    Paneldue as Pendant behavior - opposite mirrored areas activate
    PanelDue
    1.3k
    • oliofundefined
      oliof @sinned6915
      @sinned6915 if noone from diabase reads here, you will likely need to file an issue in their github https://github.com/diabase/H-Series-Pendant-Firmware
      sinned6915undefined 1 Reply Last reply Reply Quote 1
      • sinned6915undefined
        sinned6915 @oliof
        @oliof yes, that is probly best.
        I wanted to try and make sure it was not operator error first.
        thanks again
        sinned6915undefined 1 Reply Last reply Reply Quote 0
          sinned6915 @sinned6915
          The reason I am trying to make use of this is that I am trying to avoid making the PanelDue pass-through version of the pendant.
          • oliofundefined
            oliof @sinned6915
            @sinned6915 I'd want to use it as well if I were in need of a pendant. In fact I gave it a try last year but the soldering job on my encoder knob was so bad that I built back before I printed a case and returned to stock PanelDue firmware. But not for lack of want (-:
              sinned6915 @Phaedrux
              @phaedrux here are some better videos of the behavior-
              1. PanelDue with the firmware loaded. Ignore the portait/landscape difference at the start-I have it that way so you can see the lanscape mode of the normal Panel functoin. I am trying to use a stylus to push buttons so you can see the highlighed presses, and my hand movements are making the focus jumpy.
                https://photos.app.goo.gl/8nYPxtsLjEH7yCuq7
              2. Standar Paneldue firmware on the same machine with normal firmware to show normal function- https://photos.app.goo.gl/YUebXv5EmbUYDB296
                Normal hardware and normal firmware are working correctly. Beyond that I wouldn't even know where to begin looking. The Diabase github would be my next step if I were you.
                  dc42 administrators @sinned6915
                  @sinned6915 did you re-run touch calibration after switching to pendant mode?
                    sinned6915 @dc42
                    @dc42 yes, i believe I have. I will redo and double check and report back.
                    EDIT: After upload of the FW, the PanelDue is calibration mode to touch the 4 spots.
                    After calibration it is in Pendant mode, and after switching to Panel mode, rerunning the calibration does not seem to make any difference.
                    Once I have gotten into a jog selection, say X at 1.0mm, the encoder works beautifully.
                    I have tried this on both a PanelDue 7.0 with V3 controller AND on a PanelDue 7i, both behave the same.
                    Is there anything in the config.g settings that might throw this off? I looked at the H5 firmware files, but did not see anything obvious.
                    I agree that the next step would be to create an issue ticket on Diabase github.
                    I have tried delving into the source code, but I am having a hard time telling what is OE code and what is user contributed code. My conclusions are that looking at the code are above my skills at this time.
                      @sinned6915 in the original PanelDue firmware code, there is a parameter of type DisplayOrientation to the constructor that determines the polarity of the touch response. There is also a function AdjustOrientation that can change it. AFAIR the touch calibration procedure calls AdjustOrientation.
                        sinned6915 @dc42
                        @dc42 any suggestions on what to look for?
                        their firmware is supposed to work for 5i and 7i.
                        could something be 'wrapping' to behave like this?
                          @sinned6915 I don't know why you are having this problem and Diabase isn't. However, I think a solution would be to make this function call when switching between portrait and landscape:
                          touch.adjustOrientation(ReverseX | ReverseY);
                            sinned6915 @dc42
                            @dc42 where should I be looking for this function call?
                            I am looking at lines 815 - 837 of PanelDue.cpp -
                            void LandscapeDisplay(const bool withTouch)
                            	lcd.fillScr(black);
                            	lcd.setOrientation(nvData.lcdOrientation, IS_ER, true);
                            	if (withTouch)
                            		touch.init(DisplayX, DisplayY, nvData.touchOrientation);
                            		touch.calibrate(nvData.xmin, nvData.xmax, nvData.ymin, nvData.ymax, touchCalibMargin);
                            void PortraitDisplay(const bool withTouch)
                            	DisplayOrientation portrait = static_cast<DisplayOrientation>(nvData.lcdOrientation ^ (SwapXY | ReverseX));
                            	lcd.fillScr(black);
                            	lcd.setOrientation(portrait, IS_ER, true);
                            	if (withTouch)
                            		DisplayOrientation portraitTouch = static_cast<DisplayOrientation>(nvData.touchOrientation ^ (SwapXY | ReverseX));
                            		touch.init(DisplayXP, DisplayYP, portraitTouch);
                            		touch.calibrate(nvData.ymin, nvData.ymax, nvData.xmin, nvData.xmax, touchCalibMargin);
                            the references to (SwapXY | ReverseX) are throwing me off.
                            sinneD
                              @sinned6915 said in Paneldue as Pendant behavior - opposite mirrored areas activate:
                              Since X and Y need to be reversed compared to what happens now, I suggest you change ReverseX in that line to ReverseY.
                                sinned6915 @dc42
                                @dc42 that seems to have done it!
                                at least it compiled and now runs.
                                i need to reassemble it all and make all the connections to fully test.
                                i will report back.
                                solex4everundefined 1 Reply Last reply Reply Quote 0
                                • solex4everundefined
                                  solex4ever @sinned6915
                                  @sinned6915
                                  Hello, I have the same issue on PanelDue7.0/V3 controller.
                                  I can't recompile the firmware with the modified PanelDue.cpp file because I don't have the skills. Would it be possible to share the one you use? Thanks in advance
