    Duet3D 1HCL - Closed Loop Controller Beta test
    Hardware dev
    20
    209
    19.1k
      T3P3Tony administrators @A Former User
      @gruna-studio I am using the default step timing (i.e. no T parameters in M569)
      • samlogan87undefined
        samlogan87
        @dc42 or @T3P3Tony has stall detection been implemented on these boards? Thinking of getting rid of the end stops if possible
        Custom Core-XY
          @samlogan87 stall detection should work in open loop mode, however RRF cannot yet use stall homing for motors connected to expansion boards.
          samlogan87undefined 1 Reply Last reply Reply Quote 0
            samlogan87 @dc42
            @dc42 bugger. Thanks for that. Any idea when it might be implemented
            Custom Core-XY
              @samlogan87 we're planning to implement it in RRF 3.5.
              Note, stall homing is less accurate than homing using a switch; so not recommended if you want to support resume-after-power-fail.
                A Former User @T3P3Tony
                @t3p3tony
                Ok thanks a lot
                I have constant layer shift on X axis. Can't solve it since days and several more boards are on the way.
                Open a thread was not helping because nobody answered. Haha
                Please help me
                  @gruna-studio I saw you deleted the thread, I was not sure why. Do you want to restore that thread so we can discuss the issue there? If you like I can restore the thread for you.
                    @t3p3tony
                    I have already trying a lot of things, so that this thread wasn't actual anymore.
                    Then I made a new one which is still online but after two days I could delete that, too.
                    It's also not up to date anymore.
                    I'm Sorry
                    So I'll change the boards and motors later on and will make a new thread.
                    Did you use 48 volt?
                    I "saw" a shift. The motor was less noisy and slower then normal for a short second. Like you shift in a to low gear in a car.
                    Thanks for you reply
                    I just ordered 4 more 1HCL - I'm very optimistic
                    Thanks
                    Richard
                      @gruna-studio please do repost with an uptodate setup.
                      I used 24V on my printer thus far.
                      • cloudseedsundefined
                        cloudseeds @T3P3Tony
                        @t3p3tony Thanks, snagged some up at Compass! Excited to try them!
                          samlogan87
                          Finally got the printer back up and running after rebuilding most of the mechanism. Still need to square it up as I think some of the noise is rail misalignment. That’s 1000mm/s at 30000mm/s acceleration using 48v to drive the boards
                          https://youtu.be/Mn7kX0dptjs
                          Custom Core-XY
                            A Former User @samlogan87
                            @samlogan87
                            Nice
