    1HCL 1.0 closed loop controller
    2.6k
    • supertb1undefined
      supertb1 @dc42
      @dc42 Yes sir, that is how it is set at the moment, would resetting the board help?
      G4 S1 ;wait for expansion boards to start
      M569.1 P50.0 T2 C5 E5:10 ; Configure the 1HCL board at CAN address 50 with a quadrature encoder on the motor shaft that has 20 steps per motor full step.
      M569.1 P51.0 T2 C5 E5:10 ; Configure the 1HCL board at CAN address 51 with a quadrature encoder on the motor shaft that has 20 steps per motor full step.
      M569 P50.0 D2 S1 ; Configure the motor on the 1HCL at can address 50 as being in closed-loop drive mode (D4), Open loop (D2) and not reversed (S1) X axis
      M569 P51.0 D4 S1 ; Configure the motor on the 1HCL at can address 51 as being in closed-loop drive mode (D4), Open loop (D2) and not reversed (S1) Y axis
      M584 X50.0 Y51.0 Z0.0 E0.1 ; set drive mapping
      M92 X80.50 Y81.70 Z407.00 E420.00 ; set steps per mm
      M906 X1000 Y1000 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M917 X100 Y100 ; Set the closed loop axes to have a holding current of zero
      ; homex.g
      ; called to home the X axis
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Fri Apr 08 2022 20:56:07 GMT-0500 (Central Daylight Time)
      G91 ; relative positioning
      G1 H1 X-240 F1800 ; move quickly to X axis endstop and stop there (first pass)
      G1 H2 X5 F6000 ; go back a few mm
      G1 H1 X-240 F360 ; move slowly to X axis endstop once more (second pass)
      G1 H2 Z-5 F6000 ; lower Z again
      G90 ; absolute positioning
      ; homex.g
        dc42 administrators @supertb1
        @supertb1 I was referring to this line in your homex.g file:
        M569 P50.0 D0 ; Turn off closed loop
        supertb1undefined 1 Reply Last reply Reply Quote 0
        • supertb1undefined
          supertb1 @dc42
          @dc42 I added that line to the first line of code in my home”x” and I’m still getting the same error “ driver 50.0 error: failed to maintain position. It is homing in open loop and is working that way but the error persists… I’m going to put it back in close loop and see what it does. I put it back into closed loop and of course the error persists. I switch the cards around and manually operated the switches by hand, the problem follows the motor. I disconnected the motor leads from the board, ran M122 B50 looking for the raw count being zero, then moved the motor armature and ran M122 B50 again and no change in the raw count so I think I have a bad encoder on my motor. I guess I am back to the drawing board on my end... aside from this issue I have all my other areas of concern addressed. Thank you all for your help @dc42, @Phaedrux
            @supertb1 what exactly is the sequence that gives rise to that error message? Does it occur during homing; or when homing is complete; or when you attempt an axis movement after homing? Has the driver been switched back to closed loop mode when it occurs?
            • supertb1undefined
              supertb1 @dc42
              @dc42 it happens immediately upon initiation of homing sequence, on command movement and at board reset in both open and closed loop, it will home in both open and close loop but in close loop it will not maintain position. I am going to take the motor apart to try and understand what is happening better… more to follow
              • supertb1undefined
                supertb1 @supertb1
                @supertb1 I popped the side cover off the motor and found the A+ wire had a bad solder joint, put it all back together and now when I home the axis it still returns 4/22/2022, 8:43:39 PM Error: Driver 50.0 error: failed to maintain position
                And then it displays drive 50.0 tuned successfully measured hysteresis 0.17 step… go figure… it is holding position and everything. So last question, how do I get the error to go away?
                  @supertb1 so is the only problem now that in open loop mode when you are homing and have not tuned, you are getting the "filed to maintain position" message?
                  • supertb1undefined
                    supertb1 @dc42
                    @dc42 no it is giving the alarm on a tuned closed loop homing cycle… it is doing it on my other system that I recently updated… the alarm has something to do with one of the updates I think
                      @supertb1 the homing move or moves should aways be done in open loop mode, and should be followed by the basic tuning move before switching to closed loop.
                      supertb1undefined Dutchprintingundefined 2 Replies Last reply Reply Quote 0
                      • supertb1undefined
                        supertb1 @dc42
                        @dc42 I am using the recommended homing sequence as prescribed
                          T3P3Tony administrators @supertb1
                          @supertb1 please can you test if this issue is resolved in 3.5b3
                          • supertb1undefined
                            supertb1 @T3P3Tony
                            @T3P3Tony Hi. I am almost scared to update... I am currently working through issues with my new coreXY (https://forum.duet3d.com/topic/32222/corexy-1hcl-issues/2?_=1682288729468). Apparently the close loop tuning maneuver has changed from the previous coding and it may be part of what is going on with this new machine. I will update and see if any errors develope
                              @supertb1 any news?
                              • Dutchprintingundefined
                                Dutchprinting @dc42
                                @dc42 said in 1HCL 1.0 closed loop controller:
                                You mean after homing, switch to closed loop and THEN do the tuning maneuvre? The documentation states it that way...?
                                Still having trouble with my Nema34's closed loop so i'm looking at everything right now.
                                Proudly running 1x 6CH mainboard, 5x 1HCL, 5x 1XD at 3.5b4 on my very large format 3D pinter.
