    Duet3D 1HCL - Closed Loop Controller Beta test
    Hardware dev
    20
    209
    19.0k
      dc42 administrators @alankilian
      @alankilian a 1000 PPR (pulses-per-rev) quadrature encoder provides 4000 CPR (counts per rev, better called transitions per rev). The EXP1HCL board uses all 4000 transitions. The 4 transitions that occur in the time of 1 pulse probably won't be as evenly spaced as the pulses, but using them still provides a benefit over using just the pulse count.
      @gruna-studio if the encoder spec is 1000 PPR (not 1000 CPR) then the resolution should be OK. We've only tried one system using a separate encoder (not from stepperonline) and we've had poor results; but that may be caused by something else on that machine. If you do use a separate encoder, you need to make sure there is no added backlash in the encoder caused by it being separate from the motor. So the mounting of the encoder on the shaft and the encoder body on the motor need to be rigid. As long as the EXP1HCL is in beta test and not a fully released product, we'd rather you use stepper motors with integrated encoders, so that we can be fairly sure that any issues you report are not caused by poor coupling of the motor to the encoder.
      A Former User? 2 Replies Last reply Reply Quote 0
        A Former User @dc42
        This post is deleted!
          A Former User @dc42
          I just got my boards! thanks a lot to providing me in this early stage. 😄
          I saw there are some changes to the version 0.3. Is there already a wiring diagramm?
          cheers
          Richard
            @gruna-studio latest EXP1HCL documentation is at https://docs.duet3d.com/en/Duet3D_hardware/Duet_3_family/Duet_3_Expansion_1HCL.
            Alex.crundefined 1 Reply Last reply Reply Quote 0
            • Alex.crundefined
              Alex.cr @dc42
              @dc42 @T3P3Tony
              Any idea when 1HCL will be available to US resellers?
              Voron2.4/Duet3 SBC+6HC+3HC+1LC+1HCL(x2) - Delta/Duet2 Wifi - CubePro/Duet2 Wifi+Duex5 - Laser/Duet3 Mini5+ - Cel Robox - U̶p̶3̶0̶0̶+/D̶u̶e̶t̶3̶ ̶6̶H̶C̶+̶LC1̶ - F̶T̶-̶5̶/̶D̶u̶e̶t̶2̶ ̶W̶i̶f̶i̶ - S̶o̶l̶i̶d̶o̶o̶d̶l̶e̶
                T3P3Tony administrators @Alex.cr
                @alex-cr we have orders in from at least Filastruder (need to check with the other ones). I hope we will start shipping reseller orders to them next week.
                Alex.crundefined cloudseedsundefined 2 Replies Last reply Reply Quote 2
                • Alex.crundefined
                  Alex.cr @T3P3Tony
                  @t3p3tony
                  Much appreciated!
                  • cloudseedsundefined
                    cloudseeds @T3P3Tony
                    @t3p3tony Anything for Germany/Europe? I am currently testing 1XD with SERVO42C but that makes little sense if 1HCL is available soon.
                    • madmattcoundefined
                      madmattco
                      Apologies if this was addressed before but I was wondering why the choice of using the 5160 and it's built-in encoder input was not used?
                        T3P3Tony administrators @cloudseeds
                        @cloudseeds we have dispatched some to Compass-DHM and Dold Mechatronic , I hope both of them will list them soon.
                        DHM-onlineundefined cloudseedsundefined 2 Replies Last reply Reply Quote 0
                          dc42 administrators @madmattco
                          @madmattco the EXP1HCL uses the TMC2160A because it supports the direct coil current control that we need for closed loop node. The TMC2160A does not support an encoder. In any case, reading the encoder using the built-in encoder support in the MCU is faster than reading from the stepper driver over SPI.
                          • martin7404undefined
                            martin7404
                            I have a question can I use mini with 1HCL board ?
                            Muldex IDEX Duet2+Duex5
                            Custom CoreXY 600x400 Hemera , Duet3+Toolboard+1HCL closed loop
                            Sapphire Pro with Duet2, with closed-loop motors
                            custom high temp E3D tool changer with Duet2+Duex
                              T3P3Tony administrators @martin7404
                              @martin7404 yes you can use it with any of the Duet 3 Mainboards (6HC, 6XD and Mini 5+)
                              CNCModellerundefined 1 Reply Last reply Reply Quote 0
                              • CNCModellerundefined
                                CNCModeller @T3P3Tony
                                Hi @t3p3tony,
                                Are there any 1HCL units on the way to UK resellers? I've checked E3D and Oozenest and nothing is showing there at the moment.
                                Many thanks
                                Barry M
                                Polar Duet3 Mini + 1HCL
                                https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
                                Wanhao D4S: Duet2
                                https://forum.duet3d.com/post/296755
                                K40 Laser, Duet2
                                https://forum.duet3d.com/post/312082
                                Wanhao D5S
                                https://www.youtube.com/CNCModellerUK
                                  Any one using EXP1HCL boards with firmware 3.4.0RC1, please upgrade the EXP1HCL firmware to 3.4.0RC1+2 available at https://www.dropbox.com/sh/2dt7sbqpx6l74np/AADn4-lpcil1iqnWKkiVri3Ia?dl=0.
                                  supertb1undefined 1 Reply Last reply Reply Quote 0
                                  • tristanryerparkeundefined
                                    tristanryerparke
                                    Has there been any progress on simultaneous tuning of two motors driven by individual 1HCL? I’m looking to control a dual motor Y axis gantry with auto squaring.
                                    Thanks
                                    MaxGyverundefined A Former User? 2 Replies Last reply Reply Quote 0
                                    • MaxGyverundefined
                                      MaxGyver @tristanryerparke
                                      @tristanryerparke said in Duet3D 1HCL - Closed Loop Controller Beta test:
                                      Thanks
                                      Same Here 😁
                                      • wayneosdiasundefined
                                        wayneosdias
                                        When is the 1HCL slated for production resale?
                                          A Former User @tristanryerparke
                                          @tristanryerparke
                                          Same here! 🐶
                                            T3P3Tony administrators @wayneosdias
                                            @wayneosdias depending on where you are some resellers will already have them or will get them shortly.
