    BL-Touch to Alfawise U10
    1.0k
    • Perttiundefined
      Pertti @Phaedrux
      @phaedrux
      21.4.2022 klo 12.39.39 M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
      Board ID: 0JD0M-9P6M2-NWNS0-7J9DD-3S86K-1A3ML
      Used output buffers: 3 of 24 (11 max)
      Static ram: 23876
      Dynamic ram: 75032 of which 12 recycled
      Never used RAM 15496, free system stack 178 words
      Tasks: NETWORK(ready,12.6%,231) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,364) MAIN(running,86.6%,441) IDLE(ready,0.7%,29), total 100.0%
      Owned mutexes: WiFi(NETWORK)
      Last reset 00:02:22 ago, cause: power up
      Last software reset at 2022-04-20 17:07, reason: User, GCodes spinning, available RAM 15496, slot 1
      Error status: 0x00
      Aux0 errors 0,0,0
      Step timer max interval 0
      MCU temperature: min 18.4, current 24.5, max 24.6
      Supply voltage: min 12.6, current 12.7, max 12.9, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: position 0, standstill, SG min/max not available
      Driver 1: position 0, standstill, SG min/max not available
      Driver 2: position 0, standstill, SG min/max not available
      Driver 3: position 0, standstill, SG min/max not available
      Driver 4: position 0, standstill, SG min/max not available
      Driver 5: position 0
      Driver 6: position 0
      Driver 7: position 0
      Driver 8: position 0
      Driver 9: position 0
      Driver 10: position 0
      Driver 11: position 0
      Date/time: 2022-04-21 12:39:38
      Slowest loop: 5.19ms; fastest: 0.17ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 4.0ms, write time 0.0ms, max retries 0
      === MainDDARing ===
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 15.55ms; fastest: 0.00ms
      HTTP sessions: 1 of 8
      • WiFi -
        Network state is active
        WiFi firmware version 1.26
        WiFi MAC address f4:cf:a2:68:47:93
        WiFi Vcc 3.35, reset reason Power up
        WiFi flash size 2097152, free heap 25520
        WiFi IP address 192.168.10.126
        WiFi signal strength -58dBm, mode 802.11n, reconnections 0, sleep mode modem
        Clock register 00002002
      98 P"config.g"
      Error: Bad command: 98 P"config.g"
      Pertti
      “A winner is just a loser who tried one more time.”
      George M. Moore, Jr.
        dc42 administrators @Pertti
        @pertti said in BL-Touch to Alfawise U10:
        98 P"config.g"
        You missed out the leading M.
        Perttiundefined 1 Reply Last reply Reply Quote 0
        • Perttiundefined
          Pertti @dc42
          @dc42 I see... what do You mean by "missing out the leading M"?
          Pertti
            @pertti you ran command:
            98 P"config.g"
            instead of:
            M98 P"config.g"
            • Perttiundefined
              Pertti @dc42
              @dc42 Ok, I got it, thank You.
              21.4.2022 klo 13.38.36 M98 P"config.g"
              HTTP is enabled on port 80
              FTP is disabled
              TELNET is disabled
              Pertti
                @pertti does the BLTouch perform its self test when you power up?
                • Perttiundefined
                  Pertti @dc42
                  Nope
                  Pertti
                    It sounds like the BLTouch is not getting power if it's not doing a self test. Does it light up?
                    • Perttiundefined
                      Pertti @Phaedrux
                      @phaedrux
                      No light. I´ll check the wires.
                      Pertti
                      • Perttiundefined
                        Pertti @Pertti
                        @pertti The BL touch wire connector was 1 step aside in the motherboard. 😖 wiring1.PNG
                        I´ll continue the experiment soon.
                        Pertti
                        • Perttiundefined
                          Pertti @Pertti
                          @pertti Now it gets power! At the start the Bl-touch moves back and forth . After homing it twinkles red light.
                          I have no idea weather the BL-touch is supposed to be the z-endstop or not. Is my configuration ok?
                          Pertti
                          dc42undefined Lo-Fiundefined 2 Replies Last reply Reply Quote 0
                            @pertti do M401 and M402 work to deploy and retract the probe?
                            • Lo-Fiundefined
                              Lo-Fi @Pertti
                              @pertti Do you have a Z stop switch as well as the BLTouch? If not and you want to use the BL for Z homing, you'll want to change M574 Y1 S1 P"ystop" to M574 Z1 S2 in your config and define a Z homing macro.
                              This blog post here give an excellent overview of the macros:
                              https://betrue3d.dk/bltouch-on-duet-wifi-configuratio-and-usage/
                              Remove the M280 command in the config, that belongs in the Pin Down macro.
                              • Perttiundefined
                                Pertti @dc42
                                @dc42 said in BL-Touch to Alfawise U10:
                                M401
                                M401 deploys an d M402 retracts the probe.
                                Pertti
                                • Perttiundefined
                                  Pertti @Lo-Fi
                                  @lo-fi Yes I have a remainig z endstop. I do not know is it worth saving. Less moving parts sounds good. And if I changed the bed surface thickness then it is easier to handle with z probe.
                                  Pertti
                                    Share your homeall and homez here and we can tell you if anything needs to change. In general though, to home Z with the probe you need a G30 command. And before the G30 you'd need a G1 X Y command to move the probe into position. Ideally the center of the bed.
                                    • Perttiundefined
                                      Pertti @Phaedrux
                                      @phaedrux
                                      I´ll check this, looks good. https://betrue3d.dk/bltouch-on-duet-wifi-configuratio-and-usage/
                                      ; homeall.g
                                      ; called to home all axes
                                      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Sun Mar 06 2022 15:03:52 GMT+0200 (Itä-Euroopan normaaliaika)
                                      G91 ; relative positioning
                                      G1 H1 X-405 Y-405 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                                      G1 H2 X5 Y5 F6000 ; go back a few mm
                                      G1 H1 X-405 Y-405 F360 ; move slowly to X and Y axis endstops once more (second pass)
                                      G1 H1 Z-505 F360 ; move Z down stopping at the endstop
                                      G90 ; absolute positioning
                                      G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                                      ;G91 ; relative positioning
                                      ;G90 ; absolute positioning
                                      ; homez.g
                                      ; called to home the Z axis
                                      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Mar 07 2022 20:17:53 GMT+0200 (Itä-Euroopan normaaliaika)
                                      G1 H1 Z-505 F1800 ; move Z down until the endstop is triggered
                                      Pertti
                                        Phaedrux Moderator @Pertti
                                        Remove those lines in homeall and replace them with
                                        G90
                                        G1 X150 Y150
                                        G30
                                        And in homez, remove those lines and replace them with the same.
                                        • Perttiundefined
                                          Pertti @Phaedrux
                                          Thank You all! First testprints going on! So far so good. I removed the z endstop and replaced it with z-probe.
                                          Pertti
                                          • Phaedruxundefined Phaedrux has marked this topic as solved
