    Connection lost, attempting to reconnect
    • Sculpt Fabricatorundefined
      Sculpt Fabricator
      Everything has been working fine with our printer, we just changed out our extruder and noticed it was retracting when it should be extruding, made the change in the g code, the printer shut down like normal and restarted, but now just reads connecting on the Duet screen and the dashboard just reads connection lost, attempting to reconnect.
      Printer is a Modex big 60
      We are running Duet wifi and Duex 5 with the latest updates but cannot retrieve any info to give you exact versions
      Any thoughts on what to try, besides turning off and unplugging power?
      Thank you
      Sculpt Fabricatorundefined 1 Reply Last reply Reply Quote 0
        Sculpt Fabricator @Sculpt Fabricator
        @sculpt-fabricator said in Connection lost, attempting to reconnect:
        Thank you
        We tried M552 S1 on the PanelDue but get no response on the screen, we also noticed when we click on the SD card icon, it doesn't show anything on the card, but if we bring the card over to the computer we can verify everything is still on the card. this would be the sd card from the duet wifi board
          To do some proper troubleshooting I think you'll need to remove the Duet from the enclosure and test it on the bench connected to a PC with USB. You can follow this guide to see how far you can get.
          https://docs.duet3d.com/en/User_manual/Troubleshooting/Duet_wont_respond
          Sculpt Fabricatorundefined 2 Replies Last reply Reply Quote 0
            Sculpt Fabricator @Phaedrux
            @phaedrux The lights look good
            when connecting to the device we get
            USB serial device (com4)
            is this considered unknown device?
              @phaedrux we did get in and ran a M122, which comes back stuck in spinloop?
                Can you copy and paste the full m122 response please?
                  @phaedrux we actually followed the
                  Fallback procedure #1 and got it back up and running again, thank you for your help
                  • dc42undefined dc42 marked this topic as a question
                  • dc42undefined dc42 has marked this topic as solved
