    DUEX 5 V0.8 TO DUEX 5 V0.11
    283
    23.7k
      droftarts administrators @paolozampini1973
      @paolozampini1973 Where are the Z endstops on your machine? Are they activate when the nozzle is close to the bed? Because your config.g has
      M574 Z2 S1 P"!zstop+!duex.e2stop"
      The 'Z2' means max endstop, when the Z axis is at maximum, eg Z300, when the nozzle is 300mm from the bed. But I think this should be:
      M574 Z1 S1 P"!zstop+!duex.e2stop"
      (Sorry, e2stop now)
      Try this, test Z homing.
      paolozampini1973undefined 2 Replies Last reply Reply Quote 0
      • paolozampini1973undefined
        paolozampini1973 @droftarts
        @droftarts said in DUEX 5 V0.8 TO DUEX 5 V0.11:
        (Sorry, e2stop now)
          @paolozampini1973 So yes, activates when the nozzle is on the bed. I hope this may fix the homez.g.
          paolozampini1973undefined 1 Reply Last reply Reply Quote 0
            @droftarts Yes but the LEDs light up so it indicates that it recognizes it and in any case it has always worked so useless that I change the output if you want, but it has always worked like this
              if the LEDs on the electronics indicate that they are on and the configuration is correct it means that everything is correct So in my opinion there is a problem on the electronics that is on the hardware I understand what I want to tell you you saw it with your own eyes I also sent you the photos
                @paolozampini1973 Test it, please. I don't have much time left to help you today, only 10 minutes.
                  Okay ok So what do you want me to do
                  droftartsundefined 2 Replies Last reply Reply Quote 0
                    @paolozampini1973 Test that Z homing works. Or do you still receive an error in Console?
                      No now I don't get any errors but it doesn't work
                      2/3/2022, 17:41:14 M122
                      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later + DueX2
                      Board ID: 0JD0M-9P6M2-NW4SN-6J1DD-3SJ6K-KAURK
                      Used output buffers: 3 of 24 (22 max)
                      Static ram: 23876
                      Dynamic ram: 77448 of which 0 recycled
                      Never used RAM 13092, free system stack 174 words
                      Tasks: NETWORK(ready,14.7%,237) HEAT(delaying,0.1%,330) Move(notifyWait,0.1%,340) DUEX(notifyWait,0.0%,24) MAIN(running,85.1%,411) IDLE(ready,0.1%,29), total 100.0%
                      Owned mutexes:
                      Last reset 00:22:33 ago, cause: software
                      Last software reset at 2022-03-22 17:18, reason: User, GCodes spinning, available RAM 10060, slot 2
                      Error status: 0x00
                      Aux0 errors 0,0,0
                      Step timer max interval 0
                      MCU temperature: min 29.6, current 30.4, max 31.4
                      Supply voltage: min 25.6, current 25.7, max 25.8, under voltage events: 0, over voltage events: 0, power good: yes
                      Driver 0: position 0, standstill, SG min/max not available
                      Driver 1: position 0, standstill, SG min/max not available
                      Driver 2: position 0, standstill, SG min/max not available
                      Driver 3: position 0, standstill, SG min/max not available
                      Driver 4: position 0, standstill, SG min/max not available
                      Driver 5: position 0, standstill, SG min/max not available
                      Driver 6: position 0, standstill, SG min/max not available
                      Driver 7: position 0
                      Driver 8: position 0
                      Driver 9: position 0
                      Driver 10: position 0
                      Driver 11: position 0
                      Date/time: 2022-03-22 17:41:11
                      Slowest loop: 10.18ms; fastest: 0.18ms
                      === Storage ===
                      Free file entries: 10
                      SD card longest read time 1.0ms, write time 0.0ms, max retries 0
                      === MainDDARing ===
                      === AuxDDARing ===
                      Heater 1 is on, I-accum = 0.0
                      Segments left: 0
                      Movement lock held by null
                      HTTP is idle in state(s) 0
                      Telnet is idle in state(s) 0
                      File is idle in state(s) 0
                      USB is idle in state(s) 0
                      Aux is idle in state(s) 0
                      Trigger is idle in state(s) 0
                      Queue is idle in state(s) 0
                      LCD is idle in state(s) 0
                      Daemon is idle in state(s) 0
                      Code queue is empty.
