    Why no PWM on hotend fan output?
    557
    • zaptaundefined
      zapta @Phaedrux
      @fcwilt, I tried Q250 instead of Q50000 but no change.
      @phaedrux, M106 example suggests a single temperature. "The second example sets the second fan to a thermostatic fan for sensors 1 and 2 (e.g. the extruder heaters in a dual-nozzle machine) such that the fan will be on at 70% PWM when either hot end is at or above 45C. "
      M106 P1 T45 S0.7 H1:2
      Any suggestion? Is it possible that I am using a bad RRF version?
        Can you try the same settings with a different fan?
        There are a few possibilities like the fan itself just not like PWM.
        • fcwiltundefined
          fcwilt @zapta
          @zapta said in Why no PWM on hotend fan output?:
          How are you connecting the scope?
          Is the fan connected during your tests?
          Remember that out6 is being switched not V_OUTLC2.
          • zaptaundefined
            zapta @fcwilt
            @fcwilt, I am connecting the osciloscope between ground and out5 and out6 with load for pullup. With the code below, I see 50Khz PWM on out5 but not out6. Out5 just changes on/of as the heater crosses 50C.
            ; Material fan
            M950 F0 C"out5" Q50000   ; 50Khz for the Fan Smoother
            M106 P0 S0 H-1 C"Material Fan"
            ; Heatshink fan.
            M950 F1 C"out6" Q50000   ; 50khz for the Fan Smoother.
            M106 P1 S0.5 H1 T50 C"Heatsink Fan"  ; Set hot-end fan 50% (thermostatically)
            If I swap the ports out5/6 with the code below I get PWM on out6 but not out5. Out5 just changes on/of as the heater crosses 50C.
            ; Material fan
            M950 F0 C"out6" Q50000   ; 50Khz for the Fan Smoother
            ; Heatshink fan.
            M950 F1 C"out5" Q50000   ; 50khz for the Fan Smoother.
            It's seems that the PWM goes with the function, not with the hardware port.
            @Phaedrux, I think that the above experiment covers the 'fan doesn't like pwm' case since either fan gets PWM when it acts as a material fan and doesn't see PWM when it acts as a heatsink fan. It seems that something with the the heatsink configuration or firmware is wrong and that this is not an hardware issue.
            • fcwiltundefined
              fcwilt @zapta
              @zapta
              It could be just a mistake in the documentation.
              Not all pins on the processor chip can generate PWM signals.
              • zaptaundefined
                zapta @fcwilt
                @fcwilt said in Why no PWM on hotend fan output?:
                I do get PWM on pins out5 and on out6 when I set each one of them as material cooling fan. However, I can't get PWM on them when configured as heatshink fan with themostatic control. This leads me to believe that this is not a hardware limitation or malfunction.
                zaptaundefined 1 Reply Last reply Reply Quote 1
                • zaptaundefined
                  zapta @zapta
                  Ok, found a fix/workaround. The heatsink fan PWM should be specified using parameter X rather than S.
                  M106 P1 X0.5 H1 T50 C"Heatsink Fan"  ; Max 50% PWM.
                    I wonder if this is on purpose for the heatsink fan to prevent setting it too low and causing jams. Will see what DC42 says.
                    achrnundefined 1 Reply Last reply Reply Quote 0
                    • achrnundefined
                      achrn @Phaedrux
                      @phaedrux I don't think it's related to what the fan is allocated to. My MB6HC+SBC does the same for fan 4 monitoring heater 2, using firmware 3.4.0:
                      Heater 2 is at 21.6C, and if I set it to come on at 20 with 0.6 PWM it comes on full (I can hear the fan is near full speed, and the object model says it is full):
                      It also ignores S if I specify it in the 1-255 range:
                      The output is capable of PWM and the fan is OK because if I use a range of temperatures the object model reports a less-than-full value, and I can hear that the fan runs slower:
                      All this is with a noctua 4-wire fan on out5: M950 F4 C"!out5" Q25000
                      Board: Duet 3 MB6HC (MB6HC)
                      DSF Version: 3.4.0
                      Firmware: RepRapFirmware for Duet 3 MB6HC 3.4.0 (2022-03-15)
                      SBC: Pi4
                      • zaptaundefined
                        zapta @achrn
                        @achrn, you can also gain some insight from the fan's object model display in DWC. You will see the fractional requested value and then the actual value is 1 when the heater is hot.
