Unsolved 3.4 rc1 1XD Probe problem after update
Since I hace update from 3.4 beta 4 to 3.4 rc1 I have a problem with the probing (G30, G30 S-2,....)
When I start a probe and the endstop his triggered I have a problem with my Z axis, thats create a an error in my encoder
I use duet1XD and external motor with encoder.
I don't understand because G30 works fine with 3.4beta4 but with 3.4beta7 and 3.4rc1 thats create a problem to my driver something have changed ?
; Configuration file for Duet 3 (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed Mar 31 2021 11:16:46 GMT+0200 (heure d’été d’Europe centrale) ;M98 P"/sys/condition2.g" ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"" M451 M929 S3 ; Drives M569 P0 S0 ; Drive 0 T0 Extrudeur Gauche M569 P1 S1 ; Drive 1 T1 Extrudeur Droit M569 P2 S1 ; Drive 3 T0 Extrudeur Bobine Gauche M569 P3 S1 ; Drive 3 T0 Extrudeur Bobine Droit M569 P4 S1 ; Drive 4 T1 Montée descente G4 S1 ; set drive mapping M584 E1:2 M584 A3 B4 C0 M584 P7 M350 E16:16 I1 ; configure microstepping without interpolation M350 A16 B16 C16 I1 ; configure microstepping with interpolation M92 A415 B415 C300 E582:582 ; set steps per mm M566 X500 Y500 Z25 W25 A500 B500 C50 E500:500 ; set maximum instantaneous speed changes (mm/min) M203 X12000 Y12000 Z1800 W1800 A3600 B3600 C10000 E1200:1200 ; set maximum speeds (mm/min) M201 X350 Y350 Z50 W50 A500 B500 C500 E500:500 ; set accelerations (mm/s^2) M906 A1200 B1200 C750 E400:400 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S0 ; Set idle timeout M913 C100 ; Courant moteur Axe C 50% ; Axis Limit M208 X0:1040 Y0:515 Z0:534.3 W0:534.3 A-10000:10000 B-10000:10000 C-10:10 M671 X0:1040 Y250:250 ; Endstops M574 A0 M574 B0 M574 C2 S1 P"!10.io0.in" ; Z-Probe M558 P5 C"!io4.in" H10 F300 T6000 ; set Z probe type to switch and the dive height + speeds "!io8.in" G31 P500 X0 Y0 Z-2.725 ; set Z probe trigger value, offset and trigger height M557 X15:985 Y15:485 S150 ;define mesh grid ; Bed heater M308 S0 P"temp0" Y"thermistor" A"Plateau chauffant" T100000 B4138 C0 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out5" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B0 R0.334 C356.2 D1.33 S1.00 V24.0 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 M570 H0 P60 T10 S120; set temperature limit for heater 0 to 120C ; Tool 0 heater M308 S1 P"temp1" Y"thermistor" A"E0" T98640 B4632.86 C9.4861662E-08 H0 L0 ; Set thermistor ;M307 H1 B0 R1.862 C397.7:397.7 D19.89 S1.00 V24.0 M307 H1 B0 R1.857 C385.6:374.5 D14.06 S1.00 V24.0 M950 H1 C"out1" T1 ; Extruder 0 heater M143 H1 S300 ; Set temperature limit for heater 1 to 300C M570 H1 P60 T35 S120 ;Tool 1 heater M308 S2 P"temp2" Y"thermistor" A"E1" T98640 B4632.86 C9.4861662E-08 H0 L0 ; configure sensor 2 as thermistor on pin temp2 M307 H2 B0 R1.782 C345.7:345.7 D18.75 S1.00 V24.0 M950 H2 C"out2" T2 ; create nozzle heater output on out2 and map it to sensor 2 M143 H2 S300 M570 H2 P60 T35 S120 ;Heat chamber M308 S3 P"temp3" Y"thermistor" A"Chambre" T100000 B4138 C7.06e-8 ; configure sensor 3 as thermistor on pin temp3 M950 H3 C"out0" T3 ; create chamber heater output on out3 and map it to sensor 3 M307 H3 B0 S1.00 ; disable bang-bang mode for the chamber heater and set PWM limit M141 H3 ; map chamber to heater 3 M143 H3 S100 ; set temperature limit for heater 3 to 100C M950 P6 C"out3" ; Tools M563 P0 S"E0" D0 H1 F0 ; Define Extruder 0 drive 0 Heater 1 Fan 0 G10 P0 X-10.085 Y-5.075 Z0 C0 ; Set offset G10 P0 R0 S0 ; Reset initial tool 0 active and standby temperatures to 0C M563 P1 S"E1" D1 H2 F1 ; Define Extruder 1 drive 1 Heater 2 Fan 1 G10 P1 X10.085 Y5.075 Z0 C0 ; set tool 1 axis offsets Essais Z offset pour déplacement axe C G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C ;Filament Monitor ;M591 P3 C"io5.in" S1 D0 ; filament monitor connected to E0_stop ;M591 P3 C"io6.in" S1 D0 ; filament monitor connected to E0_stop ; Fans M950 F0 C"10.out1" ; create fan 1 on pin out5 and set its frequency ;M950 F1 C"out8" ; create fan 2 on pin out6 and set its frequency ;Servo ;950 S4 C"io4.out" ; Servo Montée / Descente M950 S5 C"io5.out" ; Servo B0 M950 S7 C"io7.out" ; Servo B1 ;Input ;M950 J0 C"io0.in" ; Arret d'urgence ;M950 J20 C"35.io0.in" ;M581 T0 P0 S1 R0 ; T0 --> M112 Arret d'urgence ;M581 T0 P20 S1 R0 ;M950 J1 C"io1.in" ; Pause / Play trigger 2.g ;M581 T2 P1 S0 R0 ; T6 --> M25 Pause / Play ;M950 J2 C"io2.in" ; Pause / Stop trigger 3.g ;M581 T3 P2 S0 R0 ; Stop ;M950 J3 C"25.io2.in" ; Door ;M581 T4 P3 S0 R0 ; Door ;M950 J10 C"!10.io0.in" ; Detection Outils Impression 3D ;M581 T10 P10 S0 R0 ; Trigger10.g ;M950 J11 C"!20.io0.in" ; Detection Outils CNC ;M581 T11 P11 S0 R0 ; Trigger11.g ;Output ;M950 P0 C"20.out0" ; Verrouillage porte M950 P1 C"10.out0" ; M150 X0 ; set LED type to NeoPixel and set SPI frequency to 3MHz M501 ; Custom settings are not defined ;M375 P"/sys/_Printer/heightmap.csv" M376 H25 ; bed compensation taper ;global CumulativeTime = 0 ;M98 P"0:/macros/myUpTime.g" ; this could be in start.g if doing print time ; load saved parameters from non-volatile memory M911 S22.0 R22.5 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ;set voltage thresholds and actions to run on power loss M501
@tom33 I second this finding, today while testing 3.4 rc1 I couldn't get reliable reading while probing.
