    3.4.0beta7 - RC2 overheating when the model fan is turned on
    Beta Firmware
    503
    • Del87undefined
      Del87
      There are some strange behavior on heater when the model fan turns on high/low speed.
      Firmware 3.4.0beta6 - straight line temperature, maximum deviation +0.5 degree when model fan 100%.
      Firmware 3.4.0beta7-3.4.0RC2 - +1 degree on 2-3 layers of the model (fan 15-30%). +2 degree when model fan 100%.
      PID calibration new/old doesnt matter - same behavior.
      Duet 3 mini 5+ Pt1000
      And a small note: same models printed 3.4.0beta6 - no messages about driver0 stuck , 3.4.0RC2 - there was messages. I use sensorless homing, is there some changes mentioned in upgrade notes?
      Dmitry
      • Phaedruxundefined Phaedrux moved this topic from Firmware developers
        Can you give us some more information on your setup. Heaters, etc.
        Can you share your config.g and your PID tune values?
        What is the exact driver error message?
        Del87undefined 1 Reply Last reply Reply Quote 0
          A Former User @Del87
          @del87 said in 3.4.0beta7 - RC2 overheating when the model fan is turned on:
          About same issue for me with the RC1, look here: https://forum.duet3d.com/topic/27533/temperatures-totally-wrong
          • System referenced this topic
          • Del87undefined
            Del87 @Phaedrux
            @phaedrux
            All pid tuning by M303 T0 S235
            Pid parameters after tuning on firmware RC2:
            M307 H1 R2.017 K0.304:0.121 D5.56 E1.35 S1.00 B0 V23.8
            Old parameters firmware beta6 (works great):
            M307 H1 R2.096 C266.944:211.319 D5.59 S1.00 V23.9 B0 I0
            config.g
            I guess it is all about the model fan cooling compensation, beta6 perfect for me, later ones are much worse.
            driver0 a lot of reports about stall detection on one Z height (didn't copy it). Old firmware - no reports, same gcode.
            Dmitry
            • Dogma2kundefined
              Dogma2k
              And the same i said here
              https://forum.duet3d.com/post/270688
              • Del87undefined
                Del87
                3.4.rc2+2 pid works stable. But the problem with driver stuck is actual. There was the message about driver 0 and 1 (X Y) stuck then motor Y (h-bot configuration) stopped working. Firmware 3.4.beta6 no messages, no problems with stucks, sensorless homing, motors.
                What changes in motor/driver or sensorless settings was made after beta6 firmware?
                no such messages on firmware 3.4.beta6.
                Dmitry
                • Del87undefined
                  Del87
                  some new investigations:
                  G28 via console - no error messages
                  G28 in gcode (only one command). Error messages after this gcode start printing.
                  homeall.g
                  Dmitry
                    Phaedrux Moderator @Del87
                    @del87 Can you start a new thread with your details for this issue?
                    • Del87undefined
                      Del87 @Phaedrux
                      @phaedrux okay
                      Dmitry
