    Correction of heightmap is not really working
    6.9k
    • ICY_SNAKEundefined
      ICY_SNAKE @fcwilt
      @fcwilt said in Correction of heightmap is not really working:
      o think the correc
      yes, because the thickness of the buildplates are different.
      also another question do i need the
      G31 P500 x-18 y24 Z3.005
      in the config.g and also in the config_probe.g??
      DO IT OR DON'T
      • fcwiltundefined
        fcwilt @ICY_SNAKE
        @icy_snake said in Correction of heightmap is not really working:
        I understand that but if the correct value for G31 is always the same for each buildplate you could just have a macro which sets the new value as opposed to determining the value each time.
        What you should do is remove all three of the probe configuration commands from config.g and replace them with the M98 P"probe_config.g" command. That way the probe will be configured after a reboot or restart. Not essential but it insures the probe is ready to go if you were to issue a command like G30 from the DWC.
        ICY_SNAKEundefined 1 Reply Last reply Reply Quote 0
          ICY_SNAKE @fcwilt
          @fcwilt ok
          so i need only one macro to set the z, correct?
          DO IT OR DON'T
          • fcwiltundefined
            fcwilt @ICY_SNAKE
            @fcwilt ok
            If the value for each buildplate is constant you can eliminate editing of the probe_config.g file by using a global variable to hold the G31 Z Trigger Height value.
            Then you can have one macro for each buildplate to set the variable to the correct value for that buildplate.
            How does that sound?
              ICY_SNAKE @fcwilt
              @fcwilt Yes that would be prefect
              DO IT OR DON'T
              ICY_SNAKEundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                ICY_SNAKE @ICY_SNAKE
                @icy_snake could you write that for me, please?
                DO IT OR DON'T
                • fcwiltundefined
                  fcwilt @ICY_SNAKE
                  OK I will code that.
                  In the meantime here is the macro for measuring the Z probe trigger height - if you ever need it.
                  M300 S666 P666               ; beeo
                  M291 S3 R"Test Z Probe Trigger Height" P"Press OK to continue, or CANCEL to abort"
                  G28                          ; home all
                  G29 S2                       ; cancel mesh bed compensation
                  M290 R0 S0                   ; cancel baby stepping
                  G90                          ; absolute movements
                  ; this complicated looking command computes the X and Y parameters needed to move the probe to the center of the bed
                  G1 X{((move.axes[0].max + move.axes[0].min) / 2) - sensors.probes[0].offsets[0]}, Y{((move.axes[1].max + move.axes[1].min) / 2) - sensors.probes[0].offsets[1]}, F1800
                  M300 S1111 P666              ; beep
                  M564 H1 S0                   ; ignore axis limits
                  M291 S2 R"Test Z Probe Trigger Height - Step 1" P"Place a paper sheet under the nozzle and raise the bed until slight friction can be noticed" Z1 ;
                  G92 Z0                       ; the nozzle should now be just touching the bed so set the logical Z position to match the physical Z position
                  M300 S666 P666               ; beep
                  M291 S2 R"Test Z Probe Trigger Height - Step 2" P"Please remove the paper sheet and wait for the bed-probing to begin" ;
                  G1 Z5 F200                   ; insure Z position will allow for probing
                  G30 S-1                      ; probe the bed and report the Z probe trigger height
                  M564 S1 H1                   ; respect axis limits
                  M291 S2 R"Test Z Probe Trigger Height - Step 3" P"Copy the reported height value on the G-Code console and paste it into the probe_config.g file"
                  • fcwiltundefined
                    fcwilt @ICY_SNAKE
                    @icy_snake
                    Add this near the start of your config.g:
                    global g_probe_z_trigger   = 1.8                ; default - set as appropriate for the Z probe
                    Just for reference this is what the start of my config.g file showing the section where I set all my global variables:
                    ; prologue
                    M111 S0				; debug off
                    M550 P"MF1"			; machine name
                    ;M551 P"xxxxxx"                 ; machine password
                    M555 P2                         ; set output to look like Marlin
                    M575 P0 B57600 S2               ; communication parameters for USB serial
                    M575 P1 B115200 S1              ; communication parameters for PanelDue
                    M552 S1                         ; enable (S1) networking (WiFi)
                    M586 S1 P1 ;T0                  ; enable (S1) FTP    (P1) Disable TLS (T0)
                    M586 S1 P2 ;T0                  ; enable (S1) Telnet (P2) Disable TLS (T0)
                    G21                             ; dimensions in mm
                    G90                             ; for X,Y,Z     use absolute coordinate values
                    M83                             ; for E0,E1,etc use relative coordinate values
                    ; mode control variables
                    global g_z_home            = 5                  ; can be used to always move Z to known height
                    global g_z_datum_set       = false              ; can be used to prevent unneeded setting of Z=0 datum
                    global g_map_mode          = "300 point"        ; determines which kind of height map is created/loaded
                    global g_probe_mode        = "two consecutive"  ; determines if z proving used consecutive or averaging
                    global g_level_mode        = "3 point"          ; determines if 3 or 4 points are used for leveling
                    global g_print_beg_prime   = 10                 ; default - set desired in filament config.g
                    global g_print_beg_retract = 0                  ; default - set desired in filament config.g
                    global g_print_end_retract = 0                  ; default - set desired in filament config.g
                    global g_print_end_mode    = "heat off"         ; determines if heaters are turned off when print is done
                    In your probe_config.g file update your G31 command to replace the value after the Z parameter with the variable reference shown below:
                    G31 P25 X0 Y24.5 Z{global.g_probe_z_trigger}  ; set Z probe trigger value, offset and trigger height (larger value is closer)
                    Create the macros to set the global variable to the needed values. Name them as you desire. Here is an example:
                    set global.g_probe_z_trigger = 1.8 ; set the variable
                    M98 P"probe_config.g"              ; configure the probe using the new value
                    ; I put this G31 here just to show the current settings - it is optional
                    ; You can provide visual feedback some other way, say, using an M291 command
                    G31
                    ICY_SNAKEundefined 1 Reply Last reply Reply Quote 1
                      ICY_SNAKE @fcwilt
                      @fcwilt Whowww, many thanks Frederick,
                      perfect support, you helped me alot, thanks again.
