    I think I may have destroyed my Duet 3 6HC
    573
    • Ben 0undefined
      Ben 0
      Today I did something really stupid, I wired a switch in the 240v side of my 24v 600W power supply backwards, and then immediately tripped the RCD on that circuit when I flipped it to on. I reset the house, wired it up properly and tried again but the power supply was dead, no surprise there. Then I put my crappy old 12v 360W power supply on and the board actually booted up and looked ok, but when I asked a stepper to move I got an error saying ''Attempt to move motors when VIN is not in range" which has got me thinking that something is seriously wrong on the board as well.
      So, while I wait for my new power supply to arrive, is there anything I can do to test the Duet? I'd really hate to have to replace it as it will take me ages to save up for one again!
      weed2allundefined fcwiltundefined dc42undefined 3 Replies Last reply Reply Quote 0
      • weed2allundefined
        weed2all @Ben 0
        @ben-0 cheap psu might not have 12v on output...did you tried to see with a multimeter if the cheap 12v psu actually have 12v output? If it have less than 12v it may power the board but when you try to move motor won't work...test it and get back with info!I recon the voltage requirements are 12-32v for 6HC board!
        https://www.thingiverse.com/weed2all/designs
        Ben 0undefined 1 Reply Last reply Reply Quote 1
        • fcwiltundefined
          fcwilt @Ben 0
          @ben-0 said in I think I may have destroyed my Duet 3 6HC:
          What do you mean by that?
          Ben 0undefined 1 Reply Last reply Reply Quote 0
          • Ben 0undefined
            Ben 0 @fcwilt
            @fcwilt 240 volts wired backwards into the power supply, positive to negative, negative to positive, but I got the earth right at least ...
            Rushmere3Dundefined rjenkinsgbundefined 2 Replies Last reply Reply Quote 0
            • Rushmere3Dundefined
              Rushmere3D @Ben 0
              @ben-0 What switch are you trying to use?
              Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
              • rjenkinsgbundefined
                rjenkinsgb @Ben 0
                It's still not clear what you did?
                240V AC does not have positive and negative; swapping live and neutral, as long as you are still connecting 240V to the AC input terminals, should have no effect.
                Did you connect 240V to the 24V terminals? If so, where were the DC cables for the Duet connected at the time?
                Robert J.
                Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
                • Ben 0undefined
                  Ben 0 @rjenkinsgb
                  @rjenkinsgb live to neutral, into the 240v conector on the power supply. My fuse box and destroyed power supply disagree with you about it being no problem sadly
                  rjenkinsgbundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                    rjenkinsgb @Ben 0
                    Did you exchange live and neutral, or put both on the same terminal?
                    That would definitely blow fuses or pop breakers etc!
                    There must be something more than simply swapping L & N??
                    Robert J.
                      dc42 administrators @Ben 0
                      When you run M122 what does it report for the VIN voltage and the 12V rail voltage?
                      • fcwiltundefined
                        fcwilt @Ben 0
                        I am surprised that happened.
                        What brand and model of power supply was it?
                        • Ben 0undefined
                          Ben 0 @dc42
                          @dc42 That's got it! the VIN was showing as 10.2 so I've adjusted that with the trimpot on the supply and it's reading 13 on VIN and 12 on the 12v rail! Thanks for your input everyone, really appreciate it!
                          • Ben 0undefined
                            Ben 0 @weed2all
                            @weed2all sorry, I seem, to have glossed over your reply! I was in a bit of a tizzy yesterday, wish I'd picked this open up sooner 🙂
                            weed2allundefined 1 Reply Last reply Reply Quote 0
                              @ben-0 if you have a multimeter then I suggest you check that the actual voltage corresponds to the value reported by M122, in case you have overvoltage on the 3.3V rail which would cause VIN to read high.
                              • weed2allundefined
                                weed2all @Ben 0
                                @ben-0 so the issue was solved right? The cheap psu didn't output 12v as expected...you may want to put "solved" on the thread title...glad you sorted out!