My setup is as follows:; Drives M569 P0.0 S0 D3 H50 V50 ; physical drive 0.0 goes backwards M569 P0.1 S0 D3 H50 V50 ; physical drive 0.1 goes backwards M569 P0.2 S0 D3 H50 V50 ; physical drive 0.2 goes backwards M569 P0.3 S1 D3 H50 V50 ; physical drive 0.3 goes forwards M569 P0.4 S1 D3 H50 V50 ; physical drive 0.4 goes forwards M569 P0.5 S0 D3 H50 V50 ; physical drive 0.5 goes backwards M584 X0.3 Y0.4 Z0.2:0.1:0.0 E0.5 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z1600.00 E835 ; set steps per mm M566 X400.00 Y400.00 Z6.00 E120.00 P1 ; set maximum instantaneous speed changes (mm/min) M203 X20800.00 Y20800.00 Z1000.00 E3600.00 ; set maximum speeds (mm/min) M201 X6000.00 Y6000.00 Z3000.00 E3600.00 ; set accelerations (mm/s^2) M906 X2000 Y2000 Z1200 E800 I20 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout
and my bed.g:
M561 ; clear any bed transform G30 P0 X5 Y5 Z-99999 ; probe near a leadscrew G30 P1 X5 Y20 Z-99999 ; probe near a leadscrew G30 P2 X20 Y5 Z-99999 ; probe near a leadscrew G30 P3 X230 Y470 Z-99999 ; probe near a leadscrew G30 P4 X250 Y470 Z-99999 ; probe near a leadscrew G30 P5 X250 Y450 Z-99999 ; probe near a leadscrew G30 P6 X270 Y450 Z-99999 ; probe near a leadscrew G30 P7 X470 Y20 Z-99999 ; probe near a leadscrew G30 P8 X470 Y5 Z-99999 ; probe near a leadscrew G30 P9 X450 Y5 Z-99999 S3 ; probe near a leadscrew and calibrate 3 motors M280 P0 S160 ; clear and reset BL touch G29 S1 ; probe the bed and enable compensation
More what i found is that the motor attribution doesn't seem to work properly
while using M584 Z0:0 (and other possible combinations z0:1 or z0:2)
Sometimes I had two motors rotating and some others I had just one, I suspected I had something wrong with the wires but reverting to 3.3 made the printer fully operational without any physical change on the printer. -
@x_pedro_x @tom33 the significant difference between 3.4rc1 (also 3.4beta7) and earlier releases is that in 3.4rc1, when a motor controlled by a CAN-connected board is stopped because and endstop or Z probe is triggered, the slight overshoot that occurs is corrected after a short delay by reversing the motor movement and sending whatever steps are needed. If you are using closed-loop drivers, perhaps they don't handle this situation very well? If so then reducing the speed of the homing or probing move may help.
@dc42 Thanks for the quick reply, on my eagerness to post I forgot valuable information:
- I'm using a Duet 3 6HC with an SBC
- Open loop steppers
In reality it does look like what you explained every now and then the stepper would make a sound like I had mixed the coils (usually after the 2nd probe location, but also on the 3rd) .
@x_pedro_x please post your complete config.g file so that I can reproduce your setup.
@dc42 I don't have the problem for the homing just for the probing. And Reduce the acceleration or speed doesn't work for me
@tom33 @x_pedro_x this has now been fixed. Please try the new expansion board firmware at https://www.dropbox.com/sh/2dt7sbqpx6l74np/AADn4-lpcil1iqnWKkiVri3Ia?dl=0.
@dc42 I will have to wait a bit, unfortunately i destroyed my sbc (forgot that the camera link is not hot-plugable) and am waiting for a new one
As soon as i receive it I'll try the FW. -
@x_pedro_x @dc42 I think we have the same problem than you, as David said in our post entry. We will test it tomorrow to see if the 3.4RC1+2 solve the issue.
David, do we use all RC1+2 dropbox updated files, or only the one for the 1XD board?
@x_pedro_x Hi Pedro, we've tested with the David's 1LC 3.4rc1+2 files and it's working fine.
@dc42 I try this today !
@dc42 Hi, I tested your files and the homing could be done properly.
Just to confirm I reverted to the public rc1 and the problem happens again, using rc1+2 behaves as expected.
Thanks for the help. -
