    What firmware version are you using?
    47
    3.6k
    • EducatingSavvasundefined
      EducatingSavvas @dc42
      @dc42 Does that mean if R in M950 and P in M563 are the same number during CNC mode, I would not need to write P# when using an M3 command? Should any spindle defining commands be in the tfree#.g tpre#.g and tpost#.g? That is to say I load the spindle separately from config.g file?
      I think the confusion with CNC is that you have the spindle and the bits, or tangential knife and blades are referred and all are referred to as tools. And that on a CNC mills the tool database in often part of a complicated control system, while for flat-bed panel CNC machine the tool database in part of the CAM software.
        dc42 administrators @EducatingSavvas
        @educatingsavvas said in What firmware version are you using?:
        Yes.
        There is no need to do that. In config.g, define all your spindles, then for each tool specify which spindle it uses in its M563 command.
        EducatingSavvasundefined 1 Reply Last reply Reply Quote 1
          Not sure if this got noted @dc42 but I'm finding I still have to write the P# for the M3 command to work - I've start a separate post about this.
          • manpowreundefined
            manpowre
            3.4 beta2 on my Flsun QQ-S pro with duet3d 2 wifi. upgraded today. I had 3.3 beta 2 before this. All working as it should.
            The reason I upgraded was the bugfix for loosing z0 position of bed when homing delta. And I want to try out the accelerometer part. just gotta get the accelerometer and hook it up next week.
            • massimilianocontiundefined
              massimilianoconti
              3.4 beta 2 but has some problems I'm not happy
              • fcwiltundefined
                fcwilt @massimilianoconti
                @massimilianoconti said in What firmware version are you using?:
                Well it is a beta version.
                I never attempt to use a beta version in a production printer but I will test them on my workbench where I have a set of electronics for just for testing things like that.
                massimilianocontiundefined 1 Reply Last reply Reply Quote 0
                  massimilianoconti @fcwilt
                  @fcwilt ok however even previous versions like 3.3 were not so good, every now and then it turns out an inconsistent behavior that has no logic. there is something in the firmware that is not good is not reliable completely. I also have a zortrax and I assure you that it does not miss a beat does what it must always do perfectly
                  • fcwiltundefined
                    What problems are you seeing?
                    I have four printers using very different designs all running 3.3 on both Duet 2 and Duet 3 hardware and they print just fine.
                    • Monkey68undefined
                      Monkey68
                      well i have 3.3 but it has rendered my printer useless
                      • pokeveundefined
                        pokeve @JuJuDelta
                        @jujudelta Same here, My setup is exactly same.
                        • tfjieldundefined
                          tfjield
                          3.4.1. It's not in the poll.
                          • Phaedruxundefined Phaedrux locked this topic
                          • Phaedruxundefined Phaedrux unpinned this topic
