RGB LED SK6812 vs Mini?
@chriss You may need F0 on the second M150 after the X3 command is set.
https://docs.duet3d.com/User_manual/Reference/Gcodes#m150-set-led-colours -
@stephen6309 No change unfortunately.
@chriss On my Mini and 6HC I used a separate 5vdc power supply. The mini may not have enough power to power them.
@chriss The Mini needs an external 5vdc to power the neopixel.
https://docs.duet3d.com/en/User_manual/Connecting_hardware/IO_Neopixel_DotStar -
My understanding is that the Mini5+ can deliver 3A. I guess that this would be enough for one neopixel I'm playing with at the moment...
@chriss said in RGB LED SK6812 vs Mini?:
The Mini5+ is limited to 1A total from the 5V rail including the internal current draw.
This is to connect and power NeoPixel LED strips (DotStar LED strips are not supported) . Connect the DO pin to Neopixel DI. External 5V must be supplied to the "EXT 5V" header to power the NeoPixel array, they cannot be powered from the onboard regulator.
Got it.. I had the hope that I can drive 3 tiny LEDs without a external source... well well....
@chriss if it's just 3 LEDs then you could pick up +5V from one of the IO connectors and feed it into the 5V_EXT input.
@dc42 said in RGB LED SK6812 vs Mini?:
Ahhhhhh... that's a very, very good idea... I need to check for a free 5V pin on the IO ports..... I guess that I need to feed GND too.
@chriss no, just the 5V. The GND on the Neopixel connector will be sufficient.
@dc42 Thanks!
