    3.4.0 Stable breaks Nozz Heater[1LC ]Error:M307:Response timeout
    Using Duet Controllers
    783
    • SputnikOC3dundefined
      SputnikOC3d
      This is my 2nd 1LC tooboard ... I do have another spare. [3rd ]
      Not sure whats going on here. All other crimps and wiring on the 1LC works or worked before 3.4.0
        SputnikOC3d
        Put on a spare v1.2 1LC toolboard.
        FW ver 3.3 atm - and all works as intended - even the heater.
        Will flash the board to 3.4.0
          SputnikOC3d
          Ok well flashing the 1LC FW to 3.4.0 using M997 B121 ... updated the firmware.
          It hung on updating - please wait like it did the very first time I upgraded to 3.4.0 Stable.
          1LC worked fine on 3.3 from the factory. Now on 3.4.0 Stable - the above errors have returned, and no heater control. Its as if it is DEAD.
          • SputnikOC3dundefined SputnikOC3d referenced this topic
            jay_s_uk @SputnikOC3d
            @sputnikoc3d i suggest check your wiring
            SputnikOC3dundefined 1 Reply Last reply Reply Quote 0
              SputnikOC3d @jay_s_uk
              @jay_s_uk said in 3.4.0 Stable breaks Nozz Heater[1LC ]Error:M307:Response timeout:
              I have multiple times and it works great. Everything works on 1LC ver 3.3 fw. Everything on the toolboard except the heater works on 3.4.0
                @sputnikoc3d what type of wiring are you using?
                  @jay_s_uk
                  Cat 5 twisted pair for CAN
                    dc42 administrators @SputnikOC3d
                    @sputnikoc3d the M307 errors are why the heater won't turn on. Have you used M115 or M122 to check that the main board is running firmware 3.4 ?
                    You may need to rerun heater 1 tuning to generate a new M307 H1 command.
                    SputnikOC3dundefined 2 Replies Last reply Reply Quote 0
                      SputnikOC3d @dc42
                      @dc42 - TY for your reply.
                      Fresh reboot and power cycle of the SBC / Duet generates No M307 error code - that only happens on estop of the duet.
                      1st op after fresh reboot of entire machine and no reporting of errors, I try M303 H1 S240. I get :
                      M303 H1 S240
                      Auto tuning heater 1 using target temperature 240.0°C and PWM 1.00 - do not leave printer unattended
                      Auto tune starting phase 2, heating up
                      Auto tune cancelled because temperature is not increasing
                        SputnikOC3d @dc42
                        @dc42 well there it is ... looks like the FW upgrade from the previous post using the USB stick didnt actually work as planned ...
                        M122
                        RepRapFirmware for Duet 3 Mini 5+ version 3.4.0beta3 (2021-08-24 14:08:24) running on Duet 3 Mini5plus Ethernet (SBC mode)
                        Board ID: 1JDTH-UA67A-G65J0-40TFU-22D0Z-R2KLQ
                        Used output buffers: 1 of 40 (11 max)
                        Static ram: 102756
                        Dynamic ram: 93644 of which 0 recycled
                        Never used RAM 42456, free system stack 200 words
                        Tasks: SBC(ready,2.3%,312) HEAT(notifyWait,0.0%,269) Move(notifyWait,0.0%,338) CanReceiv(notifyWait,0.0%,772) CanSender(notifyWait,0.0%,372) CanClock(delaying,0.0%,346) TMC(notifyWait,1.1%,106) MAIN(running,95.1%,536) IDLE(ready,0.7%,29) AIN(delaying,0.8%,264), total 100.0%
                        Owned mutexes: HTTP(MAIN)
                        Last reset 00:05:55 ago, cause: power up
                        Last software reset at 2021-10-30 23:33, reason: User, GCodes spinning, available RAM 42456, slot 0
                        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task SBC Freestk 0 n/a
                        Error status: 0x00
                        MCU revision 3, ADC conversions started 355962, completed 355961, timed out 0, errs 0
                        Step timer max interval 1474
                        MCU temperature: min 21.7, current 29.9, max 29.9
                        Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                        Heap OK, handles allocated/used 99/5, heap memory allocated/used/recyclable 2048/224/158, gc cycles 0
                        Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 32297, writes 11, timeouts 0, DMA errors 0
                        Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 32296, writes 11, timeouts 0, DMA errors 0
                        Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 32296, writes 11, timeouts 0, DMA errors 0
                        Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 32296, writes 11, timeouts 0, DMA errors 0
                        Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 32299, writes 9, timeouts 0, DMA errors 0
                        Driver 5: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 32296, writes 11, timeouts 0, DMA errors 0
                        Driver 6: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 32296, writes 11, timeouts 0, DMA errors 0
                        Date/time: 2021-10-31 00:02:40
                        Cache data hit count 836168537
                        Slowest loop: 9.15ms; fastest: 0.07ms
                        === Storage ===
                        Free file entries: 10
                        SD card 0 not detected, interface speed: 0.0MBytes/sec
                        DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                        === MainDDARing ===
                        === AuxDDARing ===
                        Bed heaters = 0 -1, chamberHeaters = -1 -1
                        Segments left: 0
                        Movement lock held by null
                        Telnet is idle in state(s) 0
                        File is idle in state(s) 0
                        USB is idle in state(s) 0
                        Aux is idle in state(s) 0
                        Queue is idle in state(s) 0
                        LCD is idle in state(s) 0
                        SBC is idle in state(s) 0
                        Daemon is idle in state(s) 0
                        Aux2 is idle in state(s) 0
                        Code queue is empty
                        === CAN ===
                        Messages queued 3111, received 6801, lost 0, longest wait 2ms for reply type 6026, peak Tx sync delay 3, free buffers 16 (min 15), ts 1778/1777/0
                        Tx timeouts 0,0,0,0,0,0
                        === SBC interface ===
                        State: 4, failed transfers: 1, checksum errors: 0
                        Last transfer: 4ms ago
                        RX/TX seq numbers: 13281/13281
                        SPI underruns 0, overruns 0
                        Disconnects: 0, timeouts: 0, IAP RAM available 0x10810
                        Buffer RX/TX: 0/0-0
                        === Duet Control Server ===
                        Duet Control Server v3.4.0
                        Code buffer space: 4096
                        Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
                        Full transfers per second: 39.80, max time between full transfers: 87.9ms, max pin wait times: 51.1ms/11.5ms
                        Codes per second: 0.22
                        Maximum length of RX/TX data transfers: 3464/796
                          SputnikOC3d
                          Please mark this issue as resolved - it was due to m failure to notice mismatched firmware.
                          Got the right FW on the Duet Mainboard via M997 S0
                            SputnikOC3d @SputnikOC3d
                            @sputnikoc3d - well the rasp pi is not updated to 3.4.0 stable though
                            grep of the isntalled duet versions indicates all are still on 3.4beta3 on the Pi
                            Ideas to correct this ?
                            • Phaedruxundefined Phaedrux has marked this topic as solved
                              I think you got your answer in your other thread.
