    Resolved: Homing - Quick question...
    861
    • fcwiltundefined
      fcwilt @Nightowl
      @nightowl999 said in Homing - Quick question...:
      Thank you @fcwilt.
      Always glad to be of help when I can.
      • Nightowlundefined
        Nightowl
        When I home my Duet-controlled KillerBee CNC machine to the rear, right, up, the machine position is shown in DWC as X=-3, Y=784 and Z=97, all of which are 3mm off the proximity sensors. This isn't logical to me (except for X).
        What I would like to see is X=-3, Y=-3 and Z=-3, i.e. 3mm off their respective 0's.
        Is this something I can adjust in my config.g file or their respective homing files, please?
        Thanks
        Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
        I'm still on my learning curve, so take everything I say with caution!
        RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
        • fcwiltundefined
          fcwilt @Nightowl
          Thanks
          Is it normal for CNC machines to have the XY origin (0, 0) at the right rear as opposed to FDM printers where it is usually left front?
          So on a CNC machine is the left front position XY two negative values?
          Nightowlundefined 1 Reply Last reply Reply Quote 0
          • Nightowlundefined
            Nightowl @fcwilt
            As I understand it, @fcwilt, machine 'home' can be either rear, right, up or front. left, up - as they're essentially the same (as it was explained to me).
            The reason CNC machines use right, rear, up is to ensure the working area is clear of sharp, jaggy things when fixing stock, etc. I don't know anything about 3D printers, though.
            My old Shapeoko had it's machine home at right, rear, up and that made sense to me. Project 'home' is slightly different, in that it's the starting point for cutting the stock (wood, metal, plastic, etc) which is mounted on a spoil board. Normally (but not exclusively) the front left hand corner coordinates of the stock is X=0, Y=0 and Z being measured from the top of the stock, so all Z cuts are down. some people prefer to set Z0 on the waste board, though.
            Does that help?
            • fcwiltundefined
              fcwilt @Nightowl
              Does that help?
              I think the confusion is from the terms "home" and "homing".
              To me in the FDM printer world "homing" is the process of "synchronizing" the logical position of each axis (where the controller "thinks" things are) to the physical position of each axis (where things actually are).
              Homing can be done to either the min or max end of an axis. And there is no requirement that all axes home to the same end, min or max.
              The "origin" (0, 0) has no fixed relationship to the position used for homing. The origin is often the left, front but I use the center of the bed.
              I generally mount the endstop sensors to the rear of the printer. This means that Y would home to the max end. X would home to either the min or max end depending on where it was easiest to mount the endstop sensor.
              When a print is finished I position the extruder out of the way. Typically to X=0, Y=max which on my printers is the rear center of the bed. I call this the "parked" position to distinguish it from the "origin" or the "home" position.
              So where do wish 0,0 to be? The left front or the right rear?
              • Nightowlundefined
                Nightowl @fcwilt
                @fcwilt OK, but to me, homing is the process by which the machine understands where everything is. This is particularly relevant where the settings aren't stored in an EEPROM and retained, but configured during startup.
                And there does seem a significant difference between CNC and 3D printing in that respect, too!
                • fcwiltundefined
                  fcwilt @Nightowl
                  Isn't that what I said?
                  • Nightowlundefined
                    Nightowl @fcwilt
                    You did, sorry @fcwilt. I'm switching between two threads and trying to cook my dinner!!
                    I would like the 0,0 to be right rear, in answer to your question (which I also missed 😊 )
                    Printers do have a Z height too, don't they? My knowledge of 3D printing is non-existent, in case you were wondering!
                      Right rear 0,0 position is fine. It's the typical right hand coordinate system just rotated 180 degrees. The problem occurs when you only rotate it 90 degrees in which case you'll get a mirrored axis.
                      The physical endstop position is defined in the M574 command. If you want the homed position to be 0,0 set it to 1 for the low end of travel.
                      The homing moves in your macros will need to be negative to move towards the endstop.
                      Now it's up to you to define the motor rotation direction such that a negative move goes in the rear/right direction.
                      Nightowlundefined 1 Reply Last reply Reply Quote 1
                      • Nightowlundefined
                        Nightowl @Phaedrux
                        Thank you, @phaedrux
