    Slightly confused about "!"...
    Gcode meta commands
    573
    • Nightowlundefined
      Nightowl @oliof
      @oliof They run on 5V adequately, but I'm beginning to think it's a wiring issue.
      I'm using CAT6 plugs and sockets, so aligning the cables has proven to be a bit of a pain!
      Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
      I'm still on my learning curve, so take everything I say with caution!
      RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
      • fcwiltundefined
        fcwilt @Nightowl
        @nightowl999 said in Slightly confused about "!"...:
        Actually, I've got the EndstopsMonitor installed, but this doesn't show a state change, either (I haven't edited the "!" out yet), but I thought, even if the proximity sensor was inverted, the LED would be 'on' until the sensor was activated, but I'm not getting that, either.
        Do you mean the LED on the Duet?
        That LED reflects that state of the hardware. The ! character inverts how the state is interpreted.
        Nightowlundefined 1 Reply Last reply Reply Quote 1
        • Nightowlundefined
          Nightowl @fcwilt
          Ok, @fcwilt, thanks.
          I've discovered it's actually a wiring issue, so I'm in the process of sorting that out, but the EndstopMonitor I was referring to is a plug-in (from the Duet3D DSF plug-in page) but I'm not sure why it's only showing 3 of the 4 proximity sensors.
          Is it because I've grouped two together (second line):
          M574 X1 S1 P"io8.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io8.in
          M574 Y2 S1 P"io6.in+io3.in" ; configure switch-type and dual self-squaring high end on Y1 and Y2
          M574 Z2 S1 P"io2.in" ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin io2.in
          Also, is it necessary for the Endstops to be configured in order, i.e. 2, 3, 6 then 8?
            Phaedrux Moderator @Nightowl
            The only time order of the endstops matters is your Y axis with multiple motors and endstops. The order of the endstops should match the order of the assigned driver/motors in the M584 command.
            So io6.in should match the motor that corresponds to the first Y axis driver listed in M584
            • Nightowlundefined
              Nightowl @Phaedrux
              Awesome, @phaedrux, thank you 👍
              • zaptaundefined
                zapta
                BTW, moving from NO to NC is a wise move. 😉
                • Nightowlundefined
                  Nightowl @zapta
                  Interesting, @zapta. Would you mind explaining why, please?
                  achrnundefined zaptaundefined 2 Replies Last reply Reply Quote 0
                  • achrnundefined
                    achrn @Nightowl
                    @nightowl999 If you use NO and the wire becomes unplugged or a wire breaks the machine doesn't notice. When something reaches the endstop and hits the switch, the machine still doesn't notice. Things crash into things.
                    If you use NC, as soon as the wire breaks or comes unplugged, it looks to the machine as if the endstop has triggered. Everything stops. Nothing crashes into anything.
                    That is, if a connection or wire failing looks the same as the endstop triggering, when it happens it's normally a 'fail safe' situation.
                    • zaptaundefined
                      zapta @Nightowl
                      I think NC considered a good practice because disconnection failure is more likely than a short failure. With NC and disconnection, your homing will stop immediately rather than crashing into into the mechanical end.
                      • Nightowlundefined
                        Nightowl @achrn
                        Brilliant, thank you both, @achrn and @zapta