                      I´m often in the USA for business. Maybe there will be a day that we could have some drinks.
                      Best Regards
                      Dieter
                      DO IT OR DON'T
                      ICY_SNAKEundefined fcwiltundefined 2 Replies Last reply Reply Quote 1
                        @icy_snake I´m already home today, here it´s evening.
                        I will add tomorrow the new code. I let you know if i could get it running.
                        Good evening
                        Dieter
                        DO IT OR DON'T
                        • fcwiltundefined
                          fcwilt @ICY_SNAKE
                          Best Regards
                          Dieter
                          That would be grand but I am located in South West Virginia. The closet city is Roanoke to give you a reference.
                            The trigger height for the BLTouch should stay the same between different build plates since it physically touches the build plate and the offset between the bltouch trigger point and the nozzle remains constant. That's one of the main benefits of a BLTouch.
                            fcwiltundefined 1 Reply Last reply Reply Quote 2
                            • fcwiltundefined
                              fcwilt @Phaedrux
                              @phaedrux
                              Yes it should. Hopefully this will be a good learning experience for Dieter.
                                ICY_SNAKE @fcwilt
                                @fcwilt hahah yes it was and it is and will be in the future.
                                thx all for the perfect help here.
                                Dieter
                                DO IT OR DON'T
                                • fcwiltundefined
                                  fcwilt @ICY_SNAKE
                                  @icy_snake
                                  Morning.
                                  Once you have verified that everything we have done on so far is working we can move on to the last piece of the puzzle - your "start" code - the code that is executed at the start of a print to get everything set as needed for a successful print.
                                    ICY_SNAKE @fcwilt
                                    @fcwilt Good morning frederick,
                                    here is my start gcode in ideamaker.
                                    It works, need to do anything after i hit the start button:
                                    <G28                         	; Home
                                    M566 E3000		; max speed change
                                    M572 D0 S0.07	        ; pressure calibration value 0.01 bis 0.12
                                    G92 E0		        ; Reset the extruder
                                    G0 Z20           	        ; Z down bei 20
                                    G0 X0 Y0 F6000         ; Go to left front
                                    G92 E0
                                    G1 E50 F350           	; Extrude 50mm speed 350,time to clean head
                                    G92 E0
                                    G0 X100 Y10 F9000  ; Move quickly to X100 Y10, cut the string automaticly
                                    G0 Z0.3                	; Lower Z to 0.3
                                    G1 F1000 X200 E3 	; print line to x200 speed 1000
                                    G92 E0
                                    G1 F800 E-0.3		; retract -0.3mm
                                    M117 Printing..the..new..model.>
                                    Here is my End Gcode:
                                     <G1 F800 E-1.0	;retract filament 1.0mm to prevent oozing
                                     M104 S0 T0	 	; turn off hotend 1
                                     M104 S0 t1		; turn off hotend 1
                                     G90		                ; use absolute coordinates
                                     G28 X0 Y0	 	; Move to Home without Z
                                     M221 D0 S100 	; extrusion Factor back to 100
                                     M106 S0 T0    	         ; turn off fan 1
                                     M106 S0 T1		; turn off fan 2
                                     M84	 	                ; Switch off all Motors
                                     M117 Ready..with..the..new..model--have fun!>
                                    Let me know what you think.
                                    DO IT OR DON'T
                                    • fcwiltundefined
                                      fcwilt @ICY_SNAKE
                                      @icy_snake
                                      I gather most of that code is for priming the extruder?
                                      I don't see any code to:
                                      • set heater temp
                                      • set bed temp
                                      • load height map
                                      Where is that being done?
                                        ICY_SNAKE @fcwilt
                                        @fcwilt Ok thats what you mean
                                        heater temp i set i my ideamaker
                                        bed temp i ned to set manually at an extra hardware, cannot be set via software
                                        load heightmap i do not know to load it before printing??
                                        G29 S1
                                        do i need to reload always the heightmap before printing?
                                        Dieter
                                        DO IT OR DON'T
                                        ICY_SNAKEundefined Stephen6309undefined fcwiltundefined 3 Replies Last reply Reply Quote 0
                                          thats the printsize 600x600mm
                                          my test stl
                                          DO IT OR DON'T
                                          • Stephen6309undefined
                                            Stephen6309 @ICY_SNAKE
                                            @icy_snake Load the heightmap after the G28. You do have to load the heightmap.
                                            Basic example, this runs the mesh everytime:
                                            G28
                                            G29 ; add S1 just to load the current one
                                            I use this mesh.g , it makes the heightmap if it doesn't exist and makes sure the printer has been homed before the G29 S0, just call it with G29.
                                            M561            ; clear any bed transform
                                            G29 S1          ; load heightmap.csv
                                            if result > 1   ; make if it doesn't exist
                                              if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed ; check if homed
                                               G28
                                              G29 S0        ; create heightmap.csv
