    Help with setting up new Duet 6HC/3HC and Panel 7i
    duet 6hc duet
    836
      Do you have an SD card in the Duet? If so, remove it.
      rmilyardundefined 1 Reply Last reply Reply Quote 0
      • rmilyardundefined
        rmilyard @Phaedrux
        @phaedrux No card in the Duet board.
          You can see some troubleshooting steps here: https://github.com/Duet3D/DuetSoftwareFramework/wiki/SBC-Setup-Guide#troubleshooting
          Have you done a sudo apt update and sudo apt upgrade on the pi yet?
          Are you sure the ribbon cable is seated correctly?
          Have you tried using the provided SD card in the Duet itself with the Pi disconnected?
          • rmilyardundefined
            rmilyard @Phaedrux
            @phaedrux Still can't get working. I have my Pi 4 powered with own power. I have SD card ONLY in Pi. I have the Duet 6HC on 24v PSU. I have the ribbon cable between the pi and duet. When I power up pi I can get to pi via putty. I did all the updates etc on the pi. When all running I see panel 7i screen with Connecting in the top right corner. On the duet I have 4 LEDs on and a 5th labeled RSTEXT is blinking red.
            https://share.icloud.com/photos/0637SFnuSXnb6LqF5q-kpTlAw
              Is this a clone Duet?
              If you put the SD card in a PC to view the contents does it have a set of folders www sys macros gcodes ?
              If it does, put that SD card into the Duet itself and see if it will startup and connect with the PanelDue and if it becomes visible through a USB terminal. The goal is to see what the status of the board itself is.
              rmilyardundefined 2 Replies Last reply Reply Quote 0
              • rmilyardundefined
                rmilyard @Phaedrux
                • rmilyardundefined
                  rmilyard @Phaedrux
                  @phaedrux if SD card in duet and pi off it does connect.
                    Ok, so with the SD card in the Duet connect via USB terminal like YAT and check the firmware version by sending M115. It's possible that you'll just need to update the firmware to get in sync with the Pi software versions.
                    Did you create a new SD card for the Pi using a DuetPi image?
                    You can use this procedure to update the Duet 3 firmware directly via USB and Bossa. Or you can connect to it via the network and update the firmware over the web interface.
                    Both options are described here: https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware
                    You may also need to update the PanelDue firmware via USB as described here: https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_PanelDue
                    • rmilyardundefined
                      rmilyard @Phaedrux
                      @phaedrux m115 shows:
                      FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2020-05-19b2<LF>ok<LF>
                      And yes flashed the DuetPI on sd card
                        Phaedrux Moderator @rmilyard
                        @rmilyard said in Help with setting up new Duet 6HC/3HC and Panel 7i:
                        3.1.1
                        Ok, so it's likely that the Duet firmware is too out of date for DuetPi to communicate with it successfully.
                        Update the Duet firmware to 3.4 using one of the methods described in the link from my last post.
                        • rmilyardundefined
                          rmilyard @Phaedrux
                          @phaedrux which part should I do? I can't get into webui when duet straight to PC
                            Use fallback #2 to flash it via USB
                            https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware#fallback-procedure-2
                            Or connect the Duet to the network and use the webui.
                            • rmilyardundefined
                              rmilyard @Phaedrux
                              @phaedrux so in BOSSA getting just this when click write. Never moves %
                                Can you try with this version of Bossa?
                                https://github.com/Duet3D/BOSSA/releases/tag/1.9.1a-duet3d
                                What file specifically are you trying to flash?
                                • rmilyardundefined
                                  rmilyard @Phaedrux
                                  @phaedrux Duet3Firmware_MB6HC.bin
                                  • rmilyardundefined
                                    rmilyard @Phaedrux
                                    @phaedrux after messing with it more I think have 3.4.0 on duet and 1.2.4 on panel 7
                                    FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.4.0 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2022-03-15 18:57:26<LF>ok<LF>
                                      1.2.4 on panel 7
                                      You may want to update to the latest 3.x version available for the paneldue.
                                      Now that the Duet is updated you can try connecting to the Pi again. Make sure the SD card is removed from the Duet.
                                      • rmilyardundefined
                                        rmilyard @Phaedrux
                                        @phaedrux I flashed PanelDue-v3-7.0.bin164
                                        As for connecting to pi still same. Just not sure.
                                        dc42undefined rmilyardundefined 2 Replies Last reply Reply Quote 0
                                          dc42 administrators @rmilyard
                                          That's the wrong binary for a 7i. It may work, but the colours will be wrong.
                                          • rmilyardundefined
                                            rmilyard @rmilyard
                                            So wrong bin? Have the 7" PanelDue V3.0
                                            Stephen6309undefined 1 Reply Last reply Reply Quote 0
