    Delta - Nozzle crashing into bed
    1.3k
    • fcwiltundefined
      fcwilt @malkem
      @malkem said in Delta - Nozzle crashing into bed:
      @blt3dp
      I dont get it. I put the G30 between G28 and G32, the result is the same. As soon as the printer starts to print it crashes into the bed, not by much but I can hear the knock.
      Would it help to decrease the Z-value in G31 P50 X0 Y0 Z-0.07?
      The larger the Z Trigger Height value the closer the nozzle ends up to the bed when Z is set to 0.
      So make the value smaller could help with your problem.
      malkemundefined 1 Reply Last reply Reply Quote 0
      • malkemundefined
        malkem @fcwilt
        @fcwilt
        Tried it out to decrease Z to -2 (G31 P50 X0 Y0 Z-2).
        My printer doesn't care anymore. He lower the nozzle always to the same height, what is likely Z0.
        I remember increasing/decreasing the G31 Z value helped me in version 2.05.
        Any other ideas?
        Maybe the whole config.g will help?
        config.g
        ; Configuration file for Duet WiFi (firmware version 3.3)
        ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Apr 11 2022 12:41:54 GMT+0200 (Mitteleuropäische Sommerzeit)
        G90                                                  ; send absolute coordinates...
        M83                                                  ; ...but relative extruder moves
        M550 P"TLM"                                          ; set printer name
        M665 L400.350:400.350:400.350 R172.703 H511.873 B155.0 X-0.022 Y-0.040 Z0.000                          ; Set delta radius, diagonal rod length, printable radius and homed height
        M666 X0 Y0 Z0                                        ; put your endstop adjustments here, or let auto calibration find them
        M552 S1                                              ; enable network
        M586 P0 S1                                           ; enable HTTP
        M586 P1 S0                                           ; disable FTP
        M586 P2 S0                                           ; disable Telnet
        M569 P0 S1                                           ; physical drive 0 goes forwards
        M569 P1 S1                                           ; physical drive 1 goes forwards
        M569 P2 S1                                           ; physical drive 2 goes forwards
        M569 P3 S1                                           ; physical drive 3 goes forwards
        M584 X0 Y1 Z2 E3                                     ; set drive mapping
        M350 X16 Y16 Z16 E16 I1                              ; configure microstepping with interpolation
        M92 X80.00 Y80.00 Z80.00 E815.00                     ; set steps per mm
        M566 X540.00 Y540.00 Z540.00 E240.00                 ; set maximum instantaneous speed changes (mm/min)
        M203 X24000.00 Y24000.00 Z24000.00 E6000.00          ; set maximum speeds (mm/min)
        M201 X7500.00 Y7500.00 Z7500.00 E3000.00             ; set accelerations (mm/s^2)
        M906 X1600 Y1600 Z1600 E1000 I30                     ; set motor currents (mA) and motor idle factor in per cent
        M84 S30                                              ; Set idle timeout
        M208 Z0 S1                                           ; set minimum Z
        M574 X2 S1 P"xstop"                                  ; configure switch-type (e.g. microswitch) endstop for high end on X via pin xstop
        M574 Y2 S1 P"ystop"                                  ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
        M574 Z2 S1 P"zstop"                                  ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin zstop
        M558 P8 R0.4 C"zprobe.in+zprobe.mod" H18 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
        G31 P50 X0 Y0 Z-2                                 ; set Z probe trigger value, offset and trigger height
        M557 R130 S10                                        ; define mesh grid
        M308 S0 P"bedtemp" Y"thermistor" T100000 B3950       ; configure sensor 0 as thermistor on pin bedtemp
        M950 H0 C"bedheat" T0                                ; create bed heater output on bedheat and map it to sensor 0
        M307 H0 B0 S1.00                                     ; disable bang-bang mode for the bed heater and set PWM limit
        M307 H0 R1.501 K0.636:0.000 D1.85 E1.35 S1.00 B0 ; PID parameter
        M140 H0                                              ; map heated bed to heater 0
        M143 H0 S100                                         ; set temperature limit for heater 0 to 100C
        M308 S1 P"e0temp" Y"thermistor" T100000 B3950        ; configure sensor 1 as thermistor on pin e0temp
        M950 H1 C"e0heat" T1                                 ; create nozzle heater output on e0heat and map it to sensor 1
        M307 H1 B0 S1.00                                     ; disable bang-bang mode for heater  and set PWM limit
        M307 H1 R2.755 K0.408:0.372 D5.79 E1.35 S1.00 B0 V24.0	; PID parameter
        M143 H1 S260                                         ; set temperature limit for heater 1 to 260C
        M950 F0 C"fan0" Q500                                 ; create fan 0 on pin fan0 and set its frequency
