    PT100 amplifier board - redaings seems to be 30 degrees below
    1.8k
      dc42 administrators @tony449777
      @tony449777 said in PT100 amplifier board - redaings seems to be 30 degrees below:
      @dc42 I can’t attach a picture, it will not let me however I can tell you R1 is marked”102” while R2,R3,R4 are all marked “201”
      Why can't you attach a picture?
      Do both channels give the wrong reading when you connect the 100 ohm resistor to each in turn?
      tony449777undefined 2 Replies Last reply Reply Quote 0
        Also curious, if the channel 1 on the daughter board is “spi.cs1”
        And you have one daughter board with the two ports, then is the second port for the same card “spi.cs2”?
        Yes.
        • tony449777undefined
          tony449777 @dc42
          @dc42 yes
            tony449777 @dc42
            @dc42 I’m using the phone application. Every time I try to attach a picture it just says undefined.
              @tony449777 it's easier from a PC, you can just drag and drop a .jpg file into your post.
              tony449777undefined 1 Reply Last reply Reply Quote 0
                tony449777 @dc42
                @dc42 Update. Switched out the daughter board for another one I purchased from filastruder and it works fine. It must be the board.
                  Phaedrux Moderator @tony449777
                  I believe I got this daughterboard from Filastruder. It was purchased a while ago, but never used until this build.
                  How long is a while ago?
                  • c310undefined
                    c310
                    @dc42 my 2nd channel died :I( i will be replaceing the chip, on the way want to check other parts. there are 2 pairs of capacitors - c1/c2 + c5/c6 what its default capacity should be?
                    also there is small black SMD element in between C1 and R1. what is it? what are the parameters?
                    many thanks!
                      T3P3Tony administrators @c310
                      @c310 the schematic for the board is here:
                      https://github.com/Duet3D/TempDaughterboards/blob/master/MAXTempRTD/MAXTempRTDv1.1.pdf
                      I assume you are refering to the inductor L1:
                      two screen shots depending on the version of the PT100 db you have.
                      it is an inductor such as LB2012T101K
                      c310undefined 1 Reply Last reply Reply Quote 0
                      • c310undefined
                        c310 @T3P3Tony
                        @t3p3tony said in PT100 amplifier board - redaings seems to be 30 degrees below:
                        LB2012T101K
                        thank you @T3P3Tony !!!!
