    BL-Touch to Alfawise U10
    970
    • Perttiundefined
      Pertti @Phaedrux
      @phaedrux
      (I tried to zip all, but the file format was not allowed.)
      deployprobe.g :
      M280 P0 S10
      retractprobe.g :
      M280 P0 S90
      config.g :
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Mar 07 2022 20:17:53 GMT+0200 (Itä-Euroopan normaaliaika)
      M550 P"Alfawise U10" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M92 X80.00 Y80.00 Z400.00 E92 ; set steps per mm
      M203 X20000.00 Y20000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z20.00 E250.00 ; set accelerations (mm/s^2)
      M906 X800 Y800 Z1600 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X400 Y400 Z500 S0 ; set axis maxima
      ; M574 X1 S3 ; Set X / Y endstop stall detection M574 X1 Y1 S3
      M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
      M574 Z1 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop
      M557 X15:350 Y15:350 S20 ; define mesh grid
      M950 S0 C"exp.heater3" ; Duet 2 WiFi/Ethernet
      M558 P9 C"^zprobe.in" H5 F120 T3000 ; Duet 2 WiFi/Ethernet, DueX2/5
      M280 P0 S10 ; send control signal to BLTouch through servo/gpio 0
      G31 X20 Y0 Z3.3 P25; offsetit
      ;Stall Detection
      ;M915 X R3 F0 H400 R4700 ; X / Y Axes M915 X Y S3 F0 H400 R4700
      ;M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit
      M307 H0 B0 R0.086 C686.8 D1.84 S1.00 V12.5
      ;M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
      M307 H1 B0 R1.620 C208.6 D10.64 S1.00 V12.6
      Pertti
      “A winner is just a loser who tried one more time.”
      George M. Moore, Jr.
        Phaedrux Moderator @Phaedrux
        @phaedrux said in BL-Touch to Alfawise U10:
        Also please send M122 and M98 P"config.g" and post the results.
        Perttiundefined 1 Reply Last reply Reply Quote 0
        • Perttiundefined
          Pertti @Phaedrux
          @phaedrux
          21.4.2022 klo 12.39.39 M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
          Board ID: 0JD0M-9P6M2-NWNS0-7J9DD-3S86K-1A3ML
          Used output buffers: 3 of 24 (11 max)
          Static ram: 23876
          Dynamic ram: 75032 of which 12 recycled
          Never used RAM 15496, free system stack 178 words
          Tasks: NETWORK(ready,12.6%,231) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,364) MAIN(running,86.6%,441) IDLE(ready,0.7%,29), total 100.0%
          Owned mutexes: WiFi(NETWORK)
          Last reset 00:02:22 ago, cause: power up
          Last software reset at 2022-04-20 17:07, reason: User, GCodes spinning, available RAM 15496, slot 1
          Error status: 0x00
          Aux0 errors 0,0,0
          Step timer max interval 0
          MCU temperature: min 18.4, current 24.5, max 24.6
          Supply voltage: min 12.6, current 12.7, max 12.9, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: position 0, standstill, SG min/max not available
          Driver 1: position 0, standstill, SG min/max not available
          Driver 2: position 0, standstill, SG min/max not available
          Driver 3: position 0, standstill, SG min/max not available
          Driver 4: position 0, standstill, SG min/max not available
          Driver 5: position 0
          Driver 6: position 0
          Driver 7: position 0
          Driver 8: position 0
          Driver 9: position 0
          Driver 10: position 0
          Driver 11: position 0
          Date/time: 2022-04-21 12:39:38
          Slowest loop: 5.19ms; fastest: 0.17ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 4.0ms, write time 0.0ms, max retries 0
          === MainDDARing ===
          === AuxDDARing ===
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 15.55ms; fastest: 0.00ms
          HTTP sessions: 1 of 8
          • WiFi -
            Network state is active
            WiFi firmware version 1.26
            WiFi MAC address f4:cf:a2:68:47:93
            WiFi Vcc 3.35, reset reason Power up
            WiFi flash size 2097152, free heap 25520
            WiFi IP address 192.168.10.126
            WiFi signal strength -58dBm, mode 802.11n, reconnections 0, sleep mode modem
            Clock register 00002002
          98 P"config.g"
          Error: Bad command: 98 P"config.g"
          Pertti
            dc42 administrators @Pertti
            @pertti said in BL-Touch to Alfawise U10:
            98 P"config.g"
            You missed out the leading M.
