    Z-Probe triggers, and remains triggered
    Accessories and Add-ons
    • ehutzellundefined
      ehutzell
      I have a Duet 2 Wifi with a Precision Piezo set up in digital mode. I had some initial trouble setting it up, but now the Z-Probe will trigger, but will never untrigger. The leds on the Zprobe still trigger correctly. Any thoughts on solutions? Config pasted below.
      Config
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed Jun 16 2021 15:39:56 GMT-0400 (Eastern Daylight Time)
      M550 P"FT6" ; set printer name
      M551 P"harold" ; set password
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S1 ; physical drive 0 goes backwards
      M584 X2 Y1 Z0 E3 ; set drive mapping
      M92 X80.00 Y80.00 Z722.00 E420.00 ; set steps per mm
      M84 S30 ; Set idle timeout
      M208 X350 Y720 Z400 S0 ; set axis maxima
      M574 X1 S1 P"!zstop" ; configure active-low endstop for low end on X via pin zstop
      M574 Y1 S1 P"!ystop" ; configure active-low endstop for low end on Y via pin ystop
      M574 Z1 S2 ; use z probe as endstop
      M558 C"!e0stop" P5 R0.4 F300 T6000 ; precision piezo, digital mode, NO/NC, delay, speed, not used as axis endstop
      G31 P900 X0 Y0 Z-0.1 ; X, Y, Z offsets, debounce interval
      M557 X25:325 Y20:700 P4:10 ; define mesh grid
      M307 H0 R0.416 C361.2 D3.91 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit
      M307 H1 R2.428 C222.6 D7.17 S1.00 V27.5 ; disable bang-bang mode for heater and set PWM limit
      M143 H1 S300 ; set temperature limit for heater 1 to 300C
      M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency. Part Cooling Fan.
      M106 P0 S0 H-1 C"BERD AIR" ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency. Hotend Fan.
      M950 F2 C"fan2" Q500 ; create fan 1 on pin fan1 and set its frequency. CPU Fan.
      M106 P2 S1 H0 T40 ; set fan 1 value. Thermostatic control is turned on
      M563 P0 D0 H1 F0 S"Extruder" ; define tool 0
      M591 D0 P3 C"e0_stop" C3 R40:120 E3.0 S0 ; filament monitor connected to E0_stop M591 D0 P5 S1 L25.70 R70:130 E3.00
      T0 ; select first tool
      SIamundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
        How do you mean it never untriggers?
        ehutzellundefined 1 Reply Last reply Reply Quote 0
        • SIamundefined
          SIam @ehutzell
          @ehutzell said in Z-Probe triggers, and remains triggered:
          Í would say you have to activate the internal pullup resistor.
          M558 C"^!e0stop" P5 R0.4 F300 T6000
          Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
          Duet WiFi 1.02 or later + DueX5
          RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
          Duet WiFi Server: 1.26
          Duet Web Control 3.4.0beta4 (2021-09-27)
          ehutzellundefined 1 Reply Last reply Reply Quote 1
          • ehutzellundefined
            ehutzell @Phaedrux
            @phaedrux The z probe value in duet web control is at 0 before trigerring, and remains at 1000 after triggering.
              Phaedrux Moderator @ehutzell
              G31 P900
              It sounds as though it reaches the trigger threshold but never leaves it. I'm not familiar with what Precision Piezo recommends for the trigger value.
              • ehutzellundefined
                ehutzell @SIam
                @siam This fixed the issue, thank you.
