    Invert DC Motor Direction
    • adistrundefined
      adistr
      How I Invert DC Motor Direction (the DC motor connect via fan pin).
      I mean - how I do this in the config file and not via the changing between he electric cables.
      Thanks,
      Adi
      • jens55undefined
        jens55 @adistr
        @adistr, I hope you are not suggesting to do this to an actual fan ....
        Unless I am way off base, you can't do this for a reversible DC motor on the fan pin anyway. The positive end is always a set voltage and the Duet switches the negative line to ground on or off. There is no way to reverse the voltage.
        adistrundefined 1 Reply Last reply Reply Quote 0
        • adistrundefined
          adistr @jens55
          @jens55 Hi thank you.
          I want to predefined the motor cycle side and not change it due the running.
          If it possible (and I guess that most an option) how can I define it in the config file?
          Thank you,
          Adi
          jens55undefined rjenkinsgbundefined 2 Replies Last reply Reply Quote 0
          • jens55undefined
            jens55 @adistr
            @adistr, I am sorry, I have no clue what you were just trying to say ....
            • rjenkinsgbundefined
              rjenkinsgb @adistr
              @adistr said in Invert DC Motor Direction:
              You cannot "reverse" a fan output, the hardware does not exist.
              The only way to control a motor direction would be by using a relay, with that controlled by a different output from the Duet.
              The relay would need to have the contacts wired as two pole changeover, to swap the motor connections over, with motor power from a fan connector.
              Reversing relay
              Robert J.
              Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
              • adistrundefined
                adistr @rjenkinsgb
                @rjenkinsgb
                Great, thank you very much!