            • Perttiundefined
              Pertti @dc42
              @dc42 I see... what do You mean by "missing out the leading M"?
              Pertti
                @pertti you ran command:
                98 P"config.g"
                instead of:
                M98 P"config.g"
                • Perttiundefined
                  Pertti @dc42
                  @dc42 Ok, I got it, thank You.
                  21.4.2022 klo 13.38.36 M98 P"config.g"
                  HTTP is enabled on port 80
                  FTP is disabled
                  TELNET is disabled
                  Pertti
                    @pertti does the BLTouch perform its self test when you power up?
                    • Perttiundefined
                      Pertti @dc42
                      Nope
                      Pertti
                        It sounds like the BLTouch is not getting power if it's not doing a self test. Does it light up?
                        • Perttiundefined
                          Pertti @Phaedrux
                          @phaedrux
                          No light. I´ll check the wires.
                          Pertti
                          • Perttiundefined
                            Pertti @Pertti
                            @pertti The BL touch wire connector was 1 step aside in the motherboard. 😖 wiring1.PNG
                            I´ll continue the experiment soon.
                            Pertti
                            • Perttiundefined
                              Pertti @Pertti
                              @pertti Now it gets power! At the start the Bl-touch moves back and forth . After homing it twinkles red light.
                              I have no idea weather the BL-touch is supposed to be the z-endstop or not. Is my configuration ok?
                              Pertti
                              dc42undefined Lo-Fiundefined 2 Replies Last reply Reply Quote 0
                                @pertti do M401 and M402 work to deploy and retract the probe?
                                • Lo-Fiundefined
                                  Lo-Fi @Pertti
                                  @pertti Do you have a Z stop switch as well as the BLTouch? If not and you want to use the BL for Z homing, you'll want to change M574 Y1 S1 P"ystop" to M574 Z1 S2 in your config and define a Z homing macro.
                                  This blog post here give an excellent overview of the macros:
                                  https://betrue3d.dk/bltouch-on-duet-wifi-configuratio-and-usage/
                                  Remove the M280 command in the config, that belongs in the Pin Down macro.
                                  • Perttiundefined
                                    Pertti @dc42
                                    @dc42 said in BL-Touch to Alfawise U10:
                                    M401
                                    M401 deploys an d M402 retracts the probe.
                                    Pertti
                                    • Perttiundefined
                                      Pertti @Lo-Fi
                                      @lo-fi Yes I have a remainig z endstop. I do not know is it worth saving. Less moving parts sounds good. And if I changed the bed surface thickness then it is easier to handle with z probe.
                                      Pertti
                                        Share your homeall and homez here and we can tell you if anything needs to change. In general though, to home Z with the probe you need a G30 command. And before the G30 you'd need a G1 X Y command to move the probe into position. Ideally the center of the bed.
                                        • Perttiundefined
                                          Pertti @Phaedrux
                                          @phaedrux
                                          I´ll check this, looks good. https://betrue3d.dk/bltouch-on-duet-wifi-configuratio-and-usage/
                                          ; homeall.g
                                          ; called to home all axes
                                          ; generated by RepRapFirmware Configuration Tool v3.3.10 on Sun Mar 06 2022 15:03:52 GMT+0200 (Itä-Euroopan normaaliaika)
                                          G91 ; relative positioning
                                          G1 H1 X-405 Y-405 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                                          G1 H2 X5 Y5 F6000 ; go back a few mm
                                          G1 H1 X-405 Y-405 F360 ; move slowly to X and Y axis endstops once more (second pass)
                                          G1 H1 Z-505 F360 ; move Z down stopping at the endstop
                                          G90 ; absolute positioning
                                          G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                                          ;G91 ; relative positioning
                                          ;G90 ; absolute positioning
                                          ; homez.g
                                          ; called to home the Z axis
                                          G1 H1 Z-505 F1800 ; move Z down until the endstop is triggered
                                          Pertti
                                            Phaedrux Moderator @Pertti
                                            Remove those lines in homeall and replace them with
                                            G90
                                            G1 X150 Y150
                                            G30
                                            And in homez, remove those lines and replace them with the same.
