    PanelDue Current Version
    PanelDue
    1.1k
    • asteinmarkundefined
      asteinmark
      I'm wondering if anyone can provide any documentation on the current version of the PanelDue being sold from the website. I'm specifically inquiring about the 5" version, I would like to know the dimensions (technical drawings would be great) and position of mounting holes. Also what revision is it, 2nd or 3rd? All the case files I've seen are for the 1st or 2nd version but I've seen comments online about users with the 3rd version.
      I looked at the github but it only has cad files for the case for the 1st and 2nd version and no dimensions of the board.
      • elmoretundefined
        elmoret
        Current version is v3. Should be no problem to pull dimensions from the .brd file on Github.
          asteinmark
          @elmoret:
          This is just for the board, not the LCD. Also I'm not sure how to extrapolate dimensions from this file type.
          • elmoretundefined
            elmoret
            Yes, I understand. The current version of the PanelDue board, is version 3, and the .brd file on GitHub contains the dimensions. Open it with Eagle.
              The part of the version 3 board that doesn't sit behind the TFT panel is identical to the version 2 board. So enclosures designed for version 2 will also work with version 3.
              • peirofundefined
                peirof
                Some enclosure link for panel due and TFT 5"….for print
                  @peirof:
                  Mine is at https://www.thingiverse.com/thing:656884 but there are others too.
