Solved Heater 1 fault: monitor 0 was triggered
Error: unterminated string
That would seem to indicate that you're missing a quote mark somewhere in your config.g which may be causing chaos.
I can't spot it, maybe you see it?
but your config is a bit messy. I suggest you make a backup of it, and then create a fresh config using the online tool and manually adjust it to match your config leaving it as organized and clean as possible. Then let's see if we can be rid of the string error.
https://configtool.reprapfirmware.org/Start
Even just having a basic config for testing here would be helpful even if it didn't get updated completely for your setup.
@phaedrux Thanks for the pointer - I'll try that tomorrow and see if it fixes it (& let you know).
I can't see a missing ", but not easy to spot!
@general_kaos said in Heater 1 fault: monitor 0 was triggered:
It could also be a case of a bad character. Or a command that was expecting a quoted string and not getting it.
That makes me think that perhaps your PID values aren't actually getting executed.
@phaedrux I realise it's probably just because I mistyped the command first time! Missing " in the console entry of M98 - the repeat above is green.
@general_kaos There are a bunch of M307 commands in your config.g. Most are commented out with a semicolon except the last one which I assume is the active one. However, while it does not have the semicolon, it is indented. So I'm wondering if it's the indentation that is causing the problem? Or perhaps there is a hidden character showing as an indent?
Ah yes, of course, now it's obvious.
Can you send M307 H0 and M307 H1 and compare the results it shows to what you have entered in your config.g to confirm they are actually being applied?
My recommendation to start with a clean config still stands.
@deckingman Thanks Ian - I tried that, but removing the indent did not fix it. New Config G does though.
M307 showed the values being loaded:
22/03/2022, 17:48:35: M307 h0: Heater 0: heating rate 0.350, cooling rate 0.158, dead time 31.25, max PWM 1.00, mode PID
Predicted max temperature rise 180°C
PID parameters: heating P16.3 I0.110 D357.0, steady P16.3 I0.211 D357.0
22/03/2022, 17:48:38: M307 h1: Heater 1: heating rate 4.800, cooling rate 0.546, dead time 1.38, max PWM 1.00, mode PID, calibrated at 23.8V
Predicted max temperature rise 500°C
PID parameters: heating P26.9 I1.612 D26.0, steady P26.9 I4.921 D26.0So onto a new config via the configurator, which worked and still works after copying across all the specific settings for my printer.
I am at a loss what was wrong, but it seems to work now. Thanks for your help.
; Configuration file for Duet 3 (firmware version 3.3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.10 on Tue Mar 22 2022 17:23:42 GMT+0000 (Greenwich Mean Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Duet 3" ; set printer name M669 K1 ; select CoreXY mode ; Drives M569 P0.0 S0 ; physical drive 0.0 goes backwards M569 P0.1 S1 ; physical drive 0.1 goes forwards M569 P0.2 S1 ; physical drive 0.2 goes forwards M569 P0.3 S0 ; physical drive 0.3 goes backwards M569 P0.4 S0 ; physical drive 0.4 goes backwards M569 P121.0 S0 ; physical drive 121.0 goes backwards M584 X0.0 Y0.1 Z0.2:0.3:0.4 E121.0 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X200.00 Y200.00 Z1600.00 E397.00 ; set steps per mm M566 X950.00 Y950.00 Z66.00 E1000.00 ; set maximum instantaneous speed changes (mm/min) M203 X18000.00 Y18000.00 Z540.00 E3600.00 ; set maximum speeds (mm/min) M201 X3000.00 Y3000.00 Z66.00 E1500.00 ; set accelerations (mm/s^2) M906 X1100 Y1100 Z1000 E900 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ;Leadscrew locations M671 X-60:-60:330 Y35:270:170 S7.5 ;Front left, Rear Left, Right S7.5 is the max correction ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X290 Y280 Z330 S0 ; set axis maxima ; Endstops M574 X1 S1 P"io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io2.in M574 Y1 S1 P"121.io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin 121.io1.in ;M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Z-Probe M950 S0 C"121.io0.out" ; create servo pin 0 for BLTouch M558 P9 C"121.io0.in" H10 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X45 Y-40 Z1.4 ; set Z probe trigger value, offset and trigger height M557 X50:250 Y50:250 S20 ; define mesh grid ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S115 ; set temperature limit for heater 0 to 115C M307 H0 R0.350 K0.158:0.000 D31.25 E1.35 S1.00 B0 ;PID tune bed heater 21mar22 M308 S1 P"121.temp0" Y"thermistor" T100000 B4725 C7.060000e-8 ;e3D thermistor settings M950 H1 C"121.out0" T1 ; create nozzle heater output on 121.out0 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S300 ; set temperature limit for heater 1 to 300C M307 H1 R4.880 K0.553:0.843 D1.23 E1.35 S1.00 B0 V23.8 ;PID tune w/ e£D thermistor set 23Mar22 M308 S3 Y"drivers" A"DRIVERS" ; configure sensor 3 as temperature warning and overheat flags on the TMC2660 on Duet M308 S4 Y"mcu-temp" A"MCU" ; configure sensor 4 as thermistor on pin e1temp for left stepper M912 P0 S-2.7 ; 2.7C offset from PT100 at RT 4/7/2020 ; Fans M950 F0 C"121.out2" Q500 ; create fan 0 on pin 121.out2 and set its frequency M106 P0 S0 H1 T45 ; set fan 0 value. Thermostatic control is turned on M950 F1 C"121.out1" ; create fan 1 on pin 121.out1 and set its frequency M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off M950 F2 C"out6" Q500 ; create fan 2 on pin out6 and set its frequency ;M106 P2 S0.25 H1 T30 ; set fan 2 value. Thermostatic control is turned on M106 P2 S0.3 H3:4 L0.15 X1 B0.3 T30 ;electronics fan linked to MCU/drivers ;filament sensor M591 D0 P2 C"121.io2.in" S1 ;simple trianglelabs filament sensor on toolboard IO2 ; Tools M563 P0 D0 H1 F1 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined M572 D0 S0.020 ;set pressure advance ; Miscellaneous T0 ; select first tool
