    NEMA 23 Drama
    38
    2.4k
    • hackinistratorundefined
      hackinistrator
      its very unlikely that its a power supply issue .
      did those motors ever work ?
      i ran nema23 with 24v supply without any issues
      • Joaquin Suaveundefined
        Joaquin Suave
        Yes both the motors work fine with a simple drive powered by a 24V 4a PSU.
        • mikeabuilderundefined
          mikeabuilder
          I use NEMA 23's with my Duet3 board with no issues. I also think you should check you wiring. My method with NEMAs is to disconnect the motor , then short two of the wires together. If they are on the same winding, the shaft will be hard to turn. If the shaft still turns easily, they are on different windings. Test a few combos to convince yourself you've got one pair of wires for each winding. Now you can connect them to the duet connector with confidence. If the motor turns in the wrong direction, you can adjust that in your M569 command.
          Also, double check your M906 command (max motor currents). Be sure to put in your current in milliamps, probably something around 2200 for a NEMA 23 (derated to 80% of max current).
          And congratulations on making it to the age of "do what you want". Lot's of us old coots here that also don't have anything better to do.
          • rjenkinsgbundefined
            rjenkinsgb
            Can you please post the make and model of the NEMA23 motors, or photos of the labels (or both) ?
            And also details of the "simple" drive that they do work with - again make and model, photos of any wiring diagrams or terminal layouts??
            There are some types of motor that could work with an external drive of an appropriate type, but not be compatible with the Duet motor drivers.
            Robert J.
            Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
              Joaquin Suave
              I have checked all the motors for paired windings by checking resistance and by shorting them and spinning the shaft. I am 100% sure that the wiring is correct.
              The 2 motors I plan on using are Intelligent Motion Systems M-2231-2.4S
              And... No luck!
              I also tried an Oriental Motors C0145-9212K... No luck!
              And an Oriental Motors PK268-E2.0A... No luck!
              All these motors work correctly with an external drive.
              I have to run out and meet with a client for few hours. When i get back to the shop I'll share the setting that I have tried in the RRF Config tool.
              Thanks again to all of you for "pitching in"!
              rjenkinsgbundefined mrehorstdmdundefined 2 Replies Last reply Reply Quote 0
                rjenkinsgb @Joaquin Suave
                @joaquin_suave
                OK, the motors don't look to be anything particularly special.
                The specifications are not much different from some I use.
                Info here:
                https://www.motionsolutions.com/store/pc/viewPrd.asp?idproduct=1209
                Presumably you are using Red & Red/White as one winding and Green & Green/White as the other?
                They are fairly high inductance, so will need moderate instantaneous speed change and acceleration settings, at least to start with.
                Robert J.
                • mrehorstdmdundefined
                  mrehorstdmd @Joaquin Suave
                  @joaquin_suave Is there any chance you have one of the windings reversed at the driver connections?
                    Joaquin Suave
                    Here is my M122 info:
                    m122
                    RepRapFirmware for Duet 3 MB6HC version 3.3 (2021-06-15 21:45:47) running on Duet 3 MB6HC v1.01 or later (standalone mode)
                    Board ID: 08DJM-9P63L-DJ3S0-7JTD0-3S46L-TUKZ8
                    Used output buffers: 3 of 40 (12 max)
                    Static ram: 150904
                    Dynamic ram: 91692 of which 0 recycled
                    Never used RAM 111596, free system stack 193 words
                    Tasks: NETWORK(ready,30.3%,270) ETHERNET(notifyWait,0.1%,117) HEAT(notifyWait,0.0%,325) Move(notifyWait,0.0%,284) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,333) TMC(notifyWait,7.7%,59) MAIN(running,61.8%,1096) IDLE(ready,0.0%,29), total 100.0%
                    Owned mutexes:
                    Last reset 00:09:16 ago, cause: software
                    Last software reset at 2022-03-17 13:47, reason: User, GCodes spinning, available RAM 111596, slot 0
                    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
                    Error status: 0x00
                    Aux0 errors 0,0,0
                    Step timer max interval 148
                    MCU temperature: min 34.0, current 36.9, max 36.9
                    Supply voltage: min 36.0, current 36.0, max 36.1, under voltage events: 0, over voltage events: 0, power good: yes
                    12V rail voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0
                    Driver 0: position 730913, standstill, reads 19469, writes 14 timeouts 0, SG min/max 0/0
                    Driver 1: position 0, standstill, reads 19456, writes 27 timeouts 0, SG min/max 0/179
                    Driver 2: position 0, standstill, reads 19469, writes 14 timeouts 0, SG min/max 0/0
                    Driver 3: position 0, standstill, reads 19469, writes 14 timeouts 0, SG min/max 0/0
                    Driver 4: position 0, standstill, reads 19472, writes 11 timeouts 0, SG min/max 0/0
                    Driver 5: position 0, standstill, reads 19473, writes 11 timeouts 0, SG min/max 0/0
                    Date/time: 2022-03-17 13:56:29
                    Slowest loop: 6.84ms; fastest: 0.05ms
                    === Storage ===
                    Free file entries: 10
                    SD card longest read time 2.1ms, write time 0.0ms, max retries 0
                    DMs created 125, maxWait 219077ms, bed compensation in use: none, comp offset 0.000
                    === MainDDARing ===
                    Scheduled moves 21, completed moves 21, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 21], CDDA state -1
                    === AuxDDARing ===
                    Segments left: 0
                    Movement lock held by null
                    HTTP is idle in state(s) 0
                    Telnet is idle in state(s) 0
                    File is idle in state(s) 0
                    USB is idle in state(s) 0
                    Aux is idle in state(s) 0
                    Trigger is idle in state(s) 0
                    Queue is idle in state(s) 0
                    LCD is idle in state(s) 0
                    SBC is idle in state(s) 0
                    Daemon is idle in state(s) 0
                    Aux2 is idle in state(s) 0
                    Code queue is empty.
