    How do i Run a Macro at a given temperature
    Gcode meta commands
    654
    • moth4017undefined
      moth4017 @chrishamm
      @chrishamm
      Thank thats exactly what i want to do.
      many thanks
      mark
      • T3P3Tonyundefined T3P3Tony moved this topic from Tuning and tweaking
      • moth4017undefined
        moth4017 @chrishamm
        @chrishamm
        Hi , how can i echo the reading of sensors.analog[3].lastReading in console for debugging?
        • chrishammundefined
          chrishamm administrators @moth4017
          @moth4017
          echo sensors.analog[3].lastReading
          Also see https://docs.duet3d.com/en/User_manual/Reference/Gcode_meta_commands and https://github.com/Duet3D/RepRapFirmware/wiki/Object-Model-Documentation or just enable the Object Model plugin in DWC if you want to browse the object model yourself.
          Duet software engineer
          • moth4017undefined
            moth4017 @chrishamm
            @chrishamm
            Can these conditional statement be in the config.g file ?
            OwenDundefined 1 Reply Last reply Reply Quote 0
            • OwenDundefined
              OwenD @moth4017
              @moth4017 said in How do i Run a Macro at a given temperature:
              You would need to put it in daemon.g so that the condition is continually checked.
              You would need to include code or a method to stop in running multiple times most likely.
              What is the macro going to do?
              If it's simply to start a fan then just set the fan up as thematically controlled in M950 .
              Another method might be to set up a thermostatically controlled fan output but connect a relay or mosfet to it.
              The output of the relay could be connected to a GPIO pin.
              You would then set up a trigger macro using M581 which would run when the temp reached the target temp.
              moth4017undefined 1 Reply Last reply Reply Quote 0
              • moth4017undefined
                moth4017 @OwenD
                @owend
                Hi im monitoring some of the stepper motors and want to protect them if they get to hot, also monitorng the weight of the spool so want to put up warning when the filament is getting low, ideally would like a way to send an email/txt message .
                • moth4017undefined
                  moth4017
                  @owend
                  Hi im trying to work out how
                  echo "Voltage OK : " ^ boards[0].vIn.current ;
                  how does boards[0] relate to the hardware as it is on "pin 12" labeled ADC1_ANi7 /PB05 on the Micro.
                  is there a list somewhere ?
                  • OwenDundefined
                    OwenD
                    @moth4017
                    You keep asking questions without giving any sort of context
                    This makes it very hard to provide any meaningful help.
                    Also his question seems at a large tangent to your original question.
                    Did you get that working?
                    It's best to provide the following when you're asking questions...,
                    What hardware?
                    Which version firmware?
                    What have you tried so far?
                    What did you expect to happen?
                    What actually happened?
                    boards[nn]. refers to an array referencing each connected board.
                    boards[0].vIn.current refers to the voltage being supplied to the main board by the power supply at the current moment.
                    I don't know what pin that value is read from.
                    The pins list is hardware dependent.
                    https://docs.duet3d.com/User_manual/RepRapFirmware/Migration_RRF2_to_RRF3#pin-names
                    • moth4017undefined
                      moth4017 @OwenD
                      @owend
                      Sorry ,
                      Duet3 + Mini5 wifi.
                      firmware 3.4.0
                      i was using the voltage just to get it working and display in the console and Yes i got the voltage readings to display in the console correctly.
                      Ok so i use the pin names not pin numbers on the Micro .
                      eg IO -IN3 would be "echo "Voltage : " ^ boards[0].IO3.in.current"
                      many thanks for help mark
                      • OwenDundefined
                        OwenD @moth4017
                        @owend
                        Sorry ,
                        Duet3 + Mini5 wifi.
                        firmware 3.4.0
                        No, you misunderstand how the object model works.
                        You can only access what has been exposed in the object model.
                        You can use the object model plugin to view what is available or the list here
                        • moth4017undefined
                          moth4017 @OwenD
                          @owend
                          ok thanks
                          so back to the original request
                          M308 S3 Y"Stepper-temp" A"Stepper Motor" ; configure sensor 3 as stepper motor temperature sensor
                          if sensors.analog[3].lastReading > 70
                          M98 P"ItsToHotmacro.g"
                          is the S3 after M308 referenced [3] in sensors.analog[3].lastReading ?
                          or
                          should it be
                          sensors.analog[temp2].lastReading as temp2 is the RRF3 Pin name?
                          • OwenDundefined
                            OwenD @moth4017
                            @moth4017
                            Go to settings and start the built in object model browser plugin.
                            You will then see the browser listed
                            This will let you see the object model and drill down to get the info you need.
                            If you select a value, the correct path can be copied to the clipboard using the copy button at top right.