        M106 P0 S0 H-1                                       ; set fan 0 value. Thermostatic control is turned off
        M950 F1 C"fan1" Q500                                 ; create fan 1 on pin fan1 and set its frequency
        M106 P1 S1 H1 T125                                   ; set fan 1 value. Thermostatic control is turned on
        M950 F2 C"fan1" Q500                                 ; create fan 2 on pin fan1 and set its frequency
        M106 P2 S1 H-1                                       ; set fan 2 value. Thermostatic control is turned off
        M563 P0 D0 H1 F0                                     ; define tool 0
        G10 P0 X0 Y0 Z0                                      ; set tool 0 axis offsets
        G10 P0 R0 S0                                         ; set initial tool 0 active and standby temperatures to 0C
        M501 ; Load saved parameters from non-volatile memory
        config-override.g
        ; config-override.g file generated in response to M500 at 2022-04-12 20:28
        ; Delta parameters
        M665 L400.350 R172.703 H511.873 B155.0 X-0.022 Y-0.040 Z0.000
        M666 X-0.599 Y-0.539 Z1.138 A0.04 B0.33
        ; Heater model parameters
        • fcwiltundefined
          fcwilt @malkem
          @malkem
          You don't need to run a print to verify that things are OK.
          Move the probe to the center of the bed. Execute G30. When done it should end up at appx Z=16.
          Then jog down until the nozzle is just touching the bed. Check the Z position in the DWC. It should be close to 0 if all is well.
            Have you actually tried to measure your probe trigger height yet?
            https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_testing#calibrate-the-z-probe-trigger-height
            Also, just in case, can you send M122 and M98 P"config.g" and post the results?
            • malkemundefined
              malkem @Phaedrux
              @phaedrux
              Hi and thanks for the reply!
              Here the results
              M122
              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0 (2022-03-15 18:58:31) running on Duet WiFi 1.02 or later
              Board ID: 08DGM-956GU-DJMSN-6JKD2-3SN6T-TVNRD
              Used output buffers: 3 of 24 (13 max)
              Static ram: 23868
              Dynamic ram: 73840 of which 176 recycled
              Never used RAM 14196, free system stack 184 words
              Tasks: NETWORK(ready,13.0%,232) HEAT(notifyWait,0.0%,332) Move(notifyWait,0.0%,364) MAIN(running,85.7%,440) IDLE(ready,1.3%,30), total 100.0%
              Owned mutexes: WiFi(NETWORK)
              Last reset 00:01:23 ago, cause: power up
              Last software reset at 2022-04-14 23:32, reason: User, GCodes spinning, available RAM 14296, slot 2
              Error status: 0x00
              Step timer max interval 0
              MCU temperature: min 19.8, current 25.1, max 25.3
              Supply voltage: min 24.2, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
              Events: 0 queued, 0 completed
              Driver 0: standstill, SG min n/a
              Driver 1: standstill, SG min n/a
              Driver 2: standstill, SG min n/a
              Driver 3: standstill, SG min n/a
              Driver 4: standstill, SG min n/a
              Driver 5:
              Driver 6:
              Driver 7:
              Driver 8:
              Driver 9:
              Driver 10:
              Driver 11:
              Date/time: 2022-04-15 11:46:34
              Cache data hit count 2901757074
              Slowest loop: 15.73ms; fastest: 0.19ms
              === Storage ===
              Free file entries: 10
              SD card longest read time 1.2ms, write time 0.0ms, max retries 0
              DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
              === MainDDARing ===
              === AuxDDARing ===
              Segments left: 0
              Movement lock held by null
              HTTP is idle in state(s) 0
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Trigger is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              Daemon is idle in state(s) 0
              Code queue is empty
              === Network ===
              Slowest loop: 161.06ms; fastest: 0.00ms
              HTTP sessions: 1 of 8
              - WiFi -
              Network state is active
              WiFi firmware version 1.26
              WiFi MAC address 5c:cf:7f:76:68:64
              WiFi Vcc 3.36, reset reason Turned on by main processor
              WiFi flash size 4194304, free heap 24408
              WiFi IP address 192.168.178.33
              WiFi signal strength -47dBm, mode 802.11n, reconnections 0, sleep mode modem
              Clock register 00002002
              Socket states: 4 0 0 0 0 0 0 0
              M98 P"config.g"
              HTTP is enabled on port 80
              FTP is disabled
              TELNET is disabled
              Error: bad grid definition: Too many grid points; suggest increase spacing to 13.0mm
              Error: Pin 'fan1' is not free
              Error: Fan number 2 not found
              @phaedrux said in Delta - Nozzle crashing into bed:
              I've done this in the past but I will give it another try.
