    DUEX 5 V0.8 TO DUEX 5 V0.11
    283
    23.7k
      droftarts administrators @paolozampini1973
      @paolozampini1973 Also, you have an always on fan wire running next to your ribbon cable. It would be a good idea to route this away from the ribbon cable. The ribbon cable has no shielding, and can pick up interference from fan and motor wires that run very close to it.
      paolozampini1973undefined 2 Replies Last reply Reply Quote 0
      • paolozampini1973undefined
        paolozampini1973 @droftarts
        @droftarts said in DUEX 5 V0.8 TO DUEX 5 V0.11:
        Yes I know but this was a temporary situation in the meantime to print the shells and then arrange all the cables with shielded cables You are right I agree I agree with you but as I repeat with the 08 I did not have these problems absolutely Sorry if I repeat it to you I had only a small loss of pace here the problems are so many
          @droftarts the fan can also be spent This is not the question it is a good observation what you do but this is not the problem Now tell me one thing you agree that in my opinion there are hardware problems and then my personal curiosity if you can answer me I saw photos of the printer that looks like structure to you ?
            @paolozampini1973 Where are the Z endstops on your machine? Are they activate when the nozzle is close to the bed? Because your config.g has
            M574 Z2 S1 P"!zstop+!duex.e2stop"
            The 'Z2' means max endstop, when the Z axis is at maximum, eg Z300, when the nozzle is 300mm from the bed. But I think this should be:
            M574 Z1 S1 P"!zstop+!duex.e2stop"
            (Sorry, e2stop now)
            Try this, test Z homing.
              (Sorry, e2stop now)
                @paolozampini1973 So yes, activates when the nozzle is on the bed. I hope this may fix the homez.g.
                paolozampini1973undefined 1 Reply Last reply Reply Quote 0
                  @droftarts Yes but the LEDs light up so it indicates that it recognizes it and in any case it has always worked so useless that I change the output if you want, but it has always worked like this
                    if the LEDs on the electronics indicate that they are on and the configuration is correct it means that everything is correct So in my opinion there is a problem on the electronics that is on the hardware I understand what I want to tell you you saw it with your own eyes I also sent you the photos
                      @paolozampini1973 Test it, please. I don't have much time left to help you today, only 10 minutes.
                        Okay ok So what do you want me to do
                        droftartsundefined 2 Replies Last reply Reply Quote 0
                          @paolozampini1973 Test that Z homing works. Or do you still receive an error in Console?
                            No now I don't get any errors but it doesn't work
                            2/3/2022, 17:41:14 M122
                            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later + DueX2
                            Board ID: 0JD0M-9P6M2-NW4SN-6J1DD-3SJ6K-KAURK
                            Used output buffers: 3 of 24 (22 max)
                            Static ram: 23876
                            Dynamic ram: 77448 of which 0 recycled
                            Never used RAM 13092, free system stack 174 words
                            Tasks: NETWORK(ready,14.7%,237) HEAT(delaying,0.1%,330) Move(notifyWait,0.1%,340) DUEX(notifyWait,0.0%,24) MAIN(running,85.1%,411) IDLE(ready,0.1%,29), total 100.0%
                            Owned mutexes:
                            Last reset 00:22:33 ago, cause: software
                            Last software reset at 2022-03-22 17:18, reason: User, GCodes spinning, available RAM 10060, slot 2
                            Error status: 0x00
                            Aux0 errors 0,0,0
                            Step timer max interval 0
                            MCU temperature: min 29.6, current 30.4, max 31.4
                            Supply voltage: min 25.6, current 25.7, max 25.8, under voltage events: 0, over voltage events: 0, power good: yes
                            Driver 0: position 0, standstill, SG min/max not available
                            Driver 1: position 0, standstill, SG min/max not available
                            Driver 2: position 0, standstill, SG min/max not available
                            Driver 3: position 0, standstill, SG min/max not available
                            Driver 4: position 0, standstill, SG min/max not available
                            Driver 5: position 0, standstill, SG min/max not available
                            Driver 6: position 0, standstill, SG min/max not available
                            Driver 7: position 0
                            Driver 8: position 0
                            Driver 9: position 0
                            Driver 10: position 0
                            Driver 11: position 0
                            Date/time: 2022-03-22 17:41:11
                            Slowest loop: 10.18ms; fastest: 0.18ms
                            === Storage ===
                            Free file entries: 10
                            SD card longest read time 1.0ms, write time 0.0ms, max retries 0
                            === MainDDARing ===
                            === AuxDDARing ===
                            Heater 1 is on, I-accum = 0.0
                            Segments left: 0
                            Movement lock held by null
                            HTTP is idle in state(s) 0
                            Telnet is idle in state(s) 0
                            File is idle in state(s) 0
                            USB is idle in state(s) 0
                            Aux is idle in state(s) 0
                            Trigger is idle in state(s) 0
                            Queue is idle in state(s) 0
                            LCD is idle in state(s) 0
                            Daemon is idle in state(s) 0
                            Code queue is empty.
                            === Filament sensors ===
                            Extruder 0 sensor: no filament
                            Extruder 1 sensor: ok
                            Extruder 2 sensor: no filament
                            Extruder 3 sensor: no filament
                            === DueX ===
                            Read count 1, 0.04 reads/min
                            === Network ===
                            Slowest loop: 39.72ms; fastest: 0.00ms
                            Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
                            HTTP sessions: 1 of 8
                            • WiFi -
                              Network state is active
                              WiFi firmware version 1.26
                              WiFi MAC address 40:f5:20:0d:6b:49
                              WiFi Vcc 3.37, reset reason Turned on by main processor
                              WiFi flash size 4194304, free heap 20648
                              WiFi IP address 192.168.1.4
                              WiFi signal strength -60dBm, mode 802.11n, reconnections 0, sleep mode modem
                              Clock register 00002002
                              Socket states: 0 4 0 0 0 0 0 0
                              22/3/2022, 17:41:01 Connected to 192.168.1.4
                              @paolozampini1973 If the LED turns on and off, that just means that the switch is working. The axis movement has to be in the correct direction. Your homez.g has the axis moving to minimum Z, but endstop was defined in config.g as maximum Z. So it's a configuration error, not hardware.
                                Ok What should I change because I repeat it has always worked so it is always good V0.8 what should I change In your opinion
                                  @paolozampini1973 What do you mean "It doesn't work"? What doesn't work?
                                  It's possible that the filament sensor is still configured on duex.e2stop.
                                  I think if you move the Z2 endstop back to duex.e6stop, now that the direction is correct, it should work.
                                  Then send
                                  M574 Z1 S1 P"!zstop+!duex.e6stop"
                                  Make sure this is in config.g as well.
                                    @paolozampini1973 said in DUEX 5 V0.8 TO DUEX 5 V0.11:
                                    You have made a lot of changes to your config.g. If you put your 0.8 back in, I'm sure you would have just as many problems. The problem isn't the hardware, it's the configuration. Now I know more about your machine, I can update your config.g and fix the issues.
                                      Then send
                                      config (21).g
                                        @paolozampini1973 You still have Z2, should be Z1:
                                        (Sorry, made a mistake in my earlier post, edited)
                                          I did and modified it there is nothing to do It does not work it does not work it does not work I did as you told me but it does not work even in the Z1 site it does not work
                                            @droftarts explain to me why the same configuration with the V 08 everything worked and with the V 011 there are all these problems You can help me to understand Forgive me if I insist but I want to understand I want to understand Thanks and thanks for the time you are DETICATING me
                                            Excuse me I was wrong to write that you are dedicating to me Thanks for the time you are dedicating to me
