    DUEX 5 V0.8 TO DUEX 5 V0.11
    283
    24.0k
      droftarts administrators @paolozampini1973
      @paolozampini1973 said in DUEX 5 V0.8 TO DUEX 5 V0.11:
      So we can talk tonight?
      Probably not, I have ill kids.
      paolozampini1973undefined 1 Reply Last reply Reply Quote 0
      • paolozampini1973undefined
        paolozampini1973 @droftarts
        @droftarts I am so sorry that you have sick children anyway Many thanks I am sending you the PDF file so we continue tomorrow at least out of curiosity to see how it endsDM860H V3.3 act英文 (1).pdf
          @paolozampini1973 I have found one piece of information for you this evening, regarding thermistors on V0.11. From https://docs.duet3d.com/Duet3D_hardware/Duet_2_family/DueX2_and_DueX5#pcb-revision-history
          Modified the series resistors of the temperature inputs to be 2k2 so they perform better with PT1000 sensors. From RRF3.4 the DueX5 version will be detected and the correct R values set in M308, for RRF 3.3 and earlier use R2200 in the M308 command.
          In config.g, change M308 for the following:
          M308 S3 P"duex.e2temp" Y"thermistor" T100000 B4138 R2200 ; configure sensor 3 as PT1000 on pin duex.e3temp
          M308 S4 P"duex.e3temp" Y"thermistor" T100000 B4138 R2200 ; configure sensor 4 as PT1000 on pin duex.e3temp
          This should fix the temperature reading. But I think the thermistor configuration is still wrong. What hot ends are you using? Link to where you bought them?
          paolozampini1973undefined 2 Replies Last reply Reply Quote 0
            @droftarts said in DUEX 5 V0.8 TO DUEX 5 V0.11:
            Good morning the correct TEMPERATURE I had to put R 2150
            M308 S3 P"duex.e2temp" Y"thermistor" T100000 B4138 R2150
              @droftarts
              E2 +E3+E4+E5+E6 Filament Sensing it works very well
              E2 +E3+E4+E5+E6 it does not work when microswitch is configured There is no way to make it work if I close the led the same collector lights up I connect it in duet and it works is very strange
                Use R2200, that's the value of the sense resistor. Don't worry about temperature variation of a couple of degrees at room temperature - thermistors are not very accurate at low temperature. If you use a different R value, they will be inaccurate where it is important, around 200C.
                Also, the M308 B value is wrong. I have asked you before, what thermistors or hot ends are you using?
                  Please show how you are testing this.
                    @droftarts NTC 100K ohm B3950
                    220v 1400W 500*500 NTC 100K 3950
                      M119
                        That is the bed. What about the hot ends?
                        For bed, change config.g to:
                        M308 S0 P"bedtemp" Y"thermistor" T100000 B3950         ; configure sensor 0 as thermistor on pin bedtemp
                          M119
                          M119 does not show filament sensor status, only endstop status for axes (X, Y, Z).
                          Send M591 D# where # is the extruder drive number, 0 to 3.
                            M119
                            Yes exactly so I made the limit switch m119 and for the end of the line m 591 d is the distributor number
                            and the film works perfectly instead of the switch does not work now I have replaced it and put it on two WiFi switch Z2config (22).g
                            paolozampini1973undefined droftartsundefined 2 Replies Last reply Reply Quote 0
                              paolozampini1973 @paolozampini1973
                              M119
                              config (23).g
                                @droftarts if it is possible for you we can see the problem of the loss of pace because the rest everything works
                                for other small problems I look at myself I do not want to take advantage of your kindness we see the biggest problem of the loss of the Step of X and Y
                                  @paolozampini1973
                                  M574 X0 S1 P"!xstop"     ; configure active-high endstop for low end on X via pin xstop
                                  M574 Y1 S1 P"!ystop"     ; configure active-high endstop for low end on Y via pin ystop
                                  M574 Z2 S1 P"!zstop+!e1stop"
                                  ;Filament Sensing
                                  M591 P2 C"e0stop" S0 D0
                                  M591 P2 C"duex.e2stop" S1 D2
                                  M591 P2 C"duex.e3stop" S1 D3
                                  M591 P2 C"duex.e4stop" S1 D4
                                  With this configuration, homez.g works? And the filament sensing works?
                                    @paolozampini1973
                                    ;Filament Sensing
                                    With this configuration, homez.g works? And the filament sensing works? YES
                                      @droftarts
                                      M566 X1000.00 Y1000.00
                                      M201 X2000.00 Y2000.00
                                      I tried to make a print with this configuration without extruding the pitch I don't lose it but if I increase it I lose it
                                      DM860H V3.3 act英文 (1).pdf 17HS19-2004S1.pdf
                                      I made the print at 100 mm and the displacement 130 mm
                                        Okay, back to the original problem. DM860H driver is made by Leadshine. I expect you have a Chinese clone version. All documentation I have found, except for the one you posted, has a different timing specification for the DM860H drivers. eg:
                                        http://www.jdsmotion.com/products1/dma860h.pdf
                                        https://manuals.plus/microrostep/leadshine-microstep-dm860-user-s-manual
                                        I suggest trying the following timing:
                                        M569 P7 S0 R1 T3:3:6:6                         ; E4 X physical drive 7 goes forwards
                                        M569 P8 S1 R1 T3:3:6:6                         ; E5 Y physical drive 8 goes forwards
                                        Stated timing is minimum length. Timings can be longer than stated in documentation, but not shorter. This will not affect the speed you can achieve with the axis.
                                        But note that even the pdf you linked says that signal level must be >3.5V.
                                          Ok so I apply this configuration and do a test test without instructions
                                            3:3:6:6
                                            EN+ EN- they are not connected because if I reconnect the motors remain disabled In fact I tried to see if the voltage changes but there is no change in voltage when it prints and when it stops