              I haven't change any hardware components.
              • malkemundefined
                malkem @malkem
                Just measured the Z trigger height. It is -0.15
                I've set the Z value to -2 so the nozzle should be far above the bed, am I right?
                  Phaedrux Moderator @malkem
                  Yes. -2mm is pretty extreme. That would make it think that the nozzle is 2mm below the bed surface when the probe triggers.
                  So tell me this, set your G31 Z trigger height correctly to -0.15 and then if you do a G28 to home the towers and then a G30 to probe the bed to set Z0, if you then send G1 Z0 does the nozzle end up just touching the bed?
                  • malkemundefined
                    malkem @Phaedrux
                    @phaedrux
                    Good morning phaedrux
                    I just did how you said and the nozzle was not crashing into the bed.
                    The space between nozzle and bed was just enough to slide in the sheet of paper I used to determine the Z trigger height.
                    I've send G32 after G30 and went again to Z0 and nothing has changed, it was enough space to slide in the sheet of paper.
                    This part seems working fine.
                    So what the hell is the problem of my printer?
                    I'm close to toss him out the window 😠
                    • malkemundefined
                      malkem @malkem
                      I'm running out of ideas.
                      Should I downgrade? Is it even possible?
                      In my old config.g (v2.05) I've used P1 instead of P8 "M558 P1 H18 F240 R0.4 T4000"
                      Could it change anything?
                      I took a look into the gcode file, there is also nothing suspicious in my opinion.
                      ; generated by PrusaSlicer 2.4.1+win64 on 2022-04-16 at 18:16:02 UTC
                      ; external perimeters extrusion width = 0.50mm
                      ; perimeters extrusion width = 0.50mm
                      ; infill extrusion width = 0.46mm
                      ; solid infill extrusion width = 0.45mm
                      ; top infill extrusion width = 0.40mm
                      ; support material extrusion width = 0.35mm
                      ; first layer extrusion width = 0.70mm
                      M107
                      M190 S60 ; set bed temperature and wait
                      ;TYPE:Custom
                      ;M558 P1 H8.5 F240 R0.4 T4000
                      M558 P8 R0.4 C"zprobe.in+zprobe.mod" H3 F240 T6000
                      M109 S120
                      G28
                      G1 X0 Y0 Z8.5 F6000
                      G30
                      G32    ; auto calibration
                      G29 S1 ; heightmap.csv
                      G1 X0 Y0 Z100; lift nozzle
                      M104 S210
                      M109 S210
                      G1 X0 Y0 Z10; lower nozzle
                      G21 ; set units to millimeters
                      G90 ; use absolute coordinates
                      M82 ; use absolute distances for extrusion
                      G92 E0
                      ;M572 D0 S0.05; linear advanced PLA-NX2
                      M107
                      ;LAYER_CHANGE
                      ;Z:0.35
                      ;HEIGHT:0.35
                      G1 Z.35 F27000
                      G1 E-2.8 F2400
                      G92 E0
                      G1 Z.55 F27000
                      G1 X0 Y14.575
                      G1 Z.35
                      G1 E2.8 F2400
                      ;TYPE:Skirt/Brim
                      ;WIDTH:0.7
                      G1 X-43.737 Y14.575 E6.49863
                      G1 X-44.622 Y14.439 E6.57429
                      G1 X-45.393 Y14.072 E6.64657
                      G1 X-46.033 Y13.478 E6.72039
                      G1 X-46.457 Y12.732 E6.79294
                      G1 X-46.657 Y11.769 E6.87613
                      G1 X-46.546 Y10.734 E6.96417
                      G1 X-46.132 Y9.713 E7.05727
