130:-130:500 S20 ; leadscrews at rear left, front middle and rear right
              M92 X80.00 Y80.00 Z400.00 E419.19 ; set steps per mm
              ;M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
              ;M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
              ;M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2)
              M84 S30 ; Set idle timeout
              M98 P"/macros/print_scripts/speed_printing.g"
              ;M955 P0 C"spi.cs4+spi.cs3"
              M208 X787 Y452 Z500 S0 ; set axis maxima
              ;BLTouch - Heaters
              ;M307 H2 A-1 C-1 D-1 ; Disable the 2. Heater to free up PWM channel 1 om the Duex board
              ;BLTouch
              ;M558 P9 C"^zprobe.in" H5 F120 T6000
              ;M950 S0 C"duex.pwm2" ; Duet 2 WiFi/Ethernet + DueX2/5
              ;G31 X20 Y0 Z0 P25
              M950 S0 C"duex.pwm1" ; create servo pin 0 for BLTouch
              M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
              ;M557 X15:700 Y15:400 S80 ; define mesh grid;
              ;M558 P1 C"zprobe.in" H20 F6000 T6000 ; set Z probe type to unmodulated and the dive height + speeds
              ;M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
              ;G31 P1000 X0 Y0 Z1.862 ; set Z probe trigger value, offset and trigger height
              M557 X15:780 Y15:450 S30 ; define mesh grid
              M308 S0 P"bedtemp" Y"thermistor" T50000 B4138 ; configure sensor 0 as thermistor on pin bedtemp
              M307 H0 B0 R0.297 C322.9 D14.09 S1.00 V12.4
              ;M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit
              M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
              M307 H1 B0 R2.485 C220.4 D6.96 S1.00 V12.2
              ;M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
              • hsverreundefined
                hsverre @droftarts
                I use non of the Duex heaters.
                  @hsverre What are you trying to connect, and to where? You have a BLTouch connected to PWM1. The PWM pin is to control the BLTouch deployment, not supply 5V to it.
                  • hsverreundefined
                    hsverre @droftarts
                    Yes I have a BLTouch at PWM1 and it does not work. Not action what so ever. And it works fine on another printer.
                    So this pins are not supposed to give 5V? Between GND and 5V AUX as the duex schematics show? bf7d837f-da34-4fbd-9920-1179e3c5b6b2-image.png
                    If so i guess the BLTouch get power from the Probe pins on the Duet Wifi then?
                    dc42undefined droftartsundefined 2 Replies Last reply Reply Quote 0
                      dc42 administrators @hsverre
                      @hsverre yes you can power a BLTouch from the 5V_AUX pin on the DueX.
                      If you have a multimeter then you could trace the path of the 5V rail. There should be 5V on pin 1 of the expansion connector on the Duet, then 5V on pin 1 of the expansion connector on the DueX, then 5V on the 5V_AUX jumper of the DueX. Take care not to short 5V to ground when measuring it.
                        @hsverre You have another thread going with the same issue: https://forum.duet3d.com/topic/27279/bltouch-not-working/24
                        Please don't start a second thread. You'll just be asked the same questions all over again.
                        And yes, 5V AUX should supply 5V. Follow the troubleshooting @dc42 suggested to trace the 5V rail.
                        • hsverreundefined
                          hsverre @droftarts
                          Yes the other thread is about the BLTouch, this one is about the PWM and how it works.
                          Im sorry if I did a mistake. Can i take any actions to make it ok again?
                          Of course the tracing seems like a proper next step. Ill be back
                          • hsverreundefined
                            hsverre @dc42
                            @dc42 said in Duex PWN pins gives 2.5 V and not 5 V:
                            I used a multimeter (without shortcutting 🙂 ) to measure. The 5V on pin 1 on the expanasjon connector at the Duet reports 5V, the pin 1 on the expansion connector on the Duex reports 2.5-ish V (BTW the 3.3 V pin reports 3.3 V) and the 5V_AUX reports 2.5-ish V.
                            • hsverreundefined hsverre marked this topic as a question
                            • hsverreundefined
                              hsverre
                              Where did everyone go? Did i say something wrong? What happened?
                              • JoergS5undefined
                                JoergS5 @hsverre
                                @hsverre I would try to help, but don't understand it.
                                You meant pin 1 on Duet is 5 V, but pin1 on Duex 5 is 2.5 V? They are directly connected by gray cable? Ony reason could be that the grounds are not connected. (Ground of Duet and ground of Duex). At
                                https://duet3d.dozuki.com/Wiki/Duex2_and_Duex5_Features#Section_Wiring
                                are some comments on connecting grounds.
                                If this is not the reason, please make some images of the wiring and where you measured. And information about the Duex release. And how you set the jumpers.
                                hsverreundefined 1 Reply Last reply Reply Quote 1
                                • hsverreundefined
                                  hsverre @JoergS5
                                  @joergs5
                                  Hurray. I finally found out that the problem was the gray fat ribbon cable between the Duet and the Duex. God knows why. It could be that the grounding is the problem then.
                                  Thanks a lot for all the replies 🙂
                                  • JoergS5undefined
                                    JoergS5 @hsverre
                                    @hsverre thanks for information, I am glad that you found the reason. Happy printing 😉
                                    • hsverreundefined hsverre has marked this topic as solved
