    Read Output pin state
    Using Duet Controllers
    8
    44
    2.7k
    • wayneosdiasundefined
      wayneosdias
      FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.4.0beta7 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2021-12-16 12:22:39
      I have an actuator setup as;
      M950 P3 C"out3" Q20000		;Dragpin Actuator
      and state sensor for this actuator as;
      M950 J0 C"io3.in" 			;DragPin Sensor
      Actuating and sensing work as intended and fine. My motion planner, Openpnp, also needs to know the output state and I cannot figure out how to attain this.
      I tried M950, but this just reports the pin config
      M950 P3
      > GPIO/servo port 3 pin out3 frequency 20000Hz
      > ok
      I tried M308
      > M308 P3
      Error: M308: missing parameter 'S'
      ok
      What command can I issue to get the current output state on an output pin, not the config, not the sensor, but the commanded state of an output pin?
      SIamundefined 1 Reply Last reply Reply Quote 0
      • SIamundefined
        SIam @wayneosdias
        @wayneosdias
        You have to use the object model
        sensors.gpIn[3].value
        This should return the state of gpio 3
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
        wayneosdiasundefined 1 Reply Last reply Reply Quote 1
          wayneosdias @SIam
          @siam said in Read Output pin state:
          Can you elaborate on how to setup the object model? Actual step by step
          Thanks Wayne
          > SENSORS.GPIN[3].VALUE
          Error: Bad command: SENSORSGPIN[3]VALUE
          ok
          SIamundefined Stephen6309undefined 2 Replies Last reply Reply Quote 0
          • SIamundefined
            SIam @wayneosdias
            @wayneosdias you have to write a macro, see the docs here:
            https://duet3d.dozuki.com/Wiki/Macros
            wayneosdiasundefined 1 Reply Last reply Reply Quote 0
            • Stephen6309undefined
              Stephen6309 @wayneosdias
              @wayneosdias The object model is case sensitive. DWC can show the object model, it's at the bottom of the left panel.
                wayneosdias @SIam
                @siam
                This is where I get lost,
                RepRapFirmware allows for gcode sequences, called macros...
                Great, what's the GCode for retrieving the current output state on an output pin? Ill happily put it into a macro...
                OwenDundefined 1 Reply Last reply Reply Quote 0
                  wayneosdias @Stephen6309
                  @stephen6309
                  Thanks Stephan
                  I see it here in the DWC
                  .3 is correct. Now how do I get this value into Openpnp via serial/USB?
                  I tried this
                  state.gpOut[3].value
                  Error: Bad command: stategpOut[3]value
                  ok
                  • OwenDundefined
                    OwenD @wayneosdias
                    @wayneosdias
                    The answer was provided.
                    The gcode is the object model query
                    https://github.com/Duet3D/RepRapFirmware/wiki/Object-Model-Documentation#overview
                    You should also search on duet meta commands.
                    However...
                    You said you're using openPNP
                    How does that communicate with the Duet?
                    I thought it used its own software.
                    It will make a difference whether it runs completely on the Duet, or whether it's connected via a USB cable or uses TCP socket connection.
                      wayneosdias @OwenD
                      @owend
                      OpenPnp is the motion planner, it is connected via native USB.
                      • OwenDundefined
                        OwenD @wayneosdias
                        @wayneosdias
                        So the questions becomes from where do you need the information extracted and passed to?
                        What are you trying to achieve?
                        If the query/answer will be used purely on the duet, the you can use the object model and conditional gcode to do it.
                        If you need to pass the gpio state back to your external motion planner via usb then I suspect something like M118 will need to be used, however I have no direct knowledge of openPNP
                        EDIT:
                        Can you use something like
                        M118 P1 S{state.gpOut[3].value} L0
                        This should send the IO state via USB
                          wayneosdias @OwenD
                          @owend said in Read Output pin state:
                          First thanks for everyones help thus far;
                          What Im trying to achieve is a 'component feed' as follows;
                          • machine XY's head mounted drag pin to component tape hole
                          • machine actuates drag pin
                          • drag pin is in down position inserted into tape hole
                          • machine 'drags' tape in X direction to feed next component into postion
                          • drag pin is de activated
                          • machine XY's head mounted nozzle to component
                          • ... and completes the pick process.
                          In this process there is an issue where the drap pin may be stuck down despite being de activated. To prevent XY motion in the case of a stuck drag pin there is a dragpin sensor. In Openpnp his is referred to 'Axis Interlock'. We dont dont want XY with a down drag pin UNLESS the dragpin is actuated to do so as in a feed event.
                          Boiling this all down is;
                          • we want XY movement when the drag pin is actuated and sensor states it so
                          • we dont want XY movment when the drag pin is de activated and sensor
                            states it so
                          Circling back to the original question. What Gcode can I use to get the current output state of an output pin?
                          • OwenDundefined
                            OwenD @wayneosdias
                            @wayneosdias
                            Either you are not actually reading any of the responses given, or there is some sort of communication or translation issue.
                            You have been told several times that the Gcode is
                            where 3 is the sensor number of an output pin.
                            or
                            where 3 is the sensor number of an input pin
                            If your sensor is connected to the duet, then it is an INPUT
                            Your Gcode needs to contain something like
                            while sensors.gpIn[3].value = 1
                                G4 P500 ; if the sensor level is high, go into a wait loop
                            You are unlikely to get working code unless you find someone who also uses openPNP, but you have been provided ample information to work it out.r
                              dc42 administrators @wayneosdias
                              @wayneosdias said in Read Output pin state:
                              I tried this
                              ok
                              Try this:
                              echo state.gpOut[3].value
                                wayneosdias @dc42
                                @dc42 said in Read Output pin state:
                                Hey dc
                                I tried but still get...
                                Error: Bad command: echostategpOut[3]value
                                ok
                                Stephen6309undefined 1 Reply Last reply Reply Quote 0
                                  wayneosdias @OwenD
                                  @owend
                                  I have read and tried all responses thoroughly before each and every response. I think you may be having difficulty understanding the question. But it's stated pretty explicitly.
                                    @wayneosdias If you want the pwm value, use state.gpOut[3].pwm. You can't get undefined items.
                                      @stephen6309 said in Read Output pin state:
                                      state.gpOut[3].pwm
                                      Thanks Stephen,
                                      I cant get that to work either
                                      > echo state.gpOut[3].pwm
                                      Error: Bad command: echostategpOut[3]pwm
                                      ok
                                      > state.gpOut[3].pwm
                                      Error: Bad command: stategpOut[3]pwm
                                      ok
                                      > M118 P1 S{state.gpOut[3].pwm} L0
                                      Error: M118: unknown value 'stategpOut^pwm'
                                      ok
                                      Stephen6309undefined gloomyandyundefined 2 Replies Last reply Reply Quote 0
                                        @wayneosdias I don't have any gpio pins defined, but 0 is there.
                                        Currently on rrf 3.4.0rc2
                                        Sending in the DWC Console:
                                        echo state.gpOut[0].pwm
                                        This shows up in the DWC Console:
                                        0.0736
                                        Object Model in DWC shows 0.07
                                        • gloomyandyundefined
                                          gloomyandy @wayneosdias
                                          @wayneosdias What program are you using to send those commands? It looks like something is removing some of the characters before they are sent to the Duet.
                                            @stephen6309 Hey Stephen
                                            I need response via USB to Openpnp. DWC is connected via ethernet