                      G1 X-45.438 Y8.762 E7.15689
                      G1 X-22.591 Y-14.091 E9.88954
                      G1 X-21 Y-14.75 E10.03515
                      G1 X21 Y-14.75 E13.58686
                      G1 X22.591 Y-14.091 E13.73247
                      G1 X45.633 Y8.986 E16.4902
                      G1 X46.078 Y9.619 E16.5556
                      G1 X46.402 Y10.284 E16.6182
                      G1 X46.598 Y10.965 E16.67807
                      G1 X46.661 Y11.635 E16.73506
                      G1 X46.584 Y12.315 E16.79292
                      G1 X46.377 Y12.92 E16.84695
                      G1 X46.047 Y13.461 E16.90053
                      G1 X45.613 Y13.908 E16.95323
                      G1 X44.75 Y14.397 E17.03707
                      G1 X43.737 Y14.575 E17.12405
                      G1 X.06 Y14.575 E20.81758
                      G1 X.06 Y13.95 F27000
                      G1 F2400
                      G1 X-43.722 Y13.95 E24.52001
                      G1 X-44.426 Y13.846 E24.58014
                      G1 X-45.043 Y13.554 E24.63786
                      G1 X-45.533 Y13.103 E24.69422
                      G1 X-45.878 Y12.498 E24.7531
                      G1 X-46.035 Y11.694 E24.82235
                      G1 X-45.925 Y10.831 E24.89594
                      G1 X-45.559 Y9.97 E24.97506
                      G1 X-44.963 Y9.169 E25.0595
                      G1 X-22.149 Y-13.649 E27.78808
                      G1 X-21 Y-14.125 E27.89325
                      G1 X21 Y-14.125 E31.44496
                      G1 X22.149 Y-13.649 E31.55013
                      G1 X45.101 Y9.324 E34.29624
                      G1 X45.779 Y10.41 E34.40454
                      G1 X45.961 Y10.973 E34.45455
                      G1 X46.034 Y11.532 E34.50226
                      G1 X45.996 Y12.068 E34.54771
                      G1 X45.849 Y12.571 E34.592
                      G1 X45.597 Y13.018 E34.63538
                      G1 X45.24 Y13.405 E34.67995
                      G1 X44.547 Y13.806 E34.74759
                      G1 X43.725 Y13.95 E34.81815
                      G1 X.12 Y13.95 E38.50562
                      G1 E35.70562
                      G92 E0
                      G1 Z.55 F27000
                      G1 X-20.161 Y-1.329
                      G1 Z.35
                      G1 E2.8 F2400
                      ;TYPE:Perimeter
                      G1 X-20.429 Y-.989 E2.83663
                      G1 X-20.751 Y-.714 E2.87243
                      G1 X-21.128 Y-.502 E2.90899
                      G1 X-21.53 Y-.372 E2.94472
                      G1 X-21.957 Y-.321 E2.98107
                      G1 X-22.364 Y-.351 E3.01556
                      G1 X-22.781 Y-.465 E3.05212
                      G1 X-23.169 Y-.66 E3.08883
                      G1 X-23.502 Y-.92 E3.12457
                      G1 X-23.784 Y-1.248 E3.16116
                      G1 X-23.991 Y-1.614 E3.19668
                      G1 X-24.124 Y-2.012 E3.23219
                      G1 X-24.179 Y-2.443 E3.26895
                      G1 X-24.147 Y-2.876 E3.3057
                      G1 X-24.034 Y-3.283 E3.34141
                      G1 X-23.84 Y-3.669 E3.37791
                      G1 X-23.581 Y-4 E3.41346
                      G1 X-23.264 Y-4.276 E3.44898
                      G1 X-22.888 Y-4.49 E3.48555
                      G1 X-22.488 Y-4.624 E3.52129
                      G1 X-22.059 Y-4.679 E3.55783
                      G1 X-21.638 Y-4.649 E3.59351
                      G1 X-21.219 Y-4.535 E3.63025
                      G1 X-20.831 Y-4.339 E3.66702
                      G1 X-20.498 Y-4.08 E3.70269
                      G1 X-20.217 Y-3.753 E3.73914
                      G1 X-20.009 Y-3.387 E3.77478
                      G1 X-19.875 Y-2.986 E3.81052
                      G1 X-19.821 Y-2.544 E3.84817
                      G1 X-19.854 Y-2.122 E3.88399
                      G1 X-19.966 Y-1.716 E3.91955
                      G1 X-20.134 Y-1.383 E3.95117
                      G1 X-20.691 Y-1.666 F27000
                      ;TYPE:External perimeter