                      === Filament sensors ===
                      Extruder 0 sensor: no filament
                      Extruder 1 sensor: ok
                      Extruder 2 sensor: no filament
                      Extruder 3 sensor: no filament
                      === DueX ===
                      Read count 1, 0.04 reads/min
                      === Network ===
                      Slowest loop: 39.72ms; fastest: 0.00ms
                      Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
                      HTTP sessions: 1 of 8
                      • WiFi -
                        Network state is active
                        WiFi firmware version 1.26
                        WiFi MAC address 40:f5:20:0d:6b:49
                        WiFi Vcc 3.37, reset reason Turned on by main processor
                        WiFi flash size 4194304, free heap 20648
                        WiFi IP address 192.168.1.4
                        WiFi signal strength -60dBm, mode 802.11n, reconnections 0, sleep mode modem
                        Clock register 00002002
                        Socket states: 0 4 0 0 0 0 0 0
                        22/3/2022, 17:41:01 Connected to 192.168.1.4
                        @paolozampini1973 If the LED turns on and off, that just means that the switch is working. The axis movement has to be in the correct direction. Your homez.g has the axis moving to minimum Z, but endstop was defined in config.g as maximum Z. So it's a configuration error, not hardware.
                          Ok What should I change because I repeat it has always worked so it is always good V0.8 what should I change In your opinion
                            @paolozampini1973 What do you mean "It doesn't work"? What doesn't work?
                            It's possible that the filament sensor is still configured on duex.e2stop.
                            I think if you move the Z2 endstop back to duex.e6stop, now that the direction is correct, it should work.
                            Then send
                            M574 Z1 S1 P"!zstop+!duex.e6stop"
                            Make sure this is in config.g as well.
                              @paolozampini1973 said in DUEX 5 V0.8 TO DUEX 5 V0.11:
                              You have made a lot of changes to your config.g. If you put your 0.8 back in, I'm sure you would have just as many problems. The problem isn't the hardware, it's the configuration. Now I know more about your machine, I can update your config.g and fix the issues.
                                Then send
                                config (21).g
                                  @paolozampini1973 You still have Z2, should be Z1:
                                  (Sorry, made a mistake in my earlier post, edited)
                                    I did and modified it there is nothing to do It does not work it does not work it does not work I did as you told me but it does not work even in the Z1 site it does not work
                                      @droftarts explain to me why the same configuration with the V 08 everything worked and with the V 011 there are all these problems You can help me to understand Forgive me if I insist but I want to understand I want to understand Thanks and thanks for the time you are DETICATING me
                                      Excuse me I was wrong to write that you are dedicating to me Thanks for the time you are dedicating to me
                                        @paolozampini1973 Okay, I'm going to have to stop. I'll try and edit your config.g this evening. I'm available tomorrow.
                                        I still don't think this is a hardware problem. If it is, it's because you are using a clone Duet 2, not one made by Duet3D.
                                        Check that the pins on the expansion connector are not loose or bent over, and properly soldered, on both the Duet 2 and on the DueX (both of them).
                                        If you feel like it, put the v0.8 back on and see if it works (which is also a clone, not produced by Duet3D). On looking at the external driver pdf you linked, your stepper timings are too fast; try:
                                        M569 P7 S0 R1 T3:3:6:6                         ; E4 X physical drive 7 goes forwards
                                        M569 P8 S1 R1 T3:3:6:6                         ; E5 Y physical drive 8 goes forwards
                                          If you feel like it, put the v0.8 back on (which is also a clone, not produced by Duet3D).
                                          Look for me there are no problems anyway I think it's better to go all the way if it's okay with you So we can talk tonight?
                                            Probably not, I have ill kids.