                    === CAN ===
                    Messages queued 5011, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 49 (min 49), ts 2785/0/0
                    Tx timeouts 0,0,2784,0,0,2225 last cancelled message type 30 dest 127
                    === Network ===
                    Slowest loop: 4.60ms; fastest: 0.02ms
                    HTTP sessions: 1 of 8
                    • Ethernet -
                      State: active
                      Error counts: 0 0 1 0 0
                    Help me guys! I am more confused than ever!
                      Joaquin Suave
                      m203
                      Max speeds (mm/min): X: 12000.0, Y: 12000.0, Z: 180.0, E: 1200.0, min. speed 30.00
                      3/17/2022, 2:52:11 PM m106
                      3/17/2022, 1:58:43 PM m98 p
                      Error: M98: non-empty string expected
                      When i am trying to make changes, i go into the RRF config tool and create a new zip file the download it in "my printer". It goes through the process then tells me that only one file has changed... I presumed that it was the config.g, but don't know for sure.
                      Am I missing something... I'm starting to feel really dumb here!
                      rjenkinsgbundefined 1 Reply Last reply Reply Quote 0
                        mikeabuilder
                        I think everything you put into the configurator ends up in one file - config.g. Config.g is in the sys directory of the downloaded file set. It's a text file that you can edit yourself with any text editor. It is usually not too complicated and has some good comments in it. You can use the gcode disctionary in the documentation (https://docs.duet3d.com/en/User_manual/Reference/Gcodes) to look up what each of the gcodes are doing, and you'll quickly see how they map to the things you put into the configurator. You'll pretty quickly never go back to the beginning with the configurator again.
                        If you are connecting to the duet board via the web interface (are you?), you'll see a link to the "System" page next to the gear icon on the left side of the page. When you select that link you'll see a list of those same files that you installed. You can right-click on any of them to edit, and you'll see config.g right there.
                        One warning - if you do edit those files right on the system, you should definitely keep a copy somewhere off the duet board. You can download a file after you've changed it. My personal; preference is to always edit a copy of any file on my PC and upload it to the duet board. That way, I know I have a backup copy.
                        1 Reply Last reply Reply Quote -1
                          @joaquin_suave said in NEMA 23 Drama:
                          Once you have everything in the printer the first time, I'd suggest just modifying the config in place via the web editor.
                          The config tools does a good job of a general setup but then you really need to do the "fine tuning" for your specific machine by hand.
                          I actually save the entire config for each machine on another PC (in fact on network storage) and edit files there, then drop the updated file(s) back on the machine via the DWC web page.
                          That way if anything goes wrong during an update, I can just drop the whole lot back on a new SD card setup via DWC and it's working again straight away, with no messing about.
                          Robert J.
                            Joaquin Suave
                            Here is my latest test and still no luck:
                            ; Configuration file for Duet 3 (firmware version 3.3)
                            ; generated by RepRapFirmware Configuration Tool v3.3.10 on Fri Mar 18 2022 10:57:30 GMT-0700 (Pacific Daylight Time)
                            M550 P"My Printer" ; set printer name
                            M586 P0 S1 ; enable HTTP
                            M586 P1 S0 ; disable FTP
                            M586 P2 S0 ; disable Telnet
                            M584 X0.1 Y0.2 Z0.3 E0.0 ; set drive mapping
                            M350 X1 I0 ; configure microstepping without interpolation
                            M350 Y16 Z16 E16 I1 ; configure microstepping with interpolation
                            M92 X200.00 Y1.50 Z266.00 E100.00 ; set steps per mm
                            M566 X6000.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                            M203 X30000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
                            M906 X2000 Y800 Z800 E800 ; set motor currents (mA)
                            M84 S0 ; Disable motor idle current reduction
                            M208 X416 Y416 Z400 S0 ; set axis maxima
                            M574 X1 S1 P"null" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin null
                            M574 Y1 S1 P"null" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin null
                            M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                            M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
                            M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
                            M950 F0 C"out8" Q500 ; create fan 0 on pin out8 and set its frequency
                            M950 F1 C"out7" Q500 ; create fan 1 on pin out7 and set its frequency
                              @joaquin_suave
                              That config makes no sense?
