Dockable probe .g files
460
    luckyflyer
    I'm looking for examples of bed.g and especially mesh.g files used by those who use dockable z probes. Maybe @Arnold_R_Clark has somthing, thanks.
    undefined undefined ? 3 Replies Last reply 24 Mar 2022, 16:27 Reply Quote 0
      fcwilt @luckyflyer
      @luckyflyer said in Dockable probe .g files:
      I keep my Z probe mounted except when printing.
      This means there is no mount/dismount during things like homing, bed leveling, height map creation, etc.
      In the file I execute at the start of a print I dismount the probe.
      In the file I execute at the end of a print I re-mount the probe.
      There is no special probe handling in bed.g or mesh.g.
      In the homeZ.g file I check if the probe needs to be mounted if for some reason it is not, and mount it as needed.
      1 Reply Last reply Reply Quote -1
        jay_s_uk @luckyflyer
        @luckyflyer the Euclid examples are very good.
        https://euclidprobe.github.io/06_rrf3.html
          luckyflyer
          Thanks for the replies. I'll check out the euclid files. I like the idea of leaving the probe mounted unless printing.
            luckyflyer
            Delete, problem solved.
              A Former User @luckyflyer
              This post is deleted!
              undefined 1 Reply Last reply 25 Mar 2022, 14:26 Reply Quote 0
                luckyflyer
                @Arnold_R_Clark The problem solved was a rogue g28 in my start script that was giving me grief. When I found it the problem went away. Thanks for the files.
                  @arnold_r_clark is there a reason why you don't use the usual deployprobe.g and retractprobe.g files to pick up and park the probe?
                  undefined ? 2 Replies Last reply 25 Mar 2022, 14:44 Reply Quote 0
                    jay_s_uk @dc42
                    thats how I manage my docked probe. Then use M401 and M402 when i want to pick up the probe before hand
                      A Former User @dc42
                      10 out of 10