                      G1 F2400
                      G1 X-20.882 Y-1.424 E3.97729
                      G1 X-21.11 Y-1.229 E4.00268
                      G1 X-21.38 Y-1.077 E4.02882
                      G1 X-21.665 Y-.985 E4.05414
                      G1 X-21.971 Y-.949 E4.0802
                      G1 X-22.258 Y-.97 E4.10451
                      G1 X-22.556 Y-1.051 E4.13066
                      G1 X-22.833 Y-1.191 E4.15685
                      G1 X-23.069 Y-1.375 E4.18218
                      G1 X-23.271 Y-1.609 E4.20835
                      G1 X-23.418 Y-1.869 E4.23357
                      G1 X-23.512 Y-2.152 E4.25879
                      G1 X-23.551 Y-2.459 E4.28502
                      G1 X-23.528 Y-2.769 E4.31124
                      G1 X-23.448 Y-3.057 E4.33655
                      G1 X-23.309 Y-3.333 E4.36265
                      G1 X-23.126 Y-3.568 E4.3879
                      G1 X-22.9 Y-3.764 E4.41312
                      G1 X-22.632 Y-3.917 E4.43929
                      G1 X-22.348 Y-4.012 E4.46461
                      G1 X-22.041 Y-4.051 E4.49075
                      G1 X-21.743 Y-4.03 E4.51602
                      G1 X-21.444 Y-3.949 E4.54224
                      G1 X-21.167 Y-3.809 E4.56848
                      G1 X-20.931 Y-3.625 E4.59375
                      G1 X-20.73 Y-3.392 E4.61981
                      G1 X-20.583 Y-3.131 E4.64514
                      G1 X-20.488 Y-2.847 E4.67046
                      G1 X-20.449 Y-2.53 E4.69748
                      G1 X-20.472 Y-2.231 E4.72288
                      G1 X-20.552 Y-1.943 E4.74814
                      G1 X-20.664 Y-1.72 E4.76925
                      G1 X-20.549 Y-1.392 F27000
                      G1 E1.96925 F2400
                      G92 E0
                      • fcwiltundefined
                        fcwilt
                        @malkem
                        Why did you change to probe type 8?
                        I would think the strain gauge would output an analog signal.
                        • malkemundefined
                          malkem @fcwilt
                          @fcwilt
                          I changed it back to P1, it didn't help. Got the same results.
                          If I do it manually G28 -> G30 -> G32 and move the nozzle to Z0, there is a gap between bed and nozzle, just how we would expect.
                          If I upload a gcode file and start to print, the DWC shows that the nozzle is moving to the first layer height to Z.35. But the nozzle is actually flat on the bed.
                          • fcwiltundefined
                            fcwilt @malkem
                            @malkem
                            Well in the print file you have G28 then G30 then G32 then G29.
                            Remember that G29 is going to change the Z position based on the X/Y position.
                            Also for the height map to work correctly you need to set the Z=0 Datum before creating the height map and before loading the height map. Moreover the X/Y position used for setting the Z=0 Datum must always be the same. I use the center of the bed which for me is at X=0 Y=0.
                            I don't have a delta so I am not sure what G32 does, exactly, but I think you should still have a G30 at your reference point before you do the G29.
                            And did you set the Z=-0 Datum before creating the height map?
                            • malkemundefined
                              malkem @fcwilt
                              @fcwilt
                              Hi and thanks for your time helping me out here 👍
                              heightmap and G29 was never a problem before. I've also tried without G29.
                              I downgraded to version 2.05 and my printer works again.
                              I dont know if this is a bug or just me doing something wrong.
                              If you guys want me to try something out, I will do it. But for now I'll stay on version 2.05.😁