                              It has X with 200 steps per mm, but Y with 1.5 steps per millimetre!!
                              Are all the motors the same - and are you connecting the NEMA23 motors with two reds as one winding and two green as the other?
                              Robert J.
                                Joaquin Suave
                                Oops My bad!
                                I am only testing the motor (nema 23) with the X drive and have set it so that when I manually move 1 mm it should turn the shaft 1 revolution. I figured that once i have achieved that I can tune the X & Y drives correctly.
                                Z and E are nema 17's and I don't seem to have any issues with them.
                                Any test setting you guys can suggest will be GREATLY appreciated!!!!
                                  mikeabuilder
                                  So your motor is 200 full steps per revolution. But you have microstepping set to 16, which means that "steps" to the FW are 16 * 200 = 3200 steps per revolution. Instructing it to turn 1mm should get you 200microsteps, or 1/16 revolution.
                                  Does not explain why your NEMA 17's are behaving properly (maybe they don't support microstepping?)
                                    Joaquin Suave
                                    I am only trying to configure X for right now (the X & Y motors are identical).
                                    Z is a nema 17 with a leadscrew and is moving correctly as for as I can tell ( without using a test indicator), E is a nema 17 and moves the filament close to the correct length.
                                    Wiring:
                                    A2: Green
                                    A1: Green/ White
                                    B2: Red
                                    B1: Red/ White
                                      Joaquin Suave
                                      I GOT IT!!!!!
                                      I didn't have enough current for the motors! Now I will start fine tuning!
                                      Thank all you SO MUCH!
                                      droftartsundefined 1 Reply Last reply Reply Quote 2
                                      • Phaedruxundefined Phaedrux has marked this topic as solved
                                        droftarts administrators @Joaquin Suave
                                        @joaquin_suave I was going to suggest that your jerk/maximum instantaneous speed of X6000 may be a problem. 6000mm/min is 100mm/s; larger motors may have a problem starting at this speed and require a lot of current to do it. Any move request at under 100mm/s would immediately be trying to run at that speed. High jerk is generally considered bad; better to have low jerk and higher acceleration, though you've also set that pretty high too. Minimum jerk should be 5mm/s, or 300mm/m, and a sensible value is 600 to 900mm/m.
                                        I was also going to ask how you were actually testing the motor; just pressing the jog buttons in DWC, or sending a gcode command with a feedrate? Note you can change the feedrate of the DWC jog buttons in Settings > Machine specific > General > Machine specific > Feedrate for move buttons. See https://docs.duet3d.com/User_manual/Reference/Duet_Web_Control_Manual#general-tab-1
                                          Joaquin Suave
                                          Well I spoke too quickly!
                                          I did one test run @ 16x : 150 steps/ sec. : 15 change: 200mm/ sec. : 500 Accl :
                                          5000 current... And the motor shaft rotated without stalling.
                                          Since then I have done +/- 60 tests WITH NO LUCK (in every imaginable configuration).
                                          I disconnected the motor from the board and wired it up to a simple driver i have and it works just fine!?!?
                                          Can anyone give a starting point to configure the drives for these motors?
                                          Intelligent Motion Systems M-2231-2.4S (nema 23)
                                          And I desire to achieve this travel:
                                          79.8mm = 1 rotation of the pinion on the rack / the timing belt gear reduction of 3.75:1 = 21.28mm for 1 revolution of the motor shaft.
                                          Or at 1X (200 steps) = 9.398 steps/ mm.
                                          Or at 16X (3200 steps) = 150.368 steps/ mm.
                                          Could there be a possibility that i am just asking too much from the drivers?
                                          Could there be a possibility that i "fried" the drivers?
                                          Could there be a possibility that i can wire in "add-on" drivers?
                                          In the worst case scenario, I could tear the machine apart and replace the rack/ pinion w/reduction to a regular belt drive. If so, what is a "comfortable" mm to shaft ratio?
                                          I am not trying to break any "speed records", but rather trying to repurpose a really nicely made (expensive) piece of hardware, learn about controls, 3D printing.
                                          I can't say that I have been very successful so far! 🤕
                                          • Phaedruxundefined Phaedrux has marked this topic as unsolved
                                            Phaedrux Moderator @Joaquin Suave
                                            Do you have the specs for the motor? Googling comes up with several and I don't know which matches yours.
