    Does anyone here work on Superslicer?
    87
    8.6k
    • resamundefined
      resam @chrishamm
      @chrishamm lol - yeah, good idea of mine to ask for a sanity check 😛 Thanks for catching that typo!
      I'll ask again about resolutions: what do you want, or what can you/DCW/RRF/DSF handle? I read that PanelDue can do a max. of 160x160.
        dc42 administrators @resam
        @resam said in Does anyone here work on Superslicer?:
        yeah, good idea of mine to ask for a sanity check Thanks for catching that typo!
        Actually that typo was made by the devs of PrusaSlicer; but they later corrected it.
        I don't have a latest build of PrusasSlicer, so I don't know whether they use thumbnail_end or thumbnail_QOI end.
        resamundefined 1 Reply Last reply Reply Quote 0
        • resamundefined
          resam @dc42
          @dc42 indeed! https://github.com/prusa3d/PrusaSlicer/commit/086662b6a1c7d7a14e35a90e6d46445f6871ac24 fixes it - so I probably copy-pasted it.
          The end tag is the same tag as the begin, so thumbail_QOI. See https://github.com/prusa3d/PrusaSlicer/commit/87cff55856ae14096cd57f8e2542f1f1caef7167#diff-e09699df9f3fa4c292ba50b9f88dffe95b2d2d5c0a58d9d81441f9da5031c97bR49
          0 bubnikv committed to prusa3d/PrusaSlicer
          Fixed typo in thumbnail_QOI tag.
          9 bubnikv committed to prusa3d/PrusaSlicer
          WIP: Implemented support for QOI G-code thumbnail format as requested
          by the RepRapFirmware team due to their low RAM budget for decompression.
          Bundled the QOI image compression library.
            @resam thanks for that. We'll need to change RRF and probably DSF then.
            resamundefined 2 Replies Last reply Reply Quote 0
            • resamundefined
              resam @dc42
              @dc42 ok - my Cura plugin behaves the same way as PrusaSlicer.
              • resamundefined
                resam @dc42
                @dc42 please also update the code comment at https://github.com/Duet3D/RepRapFirmware/blob/09bf6d01b6028c7d7d162f0e2b60ca8a07849901/src/Storage/FileInfoParser.cpp#L959-L961
                and am I reading RRF constant MaxThumbnails = 3 correctly, that the fourth thumbnail will not be parsed by RRF? My Cura plugin currently outputs 4 sizes... so again my question about resolutions?
                • chrishammundefined
                  chrishamm administrators @resam
                  @resam That limitation applies to RRF but not DSF. For the DWC filelist the ideal resolution is 48x48px and there is no real upper limit for previews. For PanelDue the maximum thumbnail height appears to be 6 x rowTextHeight. That means we have effective height limits of 126px for small displays and 192px for larger displays.
                  Duet software engineer
                    dc42 administrators @chrishamm
                    For PanelDue the recommended image size is 160x160 pixels. That size works on all three screen sizes.
                    • ICY_SNAKEundefined
                      ICY_SNAKE
                      @dc42 said in Does anyone here work on Superslicer?:
                      ecause QOI for
                      I work with ideamaker and have the possibility to add content of data into gcode file. Thumbnail 640x640 or any other value.
                      Would be nice if it would be used on your side.
                      thx
                      Deiter
                      DO IT OR DON'T
                        dc42 administrators @ICY_SNAKE
                        @icy_snake for PanelDue the optimum size is 160x160. DWC can use a wider variety of sizes, however RRF can only use the first 3 thumbnail images in the file.
                        Exerqtorundefined 1 Reply Last reply Reply Quote 1
                        • Exerqtorundefined
                          Exerqtor @dc42
                          Anyone got a "sample gcode" with some sort of thumbnail that they can share just to see how the thumbnails look on DWC / Paneldue? 🙄
                          • resamundefined
                            resam @Exerqtor
                            @exerqtor https://github.com/Duet3D/DuetSoftwareFramework/blob/v3.4-dev/src/UnitTests/File/GCodes/Thumbnail_QOI.gcode
                            ICY_SNAKEundefined Exerqtorundefined 2 Replies Last reply Reply Quote 2
                              ICY_SNAKE @resam
                              @resam Here is a sample code
                              Box_2_led-rar.txt
                              rename to .rar
                              includes a 160x160 thumbnail in the gcode plus an thumbnail for octoprint and Mainsail.
                              Dieter
                              DO IT OR DON'T
                              • Exerqtorundefined
                                Exerqtor @resam
                                @resam
                                Worked a treat, thx! 😃
